iso error
hi can anyone explain why i am having this error
int segmentPin = {2,3,4,5,6,7,8,9};
int displayPin = {10,11,12};
byte One =
B01100000};
byte Two=
B10001010};
for (int i=0; i <8; i++)
pinMode(segmentPin*, OUTPUT);*
  • for (int i= 0; i <3; i++)*
    _ pinMode (displayPin*, OUTPUT);_
    _
    }*_
_ void loop()
* { displayOne();*
* void displayOne()*
* for(int count=0; count <8; count++)*
* for(int i=0; i<8; i++)*
{ digitalWrite (segmentPin*, LOW);
for (int i =0; i<3; i++)
digitalWrite(displayPin, HIGH);
for(int seg=0; seg<8; seg++)
int bit = (One[count] >> seg) & 1;
if (bit ==1)
digitalWrite(segmentPin[seg], HIGH);
}*_
[/quote]
error- name lookup of ‘count’ changed for new ISO ‘for’ scoping
fez016:
First off, I’d suggest cleaning up the indentation (Ctrl+T) in the Arduino IDE :).
The problem you have comes from the declaration of the count variable as a loop condition.
You declare “count” in the for loop:
Then, you use if after the for loop, in the next one:
        int bit = (One[       count      ] >> seg) & 1;
This is not technically allowed since count only exists within the confines of the first for loop.
You can do this to work around it (if that’s really your intent):
int count=0;
for(; count <8; count++)
Might I also point out that you have a crash bug in your code that you might want to be aware of:
This piece of code…
byte One[] = { B01100000 };
Declares an array of “byte” elements and initializes it to contain a single element with the value of B01100000.
Then later in this loop:
        if (bit ==1)
You access the 8th array element in the “One” array. This is a crash bug and probably not your intention.
Just FYI.
oh shoot!! thanks for the help. am sooo green in this :fearful:
