I have an Arduino assignment for studies and it requires some sort of protocol usage.
Now I have been reading quite a bit about what protocols are and so on. However, I cannot really understand whether what I have in my project is considered using protocols.
What I have is a dht11 temperature and humidity module and I am using an esp8266 esp01 to feed the values to my computer via wifi and making the values show up on thingspeak.
Now I am using SoftwareSerial for this and if I understood correctly it sort of counts as a protocol.
I am just wondering if this is correct.
If not, how could I implement some sort of protocol usage into this sort of program of mine?
No, a protocol in this context is "an agreed upon set of rules for data representation and processing". Software Serial is more like an interface. Serial itself is a protocol because the low level timing is defined, along with the way in which data is represented for transmission. Thingspeak also has protocols.
I of course am not asking you to tell me how to explain this.
But what should I pay attention to, keep in mind when trying to explain how this is a protocol?
Like is there any specific things in the communication between the 2 which I should know?
"here is the timing requirement for the signals, here is the sequence of events, here is how any data that is transmitted is received and interpreted..."
Myself, I would use RS-232 as an example because it will be easier to find information on it.
