I'm using usb host shiled with webcam and I want to get picture from webcam on my esp32. I started the stream correctly. Set config to 1 -> set probe parameters -> get probe parameters -> set commit parameters -> set alt settigns and after that LED diode on my webcam start which means that enpoint is accesable by pipe (endpoint 2 , ep address 0x82) and the stream has started, right? After that I need to do isochronous-in transfter to endpoint 2 to get some data. I do the in transaction and it returns rcode = 0 which indicates success but RCVBC register has 0 writed in it and RCVFIFO register is empty. I dont know why max3421e wont start transfer after setting 0x42 in HXFR register, nothing happens. Why I get success when both registers are empty?
I solved the issue. Packet size constraint was problem. I didnt know some pakcets in iso transfer can be 0 length.
