Getting the following errors compiling a sketch for a DOIT ESP32 DEVKIT V1 board, and would like to ask for some help in figuring what is going on. This script will load on a Mega 2560 with these errors, but fails on the DOIT. Unfortunately, I have zero coding experience, and this is a steep learning curve.
The ESP32 is connected to a Megasquirt 3 ECU via canbus. It works as I've used a different script to send analog values to the MS3.
In file included from C:\Users\mr_sm\Documents\Arduino\broadcast_and_GPIOADC_tuotanto\broadcast_and_GPIOADC_tuotanto.ino:8:
c:\Users\mr_sm\Documents\Arduino\libraries\broadcast_and_GPIOADC_tuotanto/MBAmbientTemp.h:15:9: error: ISO C++ forbids declaration of 'init' with no type [-fpermissive]
15 | init(int inputPin, int measureCurrentPin);
In file included from C:\Users\mr_sm\Documents\Arduino\broadcast_and_GPIOADC_tuotanto\broadcast_and_GPIOADC_tuotanto.ino:15:
c:\Users\mr_sm\Documents\Arduino\libraries\broadcast_and_GPIOADC_tuotanto/MBOilPressure.h:17:9: error: ISO C++ forbids declaration of 'init' with no type [-fpermissive]
17 | init(int inputPin, int measureCurrentPin);
In file included from C:\Users\mr_sm\Documents\Arduino\broadcast_and_GPIOADC_tuotanto\broadcast_and_GPIOADC_tuotanto.ino:22:
c:\Users\mr_sm\Documents\Arduino\libraries\broadcast_and_GPIOADC_tuotanto/MBFuelAmount.h:16:9: error: ISO C++ forbids declaration of 'init' with no type [-fpermissive]
16 | init(int inputPin, int measureCurrentPin);
exit status 1
Compilation error: exit status 1
#include <SPI.h>
#include <mcp2515.h> //https://github.com/autowp/arduino-mcp2515
#include <MegaCAN.h> //https://github.com/mantonakakis1/MegaCAN
//Sensor libraries
//Ambient temperature
#include <MBAmbientTemp.h>
AmbientTemp AT;
#define AT_EXE_INTERVAL 200 // How often Ambient Temperature is measured (ms)
unsigned long ATlastExecutedMillis = 0; // Variable to save the last executed time
//Oil Pressure
#include <MBOilPressure.h>
OilPressure OP;
#define OP_EXE_INTERVAL 50 // How often Oil Pressure is measured (ms)
unsigned long OPlastExecutedMillis = 0; // Variable to save the last executed time
//Fuel Amount
#include <MBFuelAmount.h>
FuelAmount FA;
#define FA_EXE_INTERVAL 100 // How often Fuel Amount is measured (ms)
#define FW_EXE_INTERVAL 100 // How often Fuel Warning is measured (ms)
unsigned long FAlastExecutedMillis = 0; // Variable to save the last executed time
unsigned long FWlastExecutedMillis = 0; // Variable to save the last executed time
//MegaCAN
//#define CELSIUS // MegaCAN uses Fahrenheit, which is no good. This transforms broadcasted temperatures to Celsius
//MegaCAN
const uint32_t baseID = 1512; // Must set to match Megasquirt Settings!
const uint32_t finalID = baseID + 3; // Must set to match Megasquirt Settings configured in TunerStudio! The last group of data broadcasted.
//MCP2515 related
struct can_frame receivedFrame;
MCP2515 mcp2515(5); //CS at D10
MegaCAN MegaCAN; // For processed Megasquirt CAN protocol messages
MegaCAN_message_t recMsgMSC; // Stores received message from Megasquirt, Megasquirt CAN protocol
MegaCAN_message_t respMsgMSC; // Stores response message back to Megasquirt, Megasquirt CAN protocol
MegaCAN_broadcast_message_t bCastMsg; // Stores unpacked Megasquirt broadcast data, e.g. bCastMsg.rpm
struct can_frame respMsg; // Actual response message back to Megasquirt, MSCAN protocol
uint16_t GPIOADC[8] = { 0 }; // Stores values to send to Megasquirt, 4 ADCS for each message
uint16_t adc0 = 0;
uint16_t adc1 = 0;
uint16_t adc2 = 0;
uint16_t adc3 = 0;
uint16_t adc4 = 0;
uint16_t adc5 = 0;
uint16_t adc6 = 0;
uint16_t adc7 = 0;
//Variables for averaging of sensor values
//AT
const int ATnumReadings = 10;
int ATreadings[ATnumReadings]; // The readings from the analog input
int ATreadIndex = 0; // The index of the current reading
int ATtotal = 0; // The running total
int ATaverage = 0; // The average
//OP
const int OPnumReadings = 10;
int OPreadings[OPnumReadings]; // The readings from the analog input
int OPreadIndex = 0; // The index of the current reading
int OPtotal = 0; // The running total
int OPaverage = 0; // The average
//FA
const int FAnumReadings = 100;
int FAreadings[FAnumReadings]; // The readings from the analog input
int FAreadIndex = 0; // The index of the current reading
int FAtotal = 0; // The running total
int FAaverage = 0; // The average
//FW
const int FWnumReadings = 100;
int FWreadings[FWnumReadings]; // The readings from the input
int FWreadIndex = 0; // The index of the current reading
int FWtotal = 0; // The running total
int FWaverage = 0; // The average
void initializeCAN() {
mcp2515.reset();
mcp2515.setBitrate(CAN_500KBPS, MCP_8MHZ); //Megasquirt specific 500kbs
mcp2515.setNormalMode();
void canMShandler(const can_frame &msg) {
// For Megasquirt CAN protocol, MS is requesting data:
if ((msg.can_id & CAN_EFF_FLAG) != 0) { //Data request from MS uses extended flag, there may be a better way to implement this with more advanced applications, works fine for sending data to MS GPIOADC
sendDataToMS(msg); //Due to the extended flag, we assume this is a MS data request and run the function to send data to MS, passing the message received from MS to the sendDataToMS function
// For Megasquirt CAN broadcast data:
else { //Broadcast data from MS does not use extended flag, therefore a standard message from MS will contain broadcast data
//Unpack megasquirt broadcast data into bCastMsg:
MegaCAN.getBCastData(msg.can_id, msg.data, bCastMsg); //baseID fixed in library based on const parameter entered for baseID above - converts the raw CAN id and buf to bCastMsg format
if (msg.can_id == finalID) {
/*~~~Final message for this batch of data, do stuff with the data - this is a simple example~~~*/
Serial.print(bCastMsg.map); Serial.print(" | "); //should be kPa
Serial.print(bCastMsg.rpm); Serial.print(" | "); //should be rpm
Serial.println(bCastMsg.tps); //should be %
void sendDataToMS(can_frame msg) {
MegaCAN.processMSreq(msg.can_id, msg.data, recMsgMSC); // Unpack request message ("msg") from MS into recMsgMS
if (recMsgMSC.core.toOffset == 2) { //For GPIOADC0-3
GPIOADC[0] = adc0; //Ambient Temperature
GPIOADC[1] = adc1; //Oil Pressure
GPIOADC[2] = adc2; //Fuel Amount
GPIOADC[3] = adc3; //Fuel Warning. ADC is not the best solution for an on/off, but will do
MegaCAN.setMSresp(recMsgMSC, respMsgMSC, GPIOADC[0], GPIOADC[1], GPIOADC[2], GPIOADC[3]); //Packs the GPIOADC0-3 values into "respMsgMSC"
else if (recMsgMSC.core.toOffset == 10) { //For GPIOADC4-7
GPIOADC[4] = adc4; //vacant
GPIOADC[5] = adc5; //vacant
GPIOADC[6] = adc6; //vacant
GPIOADC[7] = adc7; //vacant
MegaCAN.setMSresp(recMsgMSC, respMsgMSC, GPIOADC[4], GPIOADC[5], GPIOADC[6], GPIOADC[7]); //Packs the GPIOADC4-7 values into "respMsgMSC"
// Send response to Megasquirt using MSCAN protocol:
respMsg.can_id = respMsgMSC.responseCore | CAN_EFF_FLAG; //CAN_EFF_FLAG added to the end of response message, otherwise MS will not use it
respMsg.can_dlc = sizeof(respMsgMSC.data.response);
for (int i = 0; i < respMsg.can_dlc; i++) {
respMsg.data[i] = respMsgMSC.data.response[i];
mcp2515.sendMessage(&respMsg); //Sends the GPIOADC values stored in respMsg over CAN to Mesasquirt
//Serial.println("Data sent to Megasquirt");
while (!Serial);
Serial.println("MAP | RPM | TPS");
initializeCAN();
pinMode(33, INPUT); //Fuel warning indicator switch
//Setup Ambient Temp readings
for (int ATthisReading = 0; ATthisReading < ATnumReadings; ATthisReading++) //As long as thisReading is smaller than numReadings, add to thisReading
ATreadings[ATthisReading] = 0;
AT.init(2,34); //Current from D34 and measuring voltage from A2
//Setup Oil Pressure readings
for (int OPthisReading = 0; OPthisReading < OPnumReadings; OPthisReading++) //As long as thisReading is smaller than numReadings, add to thisReading
OPreadings[OPthisReading] = 0;
OP.init(13,35); //Current from D35 and measuring voltage from A0
//Setup Fuel Amount readings
for (int FAthisReading = 0; FAthisReading < FAnumReadings; FAthisReading++) //As long as thisReading is smaller than numReadings, add to thisReading
FAreadings[FAthisReading] = 0;
FA.init(4,32); //Current from D32 and measuring voltage from A1
onReceived(); //Read messages from CAN-bus
getAT(); //Read Ambient Temperature and handle signal
getOP(); //Read Oil Pressure and handle signal
getFA(); //Read Fuel Amount and handle signal
getFW(); //Read Fuel Warning switch and handle signal
void onReceived()
//Listen to CAN-bus and run canMShandler after
if (mcp2515.readMessage(&receivedFrame) == MCP2515::ERROR_OK)
canMShandler(receivedFrame);
Serial.println("Received message:");
Serial.println(" ID: 0x" + String(receivedFrame.can_id, HEX));
Serial.println(" DLC: " + String(receivedFrame.can_dlc));
Serial.println(" Data: " + String(receivedFrame.data[0]) + " " +
String(receivedFrame.data[1]) + " " +
String(receivedFrame.data[2]) + " " +
String(receivedFrame.data[3]) + " " +
String(receivedFrame.data[4]) + " " +
String(receivedFrame.data[5]) + " " +
String(receivedFrame.data[6]) + " " +
String(receivedFrame.data[7]));
void getAT()
unsigned long ATcurrentMillis = millis(); // Record current time
if (ATcurrentMillis - ATlastExecutedMillis >= AT_EXE_INTERVAL) //If elapsed time from last execution is more than the specified interval
ATlastExecutedMillis = ATcurrentMillis; // save the last executed time
//AT
AT.measure(5,1024,10000,3007,3848,false); //float VCC,int _ADC, float R1, int R25, int Beta, bool prints
ATtotal = ATtotal - ATreadings[ATreadIndex]; // subtract the last reading
ATreadings[ATreadIndex] = AT.ambienttempvalue*10; // read from the sensor
ATtotal = ATtotal + ATreadings[ATreadIndex]; // add the reading to the total
ATreadIndex = ATreadIndex + 1; // advance to the next position in the array
if (ATreadIndex >= ATnumReadings) // if we're at the end of the array...
ATreadIndex = 0; // ...wrap around to the beginning
ATaverage = ATtotal / ATnumReadings; // calculate the average
adc0 = ATaverage; // Insert average to variable adc0
//Serial.println(adc0);
void getOP()
unsigned long OPcurrentMillis = millis(); // Record current time
if (OPcurrentMillis - OPlastExecutedMillis >= OP_EXE_INTERVAL) //If elapsed time from last execution is more than the specified interval
OPlastExecutedMillis = OPcurrentMillis; // save the last executed time
//OP
OP.measure(5,1024,100,10,69,129,184,false); //float VCC, int _ADC, float R1, int R_0BAR, int R_1BAR, int R_2BAR, int R_3BAR, bool prints
OPtotal = OPtotal - OPreadings[OPreadIndex]; // subtract the last reading
OPreadings[OPreadIndex] = OP.oilpressurevalue*100; // read from the sensor
OPtotal = OPtotal + OPreadings[OPreadIndex]; // add the reading to the total
OPreadIndex = OPreadIndex + 1; // advance to the next position in the array
if (OPreadIndex >= OPnumReadings) // if we're at the end of the array...
OPreadIndex = 0; // ...wrap around to the beginning:
OPaverage = OPtotal / OPnumReadings; // calculate the average
adc1 = OPaverage; // Insert average to variable adc1
//Serial.println(adc1);
void getFA()
unsigned long FAcurrentMillis = millis(); // Record current time
if (FAcurrentMillis - FAlastExecutedMillis >= FA_EXE_INTERVAL) //If elapsed time from last execution is more than the specified interval
FAlastExecutedMillis = FAcurrentMillis; // save the last executed time
//FA
FA.measure(5,1024,10,2,78,false); //float VCC,int _ADC, float R1, int R_Full, int R_Empty, bool prints
FAtotal = FAtotal - FAreadings[FAreadIndex]; // subtract the last reading
FAreadings[FAreadIndex] = FA.fuelamountvalue*100; // read from the sensor
FAtotal = FAtotal + FAreadings[FAreadIndex]; // add the reading to the total
FAreadIndex = FAreadIndex + 1; // advance to the next position in the array
if (FAreadIndex >= FAnumReadings) // if we're at the end of the array...
FAreadIndex = 0; // ...wrap around to the beginning
FAaverage = FAtotal / FAnumReadings; // calculate the average
adc2 = FAaverage; // Insert average to variable adc2
//Serial.println(adc2);
void getFW()
unsigned long FWcurrentMillis = millis(); // Record current time
if (FWcurrentMillis - FWlastExecutedMillis >= FW_EXE_INTERVAL) //If elapsed time from last execution is more than the specified interval
FWlastExecutedMillis = FWcurrentMillis; // save the last executed time
//FW
FWtotal = FWtotal - FWreadings[FWreadIndex]; // subtract the last reading
int sensorVal = digitalRead(33); // read port status:
if (sensorVal = LOW) // If the switch is closed...
FWreadings[FWreadIndex] = 1; //...reading is one
FWreadings[FWreadIndex] = 0; //...reading is zero
FWtotal = FWtotal + FWreadings[FWreadIndex]; // add the reading to the total
FWreadIndex = FWreadIndex + 100; // advance to the next position in the array
if (FWreadIndex >= FWnumReadings)
FWreadIndex = 0; // ...wrap around to the beginning
FWaverage = FWtotal / FWnumReadings; // calculate the average
adc3 = FWaverage; // Insert average to variable adc3
//Serial.println(adc3);
