ISD1700 Programming problem
Hi i am trying to use an ISD1700 voice board to play one recorded message each time a PIR sensor is activated.I can get it working in button mode without any issues,and i understand i need to connect through MISO,MOSI,SCLK and SS pins for SPI mode.However i really need help with the code to get this to work as this is all new to me.I have already installed the ISD1700 library.
I miss a lot of info to help you further
  • code so far (both the working and the failing)
  • link to datasheet of sensor and shield
  • link to the library used
