Is this usage of Wire.write() correct ?
hello all,
we are experimenting with Arduino for the first time using the I2C connection to another microcontroller.
from ;
we learned that;
a)
  // join i2c bus (address optional for master)
  Wire.begin();
  Wire.beginTransmission(4); // transmit to device #4
  Wire.write("x is ");       // write five bytes
  Wire.write(x);             // write one byte
  Wire.endTransmission();    // stop transmitting
  x++;
is okay
and
b)
  Wire.begin(2);
  Wire.onRequest(requestEvent);
  delay(100);
void requestEvent()
  Wire.write("hello ");
is also okay.
but when we try;
b)
  Wire.begin(2);
  delay(100);
void requestEvent()
it is not okay.
only the last Wire.write() is received on the master-side.
is the above syntax (two times Wire.write() in a RequestEvent) valid ?
You could always do something like:
char stuffToSend[10];
sprintf(stuffToSend, "x is %d", x);
Wire.write(stuffToSend);
in the requestEvent() function.
That's right. That's what happens.
Inside a requestEvent if you try to do two writes the second one overwrites the buffer that the first one used.
As PaulS said, you need to construct a single string (or buffer) and send that with a single write.
[quote author=Nick Gammon link=topic=119628.msg901045#msg901045 date=1345676108]
###[/quote]
i see, thanks for confirming that - will have to work around that then.
ah yes, we had started thinking of concetanating the strings but encountered 'variable type' errors - will have to study how to convert using byte() and thanks PaulS for pointing out the use of sprintf.
Cheers All !
