is this rotary encoder functioning correctly? (rotary encoder inconsistent )
Hello I had problems using a rotary encoder as an input device.
after a while I decided to test it (on analog pins) to find out where the error was.
this is the code i used:
  int INclk;
  int INdt;
  int INclkOLd;
  int INdtOLd;
  int counter = 0;
  int dt = A0;
  int clk = A2;
  Serial.begin (9600);
  pinMode(clk, INPUT);
  pinMode(dt, INPUT);
  INclkOLd = analogRead(clk);
  INdtOLd = analogRead(dt);
  INclk = analogRead(clk);
  INdt = analogRead(dt);
if (INclk ==! INclkOLd || INdt ==! INdtOLd){
    Serial.print(INclk);
    Serial.print("____");
    Serial.println(INdt);
So if something changes in the CLK or DT values, the following is printed out in the serial monitor:
“CLK” ____ ”DT”
that is an example, what is written in the serial monitor when I turn it 10 clicks clockwise:
1023____0
0____0
0____1023
1023____0
1023____0
1023____0
1023____0
1023____0
0____0
0____0
0____0
1021____0
0____0
1023____0
1023____0
0____0
1023____0
1023____0
0____0
and when I turn it 10 clicks counterclockwise:
0____0
0____1023
0____1023
0____0
0____0
1023____0
0____0
0____1023
0____0
do you know what is going on there?
try this concept out:
  int dt = A0;
  int clk = A2;
  int counter;
  pinMode(dt, INPUT);
  static int LastState;
  int Clock;
  if(LastState == (Clock = digitalRead(clk))) return; // No Change
  LastState = Clock;
  if(Clock == 0) return; // Clock Went Low
  //Clock went High
  (digitalRead(dt))? counter++: counter--;
  Serial.println(counter);
Z
