Is there a way to create an environment where the projects are isolated from one another. It seems like I either have to run 1 project per computer or entirely delete the IDE and associated file to keep the projects from interfering with one another.
Or am I just missing something?
Perhaps missing something?
I have 19 ESP32's all programmed with the Arduino IDE all running independently. The projects have their own power sources.
For instance I have 2 ESP32's in abox sitting in the backyard monitoring the weather and tracking the sun; operating independently from the computer.
Thank you for the reply.
The issues are in the pre-2 Arduino IDE Currently 1.8.XX
The issues exist on Linux (Fedora 37, Kubuntu, and Slackware) and Windows 11.
The issues include
After downloading a project from Github, or other Vendor bought kit.
When it comes time to compile/upload to the arduino I get various errors.
Undeclared variables.
Invalid commandlines.
using the wrong library.
etc...
until I completely remove the environment and reinstall with only the specific libraries for that project.
Then it all works.
My solution so far is have 1 project per computer. when done wipe the IDE
completely and start again.
probably missing something simple?
Examples including links so people can try themselves ?
AFAIK there should never be a need to wipe the IDE.
@pert input needed.
Hi @dickisne . An easy way to get some level of isolation of the library dependencies is to use a dedicated sketchbook for each project. In addition to being a convenient location for storing your sketches, Arduino IDE installs libraries to the libraries
subfolder of the sketchbook. So the sketchbook is a significant part of the sketch's "environment".
You can easily change the location of the sketchbook folder by doing the following:
Select File > Preferences from the Arduino IDE menu.
Set the Sketchbook location preference to the folder where you would like to store the project's dedicated sketchbook.
Click the "OK " button.
If you want full isolation, you can have a dedicated installation of Arduino IDE for each project. This will cause the boards platform dependencies to be isolated in addition to the libraries.
This is done by using Arduino IDE 1.x in "portable" mode. You do that by creating a folder named portable
under each Arduino IDE installation folder. The next time you start the IDE, it will install all libraries and boards platforms inside that portable
folder instead of using the global locations as usual.
b707
April 3, 2023, 3:47pm
7
It seems an absolutely normal situation when you start a new project.
All of this usually can be fixed without of wiping IDe completely.
This are ordinar compiler errors, not more
It's by far the best solution if you want to keep projects separate. I'm working on a project for a friend for an Arduino Due where I need a far bigger serial buffer than the standard 128 bytes (unless I want to hack 3rd party libraries and analogRead() which is near impossible if one does not have the Due). So a portable install that will not interfere with standard installs where I can change the buffer size is my solution.
My guess is that the project examples don't match the most current updated library, or a library with that same name already existed but isn't the same.
Everyone has their own ideas, but I have used this technique for 12+ years and never an issue (yea, not normal.)
folder under C:\Users\me\Documents\Arduino\
folder named Ray_Sketches
folder structured by board architecture
subdirectories for project
nested subdirectories for various versions (latest is always highest #hardware
backup is just a Zip of one folder!
12 years of Arduino:
Folder PATH listing for volume Windows
Volume serial number is 0E47-5223
C:\USERS\BURNE\DOCUMENTS\ARDUINO\RAY_SKETCHES
+---1284P
¦ +---C64BASIC
¦ ¦ +---BACKUP
¦ ¦ +---_1284_6502
¦ +---Tests
¦ +---Blink_Count_Free
+---4Comparison
¦ +---BP180_GLCD_48
+---5ohBEE-2019-master
¦ +---helpers
¦ +---sketch
¦ +---five-oh-BEE
¦ +---hexdump
¦ +---HugQuest
¦ +---multi-chat
¦ +---multi-mode
¦ +---quest
¦ +---rssi
+---ATmega128RFA1
¦ +---SMART_20210727
¦ +---SMART_202107270A
¦ +---SMART_20210729
¦ +---SMART_202107290A
¦ +---SMART_202107290B
¦ +---SMART_20210730
¦ +---SMART_20210731
¦ +---SMART_20210801
¦ +---SMART_202108010A
¦ +---SMART_20210802
¦ +---SMART_20210803
+---BACKUP
¦ +---BlinkFAST
¦ +---IR_DS1307_Test
¦ +---OptiLoader
¦ +---PulseIn_Test
¦ +---Tiny85_Blink
¦ ¦ +---Tiny85_Blink_ino
¦ +---Uno_ISP
+---BluePill
¦ +---BlinkNcount3
¦ +---BlinkNcount_CDA
¦ +---Test_Blink
+---Demo
¦ +---Blink_Count
¦ +---Blink_Count_2
¦ +---Blink_Count_3
¦ +---FadingOnboard
¦ +---OneSecBlink
¦ +---PrimeNos
¦ +---StringEx_Parsing
¦ +---strtol_DecEquivalents
+---dfu-util
¦ +---.git
¦ ¦ +---branches
¦ ¦ +---hooks
¦ ¦ +---info
¦ ¦ +---logs
¦ ¦ ¦ +---refs
¦ ¦ ¦ +---heads
¦ ¦ ¦ +---remotes
¦ ¦ ¦ +---origin
¦ ¦ +---objects
¦ ¦ ¦ +---info
¦ ¦ ¦ +---pack
¦ ¦ +---refs
¦ ¦ +---heads
¦ ¦ +---remotes
¦ ¦ ¦ +---origin
¦ ¦ +---tags
¦ +---autom4te.cache
¦ +---device-logs
¦ +---doc
¦ +---m4
¦ +---msvc
¦ +---src
¦ ¦ +---.deps
¦ +---www
+---ESP32
¦ +---ADXL345_ILI9341
¦ +---ADXL345_test
¦ +---AWS_X509
¦ +---DualCore
¦ +---ESPNow
¦ ¦ +---Master
¦ ¦ +---Slave
¦ +---ESP_1Button
¦ +---graphicstest
¦ +---graphicstest_ILI9341_SWSPI_OK
¦ +---HTML_Render
¦ ¦ +---Modest
¦ ¦ +---devel
¦ ¦ ¦ +---osx
¦ ¦ ¦ +---Modest
¦ ¦ ¦ +---Modest.xcodeproj
¦ ¦ ¦ +---project.xcworkspace
¦ ¦ ¦ ¦ +---xcuserdata
¦ ¦ ¦ ¦ +---alexanderborisov.xcuserdatad
¦ ¦ ¦ +---xcdebugger
¦ ¦ ¦ +---xcschemes
¦ ¦ +---docs
¦ ¦ ¦ +---img
¦ ¦ ¦ +---stylesheets
¦ ¦ +---examples
¦ ¦ ¦ +---modest
¦ ¦ ¦ +---mycss
¦ ¦ ¦ +---myencoding
¦ ¦ ¦ +---myfont
¦ ¦ ¦ +---myhtml
¦ ¦ ¦ +---myurl
¦ ¦ +---include
¦ ¦ ¦ +---modest
¦ ¦ ¦ ¦ +---finder
¦ ¦ ¦ ¦ +---layer
¦ ¦ ¦ ¦ +---node
¦ ¦ ¦ ¦ +---render
¦ ¦ ¦ ¦ +---style
¦ ¦ ¦ +---mycore
¦ ¦ ¦ ¦ +---utils
¦ ¦ ¦ +---mycss
¦ ¦ ¦ ¦ +---declaration
¦ ¦ ¦ ¦ +---media
¦ ¦ ¦ ¦ +---namespace
¦ ¦ ¦ ¦ +---property
¦ ¦ ¦ ¦ +---selectors
¦ ¦ ¦ ¦ +---values
¦ ¦ ¦ +---myfont
¦ ¦ ¦ +---myhtml
¦ ¦ ¦ +---myunicode
¦ ¦ ¦ +---myurl
¦ ¦ +---source
¦ ¦ ¦ +---modest
¦ ¦ ¦ ¦ +---finder
¦ ¦ ¦ ¦ +---layer
¦ ¦ ¦ ¦ +---node
¦ ¦ ¦ ¦ +---render
¦ ¦ ¦ ¦ +---style
¦ ¦ ¦ +---mycore
¦ ¦ ¦ ¦ +---utils
¦ ¦ ¦ +---mycss
¦ ¦ ¦ ¦ +---media
¦ ¦ ¦ ¦ +---syntax
¦ ¦ ¦ ¦ +---values
¦ ¦ ¦ +---myfont
¦ ¦ ¦ +---myhtml
¦ ¦ ¦ +---myport
¦ ¦ ¦ ¦ +---posix
¦ ¦ ¦ ¦ ¦ +---mycore
¦ ¦ ¦ ¦ ¦ +---utils
¦ ¦ ¦ ¦ +---windows_nt
¦ ¦ ¦ ¦ +---mycore
¦ ¦ ¦ ¦ +---utils
¦ ¦ ¦ +---myunicode
¦ ¦ ¦ +---myurl
¦ ¦ +---test
¦ ¦ ¦ +---mycore
¦ ¦ ¦ ¦ +---data
¦ ¦ ¦ ¦ ¦ +---encoding
¦ ¦ ¦ ¦ +---utils
¦ ¦ ¦ +---mycss
¦ ¦ ¦ ¦ +---data
¦ ¦ ¦ ¦ +---data
¦ ¦ ¦ +---myhtml
¦ ¦ ¦ +---myurl
¦ ¦ ¦ +---data
¦ ¦ +---third_party
¦ ¦ ¦ +---font
¦ ¦ +---utils
¦ ¦ +---ext
¦ ¦ ¦ +---MyCSS
¦ ¦ ¦ +---MyHTML
¦ ¦ +---MyCSS
¦ ¦ ¦ +---data
¦ ¦ ¦ +---tmpl
¦ ¦ +---MyHTML
¦ ¦ +---tmpl
¦ ¦ +---encoding
¦ ¦ +---encoding_for_detector
¦ +---IBM_IoT
¦ ¦ +---ESP32BleBeacon
¦ ¦ +---ESP32BleGateway
¦ ¦ +---ESP8266HttpSecure
¦ ¦ +---ESP8266MqttSecure
¦ ¦ +---quickstart
¦ ¦ +---quickstartwifishield
¦ ¦ +---registered
¦ +---ILI9341
¦ ¦ +---All_Free_Fonts_Demo
¦ ¦ ¦ +---data
¦ ¦ +---DanM
¦ ¦ ¦ +---Adafruit_GFX_TFTSPI_042119
¦ ¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ ¦ +---mock_ili9341
¦ ¦ ¦ ¦ +---fontconvert
¦ ¦ ¦ ¦ +---Fonts
¦ ¦ ¦ +---Adafruit_ILI9341_050919
¦ ¦ ¦ ¦ +---.github
¦ ¦ ¦ ¦ +---breakouttouchpaint
¦ ¦ ¦ ¦ +---graphicstest
¦ ¦ ¦ ¦ +---graphicstest_featherwing
¦ ¦ ¦ ¦ +---graphicstest_pyportal
¦ ¦ ¦ ¦ +---mandelbrot
¦ ¦ ¦ ¦ +---onoffbutton
¦ ¦ ¦ ¦ +---onoffbutton_breakout
¦ ¦ ¦ ¦ +---pictureEmbed
¦ ¦ ¦ ¦ +---pyportal_boing
¦ ¦ ¦ ¦ +---touchpaint
¦ ¦ ¦ ¦ +---touchpaint_featherwing
¦ ¦ ¦ ¦ +---touchpaint_pyportal
¦ ¦ ¦ +---esp32_gfxtest9341
¦ ¦ ¦ +---esp32_gfxtest9341HWSPInotOK
¦ ¦ +---demo
¦ ¦ ¦ +---graphicstest_SWSPI_OK
¦ ¦ +---GitHub_Demo
¦ ¦ ¦ +---GitHub_Demo_ILI9341_SWSPI_OK
¦ ¦ +---ILI9341_Lib_Encapsulated
¦ ¦ ¦ +---ESP32_HSPI_ILI9341
¦ ¦ ¦ ¦ +---Fonts
¦ ¦ ¦ +---ESP32_H_V-SPI_ILI9341
¦ ¦ ¦ ¦ +---ESP32_H_V-SPI_ILI9341
¦ ¦ ¦ +---ESP32_H_V-SPI_ILI9341_notOK
¦ ¦ +---RLE_Font_test
¦ ¦ +---TFT_Clock
¦ ¦ +---TFT_Clock_Digital
¦ ¦ +---TFT_Clock_notOK
¦ ¦ +---TFT_Mandlebrot
¦ ¦ +---TFT_Matrix
¦ +---Korban_BLE
¦ +---Korban_Examples
¦ ¦ +---ESP32-Board-Test
¦ ¦ ¦ +---ESP32_GPIODiscovery
¦ ¦ ¦ +---ESP32_ModeTest
¦ ¦ ¦ +---ESP32_OLED_Demo
¦ ¦ +---ESP32-Deep-Sleep
¦ ¦ ¦ +---ExternalWakeUp_EXT0
¦ ¦ ¦ +---ExternalWakeUp_EXT1
¦ ¦ ¦ +---TimerWakeUp
¦ ¦ ¦ +---TouchWakeUp
¦ ¦ +---ESP32-Dual-Core
¦ ¦ ¦ +---Arduino_SpeedTest
¦ ¦ ¦ +---ESP32_MoveCore
¦ ¦ ¦ +---ESP32_ShowCore
¦ ¦ ¦ +---ESP32_SpeedTest
¦ ¦ ¦ +---ESP32_TwoTasks_Template
¦ ¦ ¦ +---ESP32_Two_LED_Asynchron
¦ ¦ ¦ +---ESP32_Two_LED_Synchron
¦ ¦ ¦ +---ESP32_WhichCore
¦ ¦ +---ESP8266-RTC-Memory
¦ ¦ ¦ +---ESPSensorHourlyEnhanced
¦ ¦ ¦ +---RTCmemTest
¦ ¦ +---LoRa
¦ ¦ ¦ +---Nodes
¦ ¦ ¦ +---Dragino
¦ ¦ ¦ ¦ +---HelloWorld
¦ ¦ ¦ +---TTN-Tester
¦ ¦ +---LoRa-Point-to-Point
¦ ¦ ¦ +---LoRaReceiver_MQTT
¦ ¦ ¦ +---LoRaSenderAltitude
¦ ¦ +---NeoGPS
¦ ¦ ¦ +---configs
¦ ¦ ¦ ¦ +---DTL
¦ ¦ ¦ ¦ +---Minimal
¦ ¦ ¦ ¦ +---Nominal
¦ ¦ ¦ +---doc
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---NMEA
¦ ¦ ¦ ¦ +---NMEAbenchmark
¦ ¦ ¦ ¦ +---NMEAblink
¦ ¦ ¦ ¦ +---NMEAcoherent
¦ ¦ ¦ ¦ +---NMEAfused
¦ ¦ ¦ ¦ +---NMEAtest
¦ ¦ ¦ ¦ +---PUBX
¦ ¦ ¦ ¦ +---ublox
¦ ¦ ¦ +---ublox
¦ ¦ +---NRF24L01-Bi-Directional-Communication
¦ ¦ +---NTPtimeESP
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---NTPtimeESP
¦ ¦ +---Scripts-for-my-videos
¦ ¦ +---Two-OLEDs-on-the-same-I2C-Bus
¦ +---LowPower_MQTT
¦ +---MultiLoop
¦ +---PrimeNos2
¦ +---RGB2_TSC3200
¦ +---RGB_TSC3200
¦ +---SimpleWiFiServer
¦ +---Sniff32
¦ +---Sniffing6
¦ +---Spoof_MAC
¦ +---StartCounter
¦ +---Three_Serial
¦ +---TouchInterrupt
¦ +---TouchRead
¦ +---WiFiClient
¦ +---WiFiClientBasic
¦ +---WiFiClientEvents
¦ +---WiFiClientSecure
¦ +---WiFiIPv6
¦ +---WiFiMulti
¦ +---WiFiScan
¦ +---WiFiSmartConfig
¦ +---WiFiUDPClient
¦ +---WIFI_SNIFFER_ESP32
+---ESP8266
¦ +---AccessPt
¦ +---AJAX
¦ +---BASIC
¦ ¦ +---ESP8266Basic
¦ ¦ +---Flasher
¦ +---Blink
¦ +---Blink01Pin2
¦ +---C64-ESP8266
¦ +---C64-ESP8266-OLED
¦ +---C64-ESP8266B
¦ +---CaptivePortal
¦ ¦ +---CaptivePortal
¦ ¦ +---CaptivePortal2
¦ ¦ +---CaptivePortalAdv
¦ ¦ +---DNSServer
¦ +---CaptivePortal1
¦ +---CaptivePortalAdvanced
¦ ¦ +---data
¦ +---Date_Time1
¦ +---Empty
¦ +---esp8266-C64
¦ +---ESP8266Forth
¦ ¦ +---ESP8266ForthLoader
¦ ¦ +---misc
¦ +---esp8266_python_wifi_topologist-master
¦ +---esp8266_web_ajax1
¦ +---ESP_WIFISCAN_OLED_ACQUIRE
¦ +---Examples
¦ ¦ +---BlinkNcount
¦ ¦ +---BlinkNcount_160
¦ ¦ +---BlinkNcount_noRF
¦ ¦ +---PrimeNos
¦ ¦ +---PrimeNos2
¦ ¦ +---PrimeNos_IRAM
¦ ¦ +---PrimeNos_noRF
¦ ¦ +---Serial_Test
¦ ¦ +---strol_DecEquivalents
¦ +---Forum
¦ ¦ +---Adafruit OLED Badge
¦ ¦ +---Adafruit_OLED-128x32
¦ ¦ +---Adafruit_TestScript
¦ ¦ +---Ajax
¦ ¦ ¦ +---data
¦ ¦ +---arduinoWebSockets
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---WebSocketClient
¦ ¦ ¦ ¦ +---WebSocketClientAVR
¦ ¦ ¦ ¦ +---WebSocketClientSSL
¦ ¦ ¦ ¦ +---WebSocketServer
¦ ¦ ¦ ¦ +---WebSocketServer_LEDcontrol
¦ ¦ ¦ +---src
¦ ¦ ¦ ¦ +---libb64
¦ ¦ ¦ ¦ +---libsha1
¦ ¦ ¦ +---tests
¦ ¦ ¦ +---webSocketServer
¦ ¦ +---Basic-master
¦ ¦ ¦ +---ESP8266Basic
¦ ¦ ¦ +---Flasher
¦ ¦ ¦ +---Build
¦ ¦ ¦ +---1M
¦ ¦ ¦ +---2M
¦ ¦ ¦ +---4M
¦ ¦ ¦ +---512k
¦ ¦ +---BeaconJam
¦ ¦ +---BENCHMARK
¦ ¦ ¦ +---dhry21a
¦ ¦ ¦ +---dhry21b
¦ ¦ +---DHT11_MQTT
¦ ¦ ¦ +---DHT11_MQTT
¦ ¦ +---Display_AP-JS
¦ ¦ ¦ +---data
¦ ¦ +---easyMesh
¦ ¦ ¦ +---.github
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---demoToy
¦ ¦ ¦ ¦ ¦ +---data
¦ ¦ ¦ ¦ +---IndentedPrintExample
¦ ¦ ¦ ¦ +---JsonGeneratorExample
¦ ¦ ¦ ¦ +---JsonHttpClient
¦ ¦ ¦ ¦ +---JsonParserExample
¦ ¦ ¦ ¦ +---JsonServer
¦ ¦ ¦ ¦ +---JsonUdpBeacon
¦ ¦ ¦ ¦ +---SimpleList_delete_while_iterating_example
¦ ¦ ¦ ¦ +---SimpleList_pre-reserve_memory_usage_and_comparation
¦ ¦ ¦ ¦ +---SimpleList_store_ints_example
¦ ¦ ¦ ¦ +---startHere
¦ ¦ ¦ +---include
¦ ¦ ¦ ¦ +---ArduinoJson
¦ ¦ ¦ ¦ +---Internals
¦ ¦ ¦ ¦ +---Polyfills
¦ ¦ ¦ ¦ +---TypeTraits
¦ ¦ ¦ +---scripts
¦ ¦ ¦ ¦ +---travis
¦ ¦ ¦ +---src
¦ ¦ ¦ +---test
¦ ¦ ¦ +---third-party
¦ ¦ ¦ +---cpplint
¦ ¦ ¦ +---gtest-1.7.0
¦ ¦ ¦ +---build-aux
¦ ¦ ¦ +---cmake
¦ ¦ ¦ +---codegear
¦ ¦ ¦ +---fused-src
¦ ¦ ¦ ¦ +---gtest
¦ ¦ ¦ +---include
¦ ¦ ¦ ¦ +---gtest
¦ ¦ ¦ ¦ +---internal
¦ ¦ ¦ +---m4
¦ ¦ ¦ +---make
¦ ¦ ¦ +---msvc
¦ ¦ ¦ +---samples
¦ ¦ ¦ +---scripts
¦ ¦ ¦ ¦ +---test
¦ ¦ ¦ +---src
¦ ¦ ¦ +---test
¦ ¦ ¦ +---xcode
¦ ¦ ¦ +---Config
¦ ¦ ¦ +---gtest.xcodeproj
¦ ¦ ¦ +---Resources
¦ ¦ ¦ +---Samples
¦ ¦ ¦ ¦ +---FrameworkSample
¦ ¦ ¦ ¦ +---WidgetFramework.xcodeproj
¦ ¦ ¦ +---Scripts
¦ ¦ +---ESP2ESP
¦ ¦ +---ESP_T_TRACKER
¦ ¦ +---ESP_WiFiSwitch
¦ ¦ ¦ +---BUILD
¦ ¦ ¦ +---ElectronicDesignAutomation
¦ ¦ ¦ ¦ +---Gerber
¦ ¦ ¦ +---other
¦ ¦ +---FTP_SPIFFS
¦ ¦ ¦ +---esp8266FTPServer
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---FTPServerSample
¦ ¦ +---IOT
¦ ¦ ¦ +---Day10_TCPWeatherUpdate
¦ ¦ ¦ +---Day11_TCPServer
¦ ¦ ¦ +---Day12_TCPServerLed
¦ ¦ ¦ +---Day13_TCPServerProgmen
¦ ¦ ¦ +---Day14_TCPServerRGB
¦ ¦ ¦ +---Day15_TCPServerBright
¦ ¦ ¦ +---Day16_TCPServerGPIO
¦ ¦ ¦ +---Day17_IRmodul
¦ ¦ ¦ ¦ +---libraries
¦ ¦ ¦ ¦ +---IRremote
¦ ¦ ¦ ¦ +---IRrecord
¦ ¦ ¦ ¦ +---IRrecvDemo
¦ ¦ ¦ ¦ +---IRrecvDump
¦ ¦ ¦ ¦ +---IRrelay
¦ ¦ ¦ ¦ +---IRsendDemo
¦ ¦ ¦ ¦ +---IRtest
¦ ¦ ¦ ¦ +---IRtest2
¦ ¦ ¦ ¦ +---JVCPanasonicSendDemo
¦ ¦ ¦ +---Day18_IrRemote
¦ ¦ ¦ ¦ +---IRrelay
¦ ¦ ¦ ¦ +---IRtest
¦ ¦ ¦ ¦ +---IRtest2
¦ ¦ ¦ +---Day19_ThinkSpeak1
¦ ¦ ¦ +---Day1_SoftwareSerial
¦ ¦ ¦ +---Day20_ThinkSpeakTwitch
¦ ¦ ¦ +---Day21_ThinkSpeakAlarm
¦ ¦ ¦ +---Day22_ThinkSpeakTalkback
¦ ¦ ¦ +---Day23_CheerLights
¦ ¦ ¦ ¦ +---RGBLED
¦ ¦ ¦ ¦ +---SetAndFade
¦ ¦ ¦ +---Day24_Christmas
¦ ¦ ¦ ¦ +---RGBLED
¦ ¦ ¦ +---Day2_GooglePing
¦ ¦ ¦ +---Day3_UPDBasics
¦ ¦ ¦ +---Day4_UDPBidirectional
¦ ¦ ¦ +---Day5_UDPLED
¦ ¦ ¦ +---Day6_UDPSwitch
¦ ¦ ¦ +---Day7_UDPAnalog
¦ ¦ ¦ +---Day8_TCPBrowser
¦ ¦ ¦ +---Day9_TCPAutoTime
¦ ¦ ¦ +---libraries
¦ ¦ ¦ +---Time
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---Processing
¦ ¦ ¦ ¦ +---SyncArduinoClock
¦ ¦ ¦ +---TimeArduinoDue
¦ ¦ ¦ +---TimeGPS
¦ ¦ ¦ +---TimeNTP
¦ ¦ ¦ +---TimeRTC
¦ ¦ ¦ +---TimeRTCLog
¦ ¦ ¦ +---TimeRTCSet
¦ ¦ ¦ +---TimeSerial
¦ ¦ ¦ +---TimeSerialDateStrings
¦ ¦ ¦ +---TimeTeensy3
¦ ¦ +---IO_Socket
¦ ¦ +---JimmyJammer
¦ ¦ +---LCD128x128
¦ ¦ ¦ +---example
¦ ¦ ¦ ¦ +---Graphic
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---avr_benchmark
¦ ¦ ¦ ¦ +---basicSetup
¦ ¦ ¦ ¦ +---Benchmark
¦ ¦ ¦ ¦ +---Benchmarks_Alternative
¦ ¦ ¦ ¦ +---benchmark_multipleDisp
¦ ¦ ¦ ¦ +---benchmark_version2
¦ ¦ ¦ ¦ +---bigtest
¦ ¦ ¦ ¦ +---bubbles
¦ ¦ ¦ ¦ +---changeMode
¦ ¦ ¦ ¦ +---char_remap_example
¦ ¦ ¦ ¦ +---Clock_example
¦ ¦ ¦ ¦ +---ColorMood_example
¦ ¦ ¦ ¦ +---doubleDisplay_bars
¦ ¦ ¦ ¦ +---double_display_test
¦ ¦ ¦ ¦ +---drawLineAngle_example
¦ ¦ ¦ ¦ +---externalFonts
¦ ¦ ¦ ¦ +---icon_inverse
¦ ¦ ¦ ¦ +---icon_simple
¦ ¦ ¦ ¦ +---icon_simple2
¦ ¦ ¦ ¦ +---image_background
¦ ¦ ¦ ¦ +---image_batman
¦ ¦ ¦ ¦ +---image_eyeAnimation
¦ ¦ ¦ ¦ +---image_simple
¦ ¦ ¦ ¦ +---image_simple2
¦ ¦ ¦ ¦ +---partial_mode_example
¦ ¦ ¦ ¦ +---ringMeterExample
¦ ¦ ¦ ¦ +---roundGaugeWithBallistic
¦ ¦ ¦ ¦ +---SD_example
¦ ¦ ¦ ¦ +---sleep_example
¦ ¦ ¦ ¦ +---Solid3D_example
¦ ¦ ¦ ¦ +---SomeBars_example
¦ ¦ ¦ ¦ +---teensy_Fourier_Transform_TFT
¦ ¦ ¦ ¦ +---textCentering
¦ ¦ ¦ ¦ +---vertical_Gauges
¦ ¦ ¦ ¦ +---_ESP8266
¦ ¦ ¦ ¦ +---ringMeter_test
¦ ¦ ¦ ¦ +---WiFi_scan
¦ ¦ ¦ +---_display
¦ ¦ ¦ +---_fonts
¦ ¦ ¦ +---_icons
¦ ¦ ¦ +---_images
¦ ¦ ¦ ¦ +---eye
¦ ¦ ¦ +---_includes
¦ ¦ ¦ +---_settings
¦ ¦ ¦ +---_utility
¦ ¦ ¦ +---for_LCD_Font_Converter
¦ ¦ ¦ +---ConverterPreset
¦ ¦ ¦ +---FontFiles
¦ ¦ +---lightclockwifi
¦ ¦ ¦ +---druhvhtml
¦ ¦ ¦ ¦ +---compressed
¦ ¦ ¦ ¦ +---Menu
¦ ¦ ¦ +---lightclock
¦ ¦ +---LowPower_test
¦ ¦ +---Metadata
¦ ¦ +---Moving_Data
¦ ¦ +---MPU6050
¦ ¦ ¦ +---Examples
¦ ¦ ¦ +---MPU6050_DMP6
¦ ¦ ¦ ¦ +---Processing
¦ ¦ ¦ ¦ +---MPUTeapot
¦ ¦ ¦ +---MPU6050_raw
¦ ¦ +---MQTT_Examples
¦ ¦ ¦ +---MQTT_DHT22
¦ ¦ ¦ +---MQTT_On-Off
¦ ¦ ¦ +---MQTT_Relay-Button
¦ ¦ +---Multiple_AP_AddressConflict
¦ ¦ +---MyWiFiServer
¦ ¦ ¦ +---data
¦ ¦ ¦ +---contact
¦ ¦ ¦ +---images
¦ ¦ ¦ +---links
¦ ¦ ¦ +---photos
¦ ¦ +---OSC
¦ ¦ ¦ +---Receive
¦ ¦ ¦ +---To_SLIP
¦ ¦ +---SD_Card_WebServer
¦ ¦ +---Sliders
¦ ¦ +---SPIFFS
¦ ¦ +---SPIFFS_Server
¦ ¦ +---SSL_Example
¦ ¦ +---TakeOne_C_S
¦ ¦ ¦ +---TakeOneClient
¦ ¦ ¦ +---TakeOneServer
¦ ¦ +---Telnet
¦ ¦ +---Text_I2C_1602LCD
¦ ¦ +---TheDudeTemp
¦ ¦ +---Thingspeak
¦ ¦ +---TLC5615_DAC
¦ ¦ +---Toggle_BatteryV
¦ ¦ +---Twitter
¦ ¦ +---TwoWayComm
¦ ¦ ¦ +---First
¦ ¦ ¦ +---Second
¦ ¦ +---UdpClientServer
¦ ¦ +---UDP_SerialBridge
¦ ¦ +---WakeUp_test1
¦ ¦ +---WeatherDisplay
¦ ¦ ¦ +---3d
¦ ¦ ¦ +---pictures
¦ ¦ +---webserver2
¦ ¦ +---WebSocket-Scope
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---src
¦ ¦ ¦ ¦ +---libb64
¦ ¦ ¦ ¦ +---libsha1
¦ ¦ ¦ +---tests
¦ ¦ +---WebSocketNetwork
¦ ¦ +---WebSocket_AP
¦ ¦ +---WebSocket_Multi
¦ ¦ +---WiFi_Progmem
¦ +---GPS_Portal
¦ +---LCD_I2C
¦ +---New_AtoI
¦ +---NOT-tested
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---graphicstest_esp8266
¦ ¦ ¦ +---spitftbitmap
¦ ¦ +---AdjustDelayAfterWake
¦ ¦ +---AJAX
¦ ¦ ¦ +---ajaxxml
¦ ¦ ¦ +---ajaxxml2
¦ ¦ +---arduino_6502
¦ ¦ +---aREST-master
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---BLE
¦ ¦ ¦ ¦ +---ESP8266
¦ ¦ ¦ ¦ +---Ethernet
¦ ¦ ¦ ¦ +---Serial
¦ ¦ ¦ ¦ +---WiFi
¦ ¦ ¦ ¦ +---WiFi_CC3000
¦ ¦ ¦ ¦ +---WiFi_CC3000_Due
¦ ¦ ¦ ¦ +---Yun
¦ ¦ ¦ +---test
¦ ¦ +---BMP085_DHT_Server
¦ ¦ +---BMP18-_Ajax
¦ ¦ +---BMP180
¦ ¦ +---BMP180_2
¦ ¦ +---BMP_180_2
¦ ¦ +---ClientServer
¦ ¦ ¦ +---Client
¦ ¦ ¦ +---Server
¦ ¦ +---Conways_OLED
¦ ¦ +---C_D_LCD
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---HelloServerSPI
¦ ¦ ¦ +---LCD_graphicstest
¦ ¦ +---DHT-sensor-library-master
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---DHTtester
¦ ¦ +---DHT11-prototype
¦ ¦ +---DHT11_WiFi
¦ ¦ +---DHT22_Gauges
¦ ¦ ¦ +---data
¦ ¦ +---DHT_Portal-Server
¦ ¦ +---DS18B20_Temp
¦ ¦ +---EEPROM
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---eeprom_clear
¦ ¦ ¦ +---eeprom_read
¦ ¦ ¦ +---eeprom_write
¦ ¦ +---Email_smtp_ESR8266
¦ ¦ +---esp-pcd-weather
¦ ¦ ¦ +---photos
¦ ¦ +---ESP8266-RTC-Memory-master
¦ ¦ +---ESP8266-WeatherSensor
¦ ¦ +---ESP8266COM
¦ ¦ ¦ +---Arduino_OTA
¦ ¦ ¦ +---BufferedPrint
¦ ¦ ¦ +---Client-Server
¦ ¦ ¦ +---C_D_LCD-master
¦ ¦ ¦ ¦ +---HelloServerSPI
¦ ¦ ¦ ¦ +---LCD_graphicstest
¦ ¦ ¦ +---Date_Time
¦ ¦ ¦ +---Deactivate_Client
¦ ¦ ¦ +---DeepSleepReset
¦ ¦ ¦ +---Email_smtp_ESR8266
¦ ¦ ¦ +---ESP_Interrupts
¦ ¦ ¦ +---ESP_TH_Logger
¦ ¦ ¦ +---Ex5_UDPSvr
¦ ¦ ¦ +---Example1
¦ ¦ ¦ +---Example2
¦ ¦ ¦ +---Example3
¦ ¦ ¦ +---Example4a
¦ ¦ ¦ +---Example4b
¦ ¦ ¦ +---GarageDoor1
¦ ¦ ¦ +---GarageDoor2
¦ ¦ ¦ +---GenFaultTextEmail
¦ ¦ ¦ +---Max7219
¦ ¦ ¦ +---MLX90614
¦ ¦ ¦ +---MQTT_MessageCenter
¦ ¦ ¦ +---MQTT_PubSub1
¦ ¦ ¦ +---MQTT_PubSub2
¦ ¦ ¦ +---NMEA2Server
¦ ¦ ¦ +---PubSub_DHT
¦ ¦ ¦ +---Read33Battery
¦ ¦ ¦ +---Read33Battery2
¦ ¦ ¦ +---Read33Battery3
¦ ¦ ¦ +---RTC_MemoryWrite
¦ ¦ ¦ +---Sketch_Buffet
¦ ¦ ¦ +---Static_IP
¦ ¦ ¦ +---ThingSpeak
¦ ¦ ¦ +---Tweet2ThingsSpeak
¦ ¦ ¦ +---UdpClientServer
¦ ¦ ¦ +---UDPmulticast
¦ ¦ ¦ +---UDPwithReturn
¦ ¦ ¦ +---WebServer
¦ ¦ ¦ +---WebServer_2
¦ ¦ ¦ +---WiFi_EEPROM
¦ ¦ +---ESP8266mDNS
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---mDNS_Web_Server
¦ ¦ +---ESP8266SDK2
¦ ¦ +---ESP8266WebServer
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---AdvancedWebServer
¦ ¦ ¦ ¦ +---SDWebServer
¦ ¦ ¦ ¦ +---SdRoot
¦ ¦ ¦ ¦ +---edit
¦ ¦ ¦ +---src
¦ ¦ +---ESP8266WiFi
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---NTPClient
¦ ¦ ¦ ¦ +---WiFiAccessPoint
¦ ¦ ¦ ¦ +---WiFiClient
¦ ¦ ¦ ¦ +---WiFiMulti
¦ ¦ ¦ ¦ +---WiFiScan
¦ ¦ ¦ ¦ +---WiFiTelnetToSerial
¦ ¦ ¦ ¦ +---WiFiWebServer
¦ ¦ ¦ +---src
¦ ¦ ¦ +---arch
¦ ¦ ¦ +---include
¦ ¦ ¦ +---lwip
¦ ¦ +---ESP8266_BASIC_INTERPERTERV2
¦ ¦ +---ESP8266_Blink
¦ ¦ +---esp8266_time
¦ ¦ +---ESP8266_Ubidots
¦ ¦ +---ESP_interrupt2
¦ ¦ +---ESP_MQTT_12_NETCHECK_FORUM
¦ ¦ +---ESP_SSD1306-master
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---ESP_ssd1306_128x64_SPI
¦ ¦ +---ESP_WebConfig
¦ ¦ +---ESP_WiFiScan_OLED_2
¦ ¦ +---Ethernet_Address_Formatting
¦ ¦ +---FlashSize
¦ ¦ +---FSBrowser
¦ ¦ ¦ +---data
¦ ¦ +---FSwebBrowser
¦ ¦ +---FTP_Passive
¦ ¦ ¦ +---data
¦ ¦ +---GameOfLife
¦ ¦ +---Google_Time
¦ ¦ +---GPS-OLED_SVR
¦ ¦ +---Hash
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---src
¦ ¦ ¦ +---sha1
¦ ¦ +---HelloServerTest
¦ ¦ +---HomeWater
¦ ¦ +---ILI9341+Touch
¦ ¦ ¦ +---ApplyThisDiff
¦ ¦ ¦ +---ili9341_arduino
¦ ¦ ¦ ¦ +---drawCircle
¦ ¦ ¦ ¦ +---drawLines
¦ ¦ ¦ ¦ +---drawNumber
¦ ¦ ¦ ¦ +---drawRectangle
¦ ¦ ¦ ¦ +---paint
¦ ¦ ¦ ¦ +---shapes
¦ ¦ ¦ ¦ +---text
¦ ¦ ¦ ¦ +---tftbmp
¦ ¦ ¦ +---SDWebServer_GPIO16_Touchn4b
¦ ¦ ¦ +---SDWebServer_GPIO16_Touchn5b
¦ ¦ ¦ +---TFT_Touch_Shield_V2
¦ ¦ ¦ ¦ +---paint
¦ ¦ ¦ ¦ +---shapes
¦ ¦ ¦ ¦ +---text
¦ ¦ ¦ ¦ +---tftbmp
¦ ¦ ¦ ¦ +---tftbmp2
¦ ¦ ¦ +---ucglib-master
¦ ¦ ¦ ¦ +---cppsrc
¦ ¦ ¦ ¦ +---cppsrc_sdspi
¦ ¦ ¦ ¦ +---csrc
¦ ¦ ¦ ¦ +---sys
¦ ¦ ¦ ¦ ¦ +---arduino
¦ ¦ ¦ ¦ ¦ ¦ +---Box3D
¦ ¦ ¦ ¦ ¦ ¦ +---ClipTest
¦ ¦ ¦ ¦ ¦ ¦ +---FPS
¦ ¦ ¦ ¦ ¦ ¦ +---GraphicsTest
¦ ¦ ¦ ¦ ¦ ¦ +---HelloWorld
¦ ¦ ¦ ¦ ¦ ¦ +---HowToUseFonts
¦ ¦ ¦ ¦ ¦ ¦ +---issue_30
¦ ¦ ¦ ¦ ¦ ¦ +---PowerDown
¦ ¦ ¦ ¦ ¦ ¦ +---Scale
¦ ¦ ¦ ¦ ¦ ¦ +---ShowTGA
¦ ¦ ¦ ¦ ¦ ¦ +---sw_spi_test
¦ ¦ ¦ ¦ ¦ ¦ +---test
¦ ¦ ¦ ¦ ¦ ¦ +---UcgLogo
¦ ¦ ¦ ¦ ¦ +---sdl
¦ ¦ ¦ ¦ ¦ ¦ +---dev
¦ ¦ ¦ ¦ ¦ ¦ +---show_tga
¦ ¦ ¦ ¦ ¦ ¦ +---test_disk
¦ ¦ ¦ ¦ ¦ ¦ +---test_font
¦ ¦ ¦ ¦ ¦ ¦ +---test_font_rotate
¦ ¦ ¦ ¦ ¦ ¦ +---test_rotate
¦ ¦ ¦ ¦ ¦ ¦ +---test_scale
¦ ¦ ¦ ¦ ¦ ¦ +---ucglib_logo
¦ ¦ ¦ ¦ ¦ +---stdout
¦ ¦ ¦ ¦ ¦ ¦ +---com
¦ ¦ ¦ ¦ ¦ +---tga
¦ ¦ ¦ ¦ ¦ +---dev
¦ ¦ ¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ ¦ +---font_array
¦ ¦ ¦ ¦ ¦ +---font_overview
¦ ¦ ¦ ¦ ¦ +---test
¦ ¦ ¦ ¦ +---tools
¦ ¦ ¦ ¦ +---font
¦ ¦ ¦ ¦ ¦ +---bdf
¦ ¦ ¦ ¦ ¦ +---bdf2ucg
¦ ¦ ¦ ¦ ¦ +---bdf2ucg_obsolete
¦ ¦ ¦ ¦ ¦ +---bdfconv
¦ ¦ ¦ ¦ ¦ +---build
¦ ¦ ¦ ¦ ¦ +---otf2bdf
¦ ¦ ¦ ¦ ¦ ¦ +---maps
¦ ¦ ¦ ¦ ¦ +---pixel
¦ ¦ ¦ ¦ ¦ +---ttf
¦ ¦ ¦ ¦ ¦ ¦ +---fu
¦ ¦ ¦ ¦ ¦ ¦ +---gp
¦ ¦ ¦ ¦ ¦ ¦ +---log
¦ ¦ ¦ ¦ ¦ ¦ +---os
¦ ¦ ¦ ¦ ¦ ¦ +---pixel
¦ ¦ ¦ ¦ ¦ +---ttfbdfupdate
¦ ¦ ¦ ¦ +---linear
¦ ¦ ¦ ¦ +---release
¦ ¦ ¦ ¦ +---arduino
¦ ¦ ¦ ¦ +---arduino_new_lib_format
¦ ¦ ¦ +---XPT2046-master
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---XPTCalibrate
¦ ¦ ¦ +---XPTPaint
¦ ¦ +---IoT_PlayGround
¦ ¦ ¦ +---ESP8266ArduinoIDE
¦ ¦ ¦ ¦ +---Blink
¦ ¦ ¦ ¦ +---DS18B20_temperature_sensor
¦ ¦ ¦ ¦ +---ESP8266_di
¦ ¦ ¦ +---external_libraries
¦ ¦ ¦ ¦ +---DHT
¦ ¦ ¦ ¦ ¦ +---DHT_Test
¦ ¦ ¦ ¦ +---DS1302RTC
¦ ¦ ¦ ¦ ¦ +---DS1302_LCD
¦ ¦ ¦ ¦ ¦ +---DS1302_RAM_Demo
¦ ¦ ¦ ¦ ¦ +---DS1302_Serial
¦ ¦ ¦ ¦ ¦ +---SetSerial
¦ ¦ ¦ ¦ +---HTU21D_Humidity
¦ ¦ ¦ ¦ ¦ +---Humidity
¦ ¦ ¦ ¦ +---Irrigation
¦ ¦ ¦ ¦ +---MySensors
¦ ¦ ¦ ¦ ¦ ¦ +---AirQualitySensor
¦ ¦ ¦ ¦ ¦ ¦ +---BatteryPoweredSensor
¦ ¦ ¦ ¦ ¦ ¦ +---BinarySwitchSensor
¦ ¦ ¦ ¦ ¦ ¦ +---BinarySwitchSleepSensor
¦ ¦ ¦ ¦ ¦ ¦ +---ClearEepromConfig
¦ ¦ ¦ ¦ ¦ ¦ +---DallasTemperatureSensor
¦ ¦ ¦ ¦ ¦ ¦ +---DimmableLEDActuator
¦ ¦ ¦ ¦ ¦ ¦ +---DistanceSensor
¦ ¦ ¦ ¦ ¦ ¦ +---DustSensor
¦ ¦ ¦ ¦ ¦ ¦ +---EnergyMeterPulseSensor
¦ ¦ ¦ ¦ ¦ ¦ +---EthernetGateway
¦ ¦ ¦ ¦ ¦ ¦ +---HumiditySensor
¦ ¦ ¦ ¦ ¦ ¦ +---IrSensor
¦ ¦ ¦ ¦ ¦ ¦ +---LightLuxSensor
¦ ¦ ¦ ¦ ¦ ¦ +---LightSensor
¦ ¦ ¦ ¦ ¦ ¦ +---MotionSensor
¦ ¦ ¦ ¦ ¦ ¦ +---MQTTGateway
¦ ¦ ¦ ¦ ¦ ¦ +---PressureSensor
¦ ¦ ¦ ¦ ¦ ¦ +---RealTimeClockDisplaySensor
¦ ¦ ¦ ¦ ¦ ¦ +---RelayActuator
¦ ¦ ¦ ¦ ¦ ¦ +---RelayWithButtonActuator
¦ ¦ ¦ ¦ ¦ ¦ +---RepeaterNode
¦ ¦ ¦ ¦ ¦ ¦ +---RF433MhzSensor
¦ ¦ ¦ ¦ ¦ ¦ +---RFIDLockSensor
¦ ¦ ¦ ¦ ¦ ¦ +---SecretKnockSensor
¦ ¦ ¦ ¦ ¦ ¦ +---SerialGateway
¦ ¦ ¦ ¦ ¦ ¦ +---ServoActuator
¦ ¦ ¦ ¦ ¦ ¦ +---SoilMoistSensor
¦ ¦ ¦ ¦ ¦ ¦ +---TimeAwareSensor
¦ ¦ ¦ ¦ ¦ ¦ +---TouchDisplaySceneControllerSensor
¦ ¦ ¦ ¦ ¦ ¦ +---UVSensor
¦ ¦ ¦ ¦ ¦ ¦ +---WaterMeterPulseSensor
¦ ¦ ¦ ¦ ¦ +---utility
¦ ¦ ¦ ¦ +---SFE_BMP180
¦ ¦ ¦ ¦ ¦ +---BMP180_altitude_example
¦ ¦ ¦ ¦ ¦ +---SFE_BMP180_example
¦ ¦ ¦ ¦ +---Timezone
¦ ¦ ¦ ¦ ¦ +---Clock
¦ ¦ ¦ ¦ ¦ +---HardwareRTC
¦ ¦ ¦ ¦ ¦ +---WorldClock
¦ ¦ ¦ ¦ ¦ +---WriteRules
¦ ¦ ¦ ¦ +---UTFT
¦ ¦ ¦ ¦ ¦ ¦ +---Arduino (ARM) + Teensy
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Bitmap
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Bitmap_128x128
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_CPLD_PageSwitching
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_128x128_Serial
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_160x128_Serial
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_220x176
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_220x176_Serial
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_320x240
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_320x240_Serial
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_400x240
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_480x272
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_480x320
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Demo_800x480
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Rotate_Bitmap
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Textrotation_Demo
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_ViewFont
¦ ¦ ¦ ¦ ¦ ¦ +---Arduino (AVR)
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---UTFT_Leonardo_Demo_320x240
¦ ¦ ¦ ¦ ¦ ¦ +---chipKit
¦ ¦ ¦ ¦ ¦ +---hardware
¦ ¦ ¦ ¦ ¦ ¦ +---arm
¦ ¦ ¦ ¦ ¦ ¦ +---avr
¦ ¦ ¦ ¦ ¦ ¦ +---pic32
¦ ¦ ¦ ¦ ¦ +---tft_drivers
¦ ¦ ¦ ¦ ¦ ¦ +---cpld
¦ ¦ ¦ ¦ ¦ ¦ +---hx8340b
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---8
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---s
¦ ¦ ¦ ¦ ¦ ¦ +---hx8347a
¦ ¦ ¦ ¦ ¦ ¦ +---hx8352a
¦ ¦ ¦ ¦ ¦ ¦ +---hx8353c
¦ ¦ ¦ ¦ ¦ ¦ +---ili9320
¦ ¦ ¦ ¦ ¦ ¦ +---ili9325c
¦ ¦ ¦ ¦ ¦ ¦ +---ili9325d
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---alt
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---default
¦ ¦ ¦ ¦ ¦ ¦ +---ili9327
¦ ¦ ¦ ¦ ¦ ¦ +---ili9341
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---s4p
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---s5p
¦ ¦ ¦ ¦ ¦ ¦ +---ili9481
¦ ¦ ¦ ¦ ¦ ¦ +---ili9486
¦ ¦ ¦ ¦ ¦ ¦ +---pcf8833
¦ ¦ ¦ ¦ ¦ ¦ +---r61581
¦ ¦ ¦ ¦ ¦ ¦ +---s1d19122
¦ ¦ ¦ ¦ ¦ ¦ +---s6d0164
¦ ¦ ¦ ¦ ¦ ¦ +---s6d1121
¦ ¦ ¦ ¦ ¦ ¦ +---ssd1289
¦ ¦ ¦ ¦ ¦ ¦ +---ssd1963
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---480
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---800
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---800alt
¦ ¦ ¦ ¦ ¦ ¦ +---st7735
¦ ¦ ¦ ¦ ¦ ¦ +---st7735s
¦ ¦ ¦ ¦ ¦ +---Tools
¦ ¦ ¦ ¦ +---UTouch
¦ ¦ ¦ ¦ ¦ ¦ +---UTouch_ButtonTest
¦ ¦ ¦ ¦ ¦ ¦ +---UTouch_Calibration
¦ ¦ ¦ ¦ ¦ ¦ +---UTouch_QuickDraw
¦ ¦ ¦ ¦ ¦ ¦ +---UTouch_QuickPaint
¦ ¦ ¦ ¦ +---arm
¦ ¦ ¦ ¦ +---avr
¦ ¦ ¦ ¦ +---pic32
¦ ¦ ¦ +---sensors
¦ ¦ ¦ +---NRF24L01
¦ ¦ ¦ +---balcony_irrigator
¦ ¦ ¦ +---clear_eeprom
¦ ¦ ¦ +---door_window_sensor
¦ ¦ +---JSON
¦ ¦ ¦ +---Snippet
¦ ¦ ¦ +---WiFiScan
¦ ¦ ¦ +---druhvhtml
¦ ¦ ¦ ¦ +---Menu
¦ ¦ ¦ +---MPU6050
¦ ¦ ¦ +---Examples
¦ ¦ +---MLX90614
¦ ¦ +---MProg 3.5 Release
¦ ¦ ¦ +---Drivers
¦ ¦ ¦ +---Help
¦ ¦ ¦ +---Templates
¦ ¦ +---MPU6050
¦ ¦ ¦ +---Examples
¦ ¦ +---MPU6050_Secure
¦ ¦ +---mqttMessageCenterExample
¦ ¦ +---MyAPClient
¦ ¦ +---MyAPServer
¦ ¦ +---OLED
¦ ¦ ¦ +---ESP_OLED_Weather_1
¦ ¦ ¦ +---Messenger1
¦ ¦ ¦ +---OLED_1306_test1
¦ ¦ ¦ +---OLED_test
¦ ¦ ¦ +---OLED_test2
¦ ¦ ¦ +---Rankin
¦ ¦ ¦ ¦ +---Bean_i2c_OLED_Test
¦ ¦ ¦ ¦ +---ESP_i2c_OLED_Test2
¦ ¦ ¦ ¦ +---GPS_Cube
¦ ¦ ¦ ¦ +---i2c_OLED_Test_Code
¦ ¦ ¦ ¦ +---Modifed_GPS_Cube
¦ ¦ ¦ +---YAW-OLED
¦ ¦ +---OneWire
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---DS18x20_Temperature
¦ ¦ ¦ +---DS2408_Switch
¦ ¦ ¦ +---DS250x_PROM
¦ ¦ +---P2P_Client
¦ ¦ ¦ +---MyAPClient
¦ ¦ +---P2P_Server
¦ ¦ ¦ +---MyAPServer
¦ ¦ +---PIR_Server
¦ ¦ +---pubsubclient
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---mqtt_auth
¦ ¦ ¦ ¦ +---mqtt_basic
¦ ¦ ¦ ¦ +---mqtt_publish_in_callback
¦ ¦ ¦ ¦ +---mqtt_stream
¦ ¦ ¦ +---PubSubClient
¦ ¦ ¦ +---tests
¦ ¦ ¦ +---src
¦ ¦ ¦ ¦ +---lib
¦ ¦ ¦ +---testcases
¦ ¦ +---PubSub_DHT11
¦ ¦ +---recover_wifi_creds
¦ ¦ +---SD
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---CardInfo
¦ ¦ ¦ ¦ +---Datalogger
¦ ¦ ¦ ¦ +---DumpFile
¦ ¦ ¦ ¦ +---Files
¦ ¦ ¦ ¦ +---listfiles
¦ ¦ ¦ ¦ +---ReadWrite
¦ ¦ ¦ +---src
¦ ¦ ¦ +---utility
¦ ¦ +---SdFat-master
¦ ¦ ¦ +---AnalogBinLoggerExtras
¦ ¦ ¦ ¦ +---ADCdocs
¦ ¦ ¦ ¦ +---bintocsv
¦ ¦ ¦ +---html
¦ ¦ ¦ ¦ +---search
¦ ¦ ¦ +---SdFat
¦ ¦ ¦ ¦ ¦ +---#attic
¦ ¦ ¦ ¦ ¦ ¦ +---AnalogLogger
¦ ¦ ¦ ¦ ¦ ¦ +---append
¦ ¦ ¦ ¦ ¦ ¦ +---average
¦ ¦ ¦ ¦ ¦ ¦ +---BaseExtCaseTest
¦ ¦ ¦ ¦ ¦ ¦ +---benchSD
¦ ¦ ¦ ¦ ¦ ¦ +---bufstream
¦ ¦ ¦ ¦ ¦ ¦ +---eventlog
¦ ¦ ¦ ¦ ¦ ¦ +---fgetsRewrite
¦ ¦ ¦ ¦ ¦ ¦ +---MiniSerial
¦ ¦ ¦ ¦ ¦ ¦ +---PrintBenchmarkSD
¦ ¦ ¦ ¦ ¦ ¦ +---readlog
¦ ¦ ¦ ¦ ¦ ¦ +---SdFatSize
¦ ¦ ¦ ¦ ¦ ¦ +---SD_Size
¦ ¦ ¦ ¦ ¦ +---AnalogBinLogger
¦ ¦ ¦ ¦ ¦ +---bench
¦ ¦ ¦ ¦ ¦ +---cin_cout
¦ ¦ ¦ ¦ ¦ +---dataLogger
¦ ¦ ¦ ¦ ¦ +---directoryFunctions
¦ ¦ ¦ ¦ ¦ +---fgets
¦ ¦ ¦ ¦ ¦ +---formatting
¦ ¦ ¦ ¦ ¦ +---getline
¦ ¦ ¦ ¦ ¦ +---LongFileName
¦ ¦ ¦ ¦ ¦ ¦ +---testFiles
¦ ¦ ¦ ¦ ¦ +---LowLatencyLogger
¦ ¦ ¦ ¦ ¦ +---OpenNext
¦ ¦ ¦ ¦ ¦ +---QuickStart
¦ ¦ ¦ ¦ ¦ +---RawWrite
¦ ¦ ¦ ¦ ¦ +---readCSV
¦ ¦ ¦ ¦ ¦ +---ReadWrite
¦ ¦ ¦ ¦ ¦ +---ReadWriteSdFat
¦ ¦ ¦ ¦ ¦ +---rename
¦ ¦ ¦ ¦ ¦ +---SdFormatter
¦ ¦ ¦ ¦ ¦ +---SdInfo
¦ ¦ ¦ ¦ ¦ +---SoftwareSpi
¦ ¦ ¦ ¦ ¦ +---StdioBench
¦ ¦ ¦ ¦ ¦ +---StreamParseInt
¦ ¦ ¦ ¦ ¦ +---ThreeCards
¦ ¦ ¦ ¦ ¦ +---Timestamp
¦ ¦ ¦ ¦ ¦ +---TwoCards
¦ ¦ ¦ ¦ +---utility
¦ ¦ ¦ +---SdFatTestSuite
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---ATS_SD_File
¦ ¦ ¦ +---ATS_SD_Files
¦ ¦ ¦ +---ATS_SD_Seek
¦ ¦ ¦ +---fstreamTest
¦ ¦ ¦ +---istreamTest
¦ ¦ ¦ +---lfnSize
¦ ¦ ¦ +---lfnTest
¦ ¦ ¦ +---lfnTestCout
¦ ¦ ¦ +---ostreamTest
¦ ¦ ¦ +---StressTest
¦ ¦ ¦ +---TestMkdir
¦ ¦ ¦ +---TestRmdir
¦ ¦ +---SD_WebServer
¦ ¦ +---ServoControl
¦ ¦ +---SimpleDashboard
¦ ¦ +---SimplePost_Get
¦ ¦ +---Simple_WebSvr
¦ ¦ +---SoftwareSerial
¦ ¦ ¦ +---softuart
¦ ¦ ¦ ¦ +---include
¦ ¦ ¦ +---user
¦ ¦ +---source-code-examples
¦ ¦ ¦ +---basic_example
¦ ¦ ¦ ¦ +---user
¦ ¦ ¦ +---blinky
¦ ¦ ¦ ¦ +---user
¦ ¦ ¦ +---interrupt_example
¦ ¦ ¦ +---user
¦ ¦ +---SPI
¦ ¦ +---SPIFFS
¦ ¦ ¦ +---data
¦ ¦ ¦ +---contact
¦ ¦ ¦ +---images
¦ ¦ ¦ +---links
¦ ¦ ¦ +---photos
¦ ¦ +---SPIFFS_TypeConv
¦ ¦ +---Streaming
¦ ¦ ¦ +---Streaming1
¦ ¦ ¦ +---Streaming2
¦ ¦ +---StringStream
¦ ¦ +---Strip_Save2SD
¦ ¦ +---Tamagotchi_ESP8266
¦ ¦ ¦ +---.git
¦ ¦ ¦ ¦ +---branches
¦ ¦ ¦ ¦ +---hooks
¦ ¦ ¦ ¦ +---info
¦ ¦ ¦ ¦ +---logs
¦ ¦ ¦ ¦ ¦ +---refs
¦ ¦ ¦ ¦ ¦ +---heads
¦ ¦ ¦ ¦ ¦ +---remotes
¦ ¦ ¦ ¦ ¦ +---origin
¦ ¦ ¦ ¦ +---objects
¦ ¦ ¦ ¦ ¦ +---00
¦ ¦ ¦ ¦ ¦ +---01
¦ ¦ ¦ ¦ ¦ +---02
¦ ¦ ¦ ¦ ¦ +---03
¦ ¦ ¦ ¦ ¦ +---04
¦ ¦ ¦ ¦ ¦ +---05
¦ ¦ ¦ ¦ ¦ +---06
¦ ¦ ¦ ¦ ¦ +---07
¦ ¦ ¦ ¦ ¦ +---09
¦ ¦ ¦ ¦ ¦ +---0a
¦ ¦ ¦ ¦ ¦ +---0b
¦ ¦ ¦ ¦ ¦ +---0c
¦ ¦ ¦ ¦ ¦ +---0d
¦ ¦ ¦ ¦ ¦ +---0e
¦ ¦ ¦ ¦ ¦ +---10
¦ ¦ ¦ ¦ ¦ +---11
¦ ¦ ¦ ¦ ¦ +---12
¦ ¦ ¦ ¦ ¦ +---13
¦ ¦ ¦ ¦ ¦ +---14
¦ ¦ ¦ ¦ ¦ +---15
¦ ¦ ¦ ¦ ¦ +---16
¦ ¦ ¦ ¦ ¦ +---18
¦ ¦ ¦ ¦ ¦ +---19
¦ ¦ ¦ ¦ ¦ +---1b
¦ ¦ ¦ ¦ ¦ +---1c
¦ ¦ ¦ ¦ ¦ +---1d
¦ ¦ ¦ ¦ ¦ +---1e
¦ ¦ ¦ ¦ ¦ +---1f
¦ ¦ ¦ ¦ ¦ +---20
¦ ¦ ¦ ¦ ¦ +---23
¦ ¦ ¦ ¦ ¦ +---24
¦ ¦ ¦ ¦ ¦ +---26
¦ ¦ ¦ ¦ ¦ +---27
¦ ¦ ¦ ¦ ¦ +---29
¦ ¦ ¦ ¦ ¦ +---2a
¦ ¦ ¦ ¦ ¦ +---2b
¦ ¦ ¦ ¦ ¦ +---2c
¦ ¦ ¦ ¦ ¦ +---2d
¦ ¦ ¦ ¦ ¦ +---2e
¦ ¦ ¦ ¦ ¦ +---30
¦ ¦ ¦ ¦ ¦ +---31
¦ ¦ ¦ ¦ ¦ +---32
¦ ¦ ¦ ¦ ¦ +---33
¦ ¦ ¦ ¦ ¦ +---34
¦ ¦ ¦ ¦ ¦ +---35
¦ ¦ ¦ ¦ ¦ +---36
¦ ¦ ¦ ¦ ¦ +---37
¦ ¦ ¦ ¦ ¦ +---39
¦ ¦ ¦ ¦ ¦ +---3a
¦ ¦ ¦ ¦ ¦ +---3b
¦ ¦ ¦ ¦ ¦ +---3c
¦ ¦ ¦ ¦ ¦ +---3d
¦ ¦ ¦ ¦ ¦ +---3e
¦ ¦ ¦ ¦ ¦ +---3f
¦ ¦ ¦ ¦ ¦ +---40
¦ ¦ ¦ ¦ ¦ +---41
¦ ¦ ¦ ¦ ¦ +---42
¦ ¦ ¦ ¦ ¦ +---43
¦ ¦ ¦ ¦ ¦ +---44
¦ ¦ ¦ ¦ ¦ +---45
¦ ¦ ¦ ¦ ¦ +---46
¦ ¦ ¦ ¦ ¦ +---47
¦ ¦ ¦ ¦ ¦ +---48
¦ ¦ ¦ ¦ ¦ +---49
¦ ¦ ¦ ¦ ¦ +---4b
¦ ¦ ¦ ¦ ¦ +---4c
¦ ¦ ¦ ¦ ¦ +---4d
¦ ¦ ¦ ¦ ¦ +---4e
¦ ¦ ¦ ¦ ¦ +---4f
¦ ¦ ¦ ¦ ¦ +---50
¦ ¦ ¦ ¦ ¦ +---51
¦ ¦ ¦ ¦ ¦ +---52
¦ ¦ ¦ ¦ ¦ +---53
¦ ¦ ¦ ¦ ¦ +---54
¦ ¦ ¦ ¦ ¦ +---55
¦ ¦ ¦ ¦ ¦ +---56
¦ ¦ ¦ ¦ ¦ +---57
¦ ¦ ¦ ¦ ¦ +---58
¦ ¦ ¦ ¦ ¦ +---59
¦ ¦ ¦ ¦ ¦ +---5a
¦ ¦ ¦ ¦ ¦ +---5b
¦ ¦ ¦ ¦ ¦ +---5c
¦ ¦ ¦ ¦ ¦ +---5d
¦ ¦ ¦ ¦ ¦ +---5e
¦ ¦ ¦ ¦ ¦ +---5f
¦ ¦ ¦ ¦ ¦ +---60
¦ ¦ ¦ ¦ ¦ +---62
¦ ¦ ¦ ¦ ¦ +---63
¦ ¦ ¦ ¦ ¦ +---64
¦ ¦ ¦ ¦ ¦ +---65
¦ ¦ ¦ ¦ ¦ +---66
¦ ¦ ¦ ¦ ¦ +---68
¦ ¦ ¦ ¦ ¦ +---69
¦ ¦ ¦ ¦ ¦ +---6a
¦ ¦ ¦ ¦ ¦ +---6b
¦ ¦ ¦ ¦ ¦ +---6c
¦ ¦ ¦ ¦ ¦ +---6d
¦ ¦ ¦ ¦ ¦ +---6e
¦ ¦ ¦ ¦ ¦ +---73
¦ ¦ ¦ ¦ ¦ +---74
¦ ¦ ¦ ¦ ¦ +---75
¦ ¦ ¦ ¦ ¦ +---76
¦ ¦ ¦ ¦ ¦ +---77
¦ ¦ ¦ ¦ ¦ +---78
¦ ¦ ¦ ¦ ¦ +---79
¦ ¦ ¦ ¦ ¦ +---7d
¦ ¦ ¦ ¦ ¦ +---7e
¦ ¦ ¦ ¦ ¦ +---7f
¦ ¦ ¦ ¦ ¦ +---80
¦ ¦ ¦ ¦ ¦ +---82
¦ ¦ ¦ ¦ ¦ +---83
¦ ¦ ¦ ¦ ¦ +---84
¦ ¦ ¦ ¦ ¦ +---86
¦ ¦ ¦ ¦ ¦ +---88
¦ ¦ ¦ ¦ ¦ +---8a
¦ ¦ ¦ ¦ ¦ +---8b
¦ ¦ ¦ ¦ ¦ +---8c
¦ ¦ ¦ ¦ ¦ +---8d
¦ ¦ ¦ ¦ ¦ +---8e
¦ ¦ ¦ ¦ ¦ +---8f
¦ ¦ ¦ ¦ ¦ +---90
¦ ¦ ¦ ¦ ¦ +---92
¦ ¦ ¦ ¦ ¦ +---93
¦ ¦ ¦ ¦ ¦ +---94
¦ ¦ ¦ ¦ ¦ +---96
¦ ¦ ¦ ¦ ¦ +---97
¦ ¦ ¦ ¦ ¦ +---98
¦ ¦ ¦ ¦ ¦ +---99
¦ ¦ ¦ ¦ ¦ +---9a
¦ ¦ ¦ ¦ ¦ +---9b
¦ ¦ ¦ ¦ ¦ +---9c
¦ ¦ ¦ ¦ ¦ +---9d
¦ ¦ ¦ ¦ ¦ +---9e
¦ ¦ ¦ ¦ ¦ +---a0
¦ ¦ ¦ ¦ ¦ +---a2
¦ ¦ ¦ ¦ ¦ +---a3
¦ ¦ ¦ ¦ ¦ +---a5
¦ ¦ ¦ ¦ ¦ +---a7
¦ ¦ ¦ ¦ ¦ +---a8
¦ ¦ ¦ ¦ ¦ +---a9
¦ ¦ ¦ ¦ ¦ +---aa
¦ ¦ ¦ ¦ ¦ +---ab
¦ ¦ ¦ ¦ ¦ +---ac
¦ ¦ ¦ ¦ ¦ +---ad
¦ ¦ ¦ ¦ ¦ +---ae
¦ ¦ ¦ ¦ ¦ +---af
¦ ¦ ¦ ¦ ¦ +---b1
¦ ¦ ¦ ¦ ¦ +---b2
¦ ¦ ¦ ¦ ¦ +---b4
¦ ¦ ¦ ¦ ¦ +---b5
¦ ¦ ¦ ¦ ¦ +---b6
¦ ¦ ¦ ¦ ¦ +---b9
¦ ¦ ¦ ¦ ¦ +---ba
¦ ¦ ¦ ¦ ¦ +---bc
¦ ¦ ¦ ¦ ¦ +---bd
¦ ¦ ¦ ¦ ¦ +---be
¦ ¦ ¦ ¦ ¦ +---bf
¦ ¦ ¦ ¦ ¦ +---c0
¦ ¦ ¦ ¦ ¦ +---c1
¦ ¦ ¦ ¦ ¦ +---c2
¦ ¦ ¦ ¦ ¦ +---c3
¦ ¦ ¦ ¦ ¦ +---c4
¦ ¦ ¦ ¦ ¦ +---c5
¦ ¦ ¦ ¦ ¦ +---c6
¦ ¦ ¦ ¦ ¦ +---c7
¦ ¦ ¦ ¦ ¦ +---ca
¦ ¦ ¦ ¦ ¦ +---cb
¦ ¦ ¦ ¦ ¦ +---cc
¦ ¦ ¦ ¦ ¦ +---ce
¦ ¦ ¦ ¦ ¦ +---cf
¦ ¦ ¦ ¦ ¦ +---d0
¦ ¦ ¦ ¦ ¦ +---d1
¦ ¦ ¦ ¦ ¦ +---d2
¦ ¦ ¦ ¦ ¦ +---d3
¦ ¦ ¦ ¦ ¦ +---d4
¦ ¦ ¦ ¦ ¦ +---d5
¦ ¦ ¦ ¦ ¦ +---d6
¦ ¦ ¦ ¦ ¦ +---d7
¦ ¦ ¦ ¦ ¦ +---d9
¦ ¦ ¦ ¦ ¦ +---da
¦ ¦ ¦ ¦ ¦ +---db
¦ ¦ ¦ ¦ ¦ +---dc
¦ ¦ ¦ ¦ ¦ +---dd
¦ ¦ ¦ ¦ ¦ +---df
¦ ¦ ¦ ¦ ¦ +---e0
¦ ¦ ¦ ¦ ¦ +---e1
¦ ¦ ¦ ¦ ¦ +---e2
¦ ¦ ¦ ¦ ¦ +---e3
¦ ¦ ¦ ¦ ¦ +---e4
¦ ¦ ¦ ¦ ¦ +---e5
¦ ¦ ¦ ¦ ¦ +---e6
¦ ¦ ¦ ¦ ¦ +---e7
¦ ¦ ¦ ¦ ¦ +---e8
¦ ¦ ¦ ¦ ¦ +---e9
¦ ¦ ¦ ¦ ¦ +---ea
¦ ¦ ¦ ¦ ¦ +---eb
¦ ¦ ¦ ¦ ¦ +---ec
¦ ¦ ¦ ¦ ¦ +---ee
¦ ¦ ¦ ¦ ¦ +---ef
¦ ¦ ¦ ¦ ¦ +---f0
¦ ¦ ¦ ¦ ¦ +---f1
¦ ¦ ¦ ¦ ¦ +---f2
¦ ¦ ¦ ¦ ¦ +---f3
¦ ¦ ¦ ¦ ¦ +---f4
¦ ¦ ¦ ¦ ¦ +---f5
¦ ¦ ¦ ¦ ¦ +---f6
¦ ¦ ¦ ¦ ¦ +---f7
¦ ¦ ¦ ¦ ¦ +---f8
¦ ¦ ¦ ¦ ¦ +---f9
¦ ¦ ¦ ¦ ¦ +---fa
¦ ¦ ¦ ¦ ¦ +---fb
¦ ¦ ¦ ¦ ¦ +---fd
¦ ¦ ¦ ¦ ¦ +---fe
¦ ¦ ¦ ¦ ¦ +---ff
¦ ¦ ¦ ¦ ¦ +---info
¦ ¦ ¦ ¦ ¦ +---pack
¦ ¦ ¦ ¦ +---refs
¦ ¦ ¦ ¦ +---heads
¦ ¦ ¦ ¦ +---remotes
¦ ¦ ¦ ¦ +---tags
¦ ¦ ¦ +---emu
¦ ¦ ¦ ¦ +---imgmatch
¦ ¦ ¦ ¦ +---M6502
¦ ¦ ¦ ¦ +---rom
¦ ¦ ¦ +---server
¦ ¦ ¦ +---viewer
¦ ¦ ¦ ¦ +---esp12
¦ ¦ ¦ ¦ ¦ +---esphttpclient
¦ ¦ ¦ ¦ ¦ +---html
¦ ¦ ¦ ¦ ¦ ¦ +---flash
¦ ¦ ¦ ¦ ¦ ¦ +---wifi
¦ ¦ ¦ ¦ ¦ +---include
¦ ¦ ¦ ¦ ¦ +---libesphttpd
¦ ¦ ¦ ¦ ¦ ¦ +---core
¦ ¦ ¦ ¦ ¦ ¦ +---espfs
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---espfstest
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---mkespfsimage
¦ ¦ ¦ ¦ ¦ ¦ +---include
¦ ¦ ¦ ¦ ¦ ¦ +---lib
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---heatshrink
¦ ¦ ¦ ¦ ¦ ¦ +---util
¦ ¦ ¦ ¦ ¦ +---user
¦ ¦ ¦ ¦ ¦ +---img
¦ ¦ ¦ ¦ +---remtama
¦ ¦ ¦ +---web
¦ ¦ +---Teensy_WebSvr
¦ ¦ +---Temp-Humidity
¦ ¦ ¦ +---examples
¦ ¦ +---Test_toWebserver
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---drawLines
¦ ¦ ¦ +---paint
¦ ¦ ¦ +---shapes
¦ ¦ ¦ +---text
¦ ¦ ¦ +---tftbmp
¦ ¦ ¦ +---tftbmp2
¦ ¦ +---ThingSpeak
¦ ¦ +---Ticker
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---TickerBasic
¦ ¦ ¦ +---TickerParameter
¦ ¦ +---TickerBasic
¦ ¦ +---TimerLib
¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ +---timerDelegates
¦ ¦ ¦ +---utility
¦ ¦ +---Tiny85_DHT22
¦ ¦ +---TinyGPS
¦ ¦ +---UDPClient
¦ ¦ +---UDPClientAPmode
¦ ¦ +---UdpMulticast2.ino
¦ ¦ +---UDP_ClientAP
¦ ¦ +---UDP_Listener
¦ ¦ +---UDP_MultiCast
¦ ¦ +---UDP_NTP
¦ ¦ +---UDP_Server
¦ ¦ +---UDP_ServerClient
¦ ¦ +---UDP_Slip
¦ ¦ +---UDP_test
¦ ¦ +---UDP_Test2
¦ ¦ +---UDP_Time
¦ ¦ +---Upload_Image
¦ ¦ +---Weather_proc
¦ ¦ +---WebGen
¦ ¦ ¦ +---AdvancedWebServerHuzzah
¦ ¦ ¦ +---AdvancedWebServerHuzzah_APandClient
¦ ¦ ¦ +---AdvancedWebServerHuzzah_SPIFFS
¦ ¦ ¦ ¦ +---data
¦ ¦ ¦ ¦ +---css
¦ ¦ ¦ ¦ +---images
¦ ¦ ¦ ¦ +---js
¦ ¦ ¦ +---WebGen
¦ ¦ ¦ +---css
¦ ¦ ¦ +---images
¦ ¦ ¦ +---js
¦ ¦ +---Webserver_Send-test
¦ ¦ +---WiFiScan_SPIFFS
¦ ¦ +---WiFi_Repeater
¦ ¦ +---Wire
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---digital_potentiometer
¦ ¦ ¦ +---master_reader
¦ ¦ ¦ +---master_writer
¦ ¦ ¦ +---SFRRanger_reader
¦ ¦ +---WirelessTemp
¦ ¦ +---WS2812
¦ ¦ +---Wunderground
¦ ¦ +---Wunderground1
¦ ¦ +---examples
¦ ¦ ¦ +---pcdtest
¦ ¦ +---MPU6050
¦ ¦ ¦ +---Examples
¦ ¦ +---photos
¦ +---OLED_WORK
¦ ¦ +---ESP_I2C_OLED_1
¦ ¦ +---ESP_WiFiScan-Acquire_1
¦ ¦ +---OLED_Server
¦ ¦ +---OLED_Template
¦ ¦ +---WiFiScan
¦ ¦ +---WiFiScanOpen
¦ +---punyforth-master
¦ ¦ +---arch
¦ ¦ ¦ +---arm
¦ ¦ ¦ +---esp8266
¦ ¦ ¦ ¦ +---bin
¦ ¦ ¦ ¦ +---forth
¦ ¦ ¦ ¦ +---rtos
¦ ¦ ¦ ¦ +---user
¦ ¦ ¦ +---x86
¦ ¦ +---contrib
¦ ¦ ¦ +---loader_by_Craig_Lindley
¦ ¦ ¦ ¦ +---ESP8266PunyForthLoader
¦ ¦ ¦ ¦ +---.settings
¦ ¦ ¦ ¦ +---bin
¦ ¦ ¦ ¦ ¦ +---com
¦ ¦ ¦ ¦ ¦ +---craigl
¦ ¦ ¦ ¦ ¦ +---esp8266punyforthloader
¦ ¦ ¦ ¦ +---jars
¦ ¦ ¦ ¦ +---src
¦ ¦ ¦ ¦ +---com
¦ ¦ ¦ ¦ +---craigl
¦ ¦ ¦ +---worldclock
¦ ¦ +---generic
¦ ¦ ¦ +---forth
¦ ¦ +---screenshot
¦ +---Simple_WebSvr
¦ +---Sniffing
¦ ¦ +---ESP8266_Serial_Mod
¦ ¦ ¦ +---esp8266mon-serial
¦ ¦ +---phatsniffer
¦ ¦ ¦ +---data
¦ ¦ ¦ +---esp8266
¦ ¦ ¦ ¦ +---jsonsniffer
¦ ¦ ¦ +---static
¦ ¦ ¦ +---templates
¦ ¦ +---Sniffing
¦ ¦ +---Sniffing2
¦ ¦ +---Sniffing3
¦ ¦ +---Sniffing4
¦ ¦ +---Sniffing5
¦ ¦ +---Sniffing6
¦ ¦ +---Sniffing_Specific
¦ +---Sparkfun
¦ ¦ +---ESP8266_GPIO_Blink
¦ ¦ +---ESP8266_Phant
¦ ¦ +---ESP8266_Phant_Library
¦ ¦ +---ESP8266_Phant_Sleep
¦ ¦ +---ESP8266_Ping
¦ ¦ +---ESP8266_Serial_Passthrough
¦ ¦ +---ESP8266_Shield_Demo
¦ ¦ +---PostWeb
¦ ¦ +---sparkfun
¦ +---Spiff_OUI
¦ ¦ +---Spiff_OUI-1
¦ ¦ ¦ +---data
¦ ¦ +---Spiff_OUI-10
¦ ¦ +---Spiff_OUI-11
¦ ¦ +---Spiff_OUI-12
¦ ¦ ¦ +---data
¦ ¦ ¦ +---small_data
¦ ¦ +---Spiff_OUI-13
¦ ¦ ¦ +---data
¦ ¦ +---Spiff_OUI-2
¦ ¦ +---Spiff_OUI-3
¦ ¦ +---Spiff_OUI-4
¦ ¦ +---Spiff_OUI-5
¦ ¦ +---Spiff_OUI-6
¦ ¦ +---Spiff_OUI-7
¦ ¦ +---Spiff_OUI-8
¦ ¦ +---Spiff_OUI-9
¦ +---SSD1306_I2C_128x32_SimpleDemo
¦ +---TardisTimeMulticast
¦ +---TardisTimeReceive
¦ +---TardisTimeReceive_OLED
¦ +---TardisTimeReceive_OLED_128x32
¦ ¦ +---OLED_LIB
¦ ¦ +---examples
¦ ¦ ¦ +---SSD1306ClockDemo
¦ ¦ ¦ +---SSD1306DrawingDemo
¦ ¦ ¦ +---SSD1306OTADemo
¦ ¦ ¦ +---SSD1306SimpleDemo
¦ ¦ ¦ +---SSD1306UiDemo
¦ ¦ +---resources
¦ +---template
¦ +---TestTest
¦ +---UDP
¦ ¦ +---UDP_2Ports
¦ ¦ +---UDP_Binary
¦ ¦ +---UDP_Client
¦ ¦ +---UDP_Echo
¦ ¦ +---UDP_Listen_Ack
¦ ¦ +---UDP_MsgEcho
¦ ¦ +---UDP_Server
¦ +---UPD_Switch
¦ +---WiFi_OFF
+---LoRa
¦ +---ESP32_LoRa_Rec_OLED
¦ +---ESP32_LoRa_Send
+---MapleMini
¦ +---AMP32F103CB
¦ ¦ +---APM_BP180_GLCD_24
¦ ¦ +---APM_FastBlinkNcount
¦ ¦ +---APM_RealTimeClock_BlkBD
¦ +---AnalogTest
¦ ¦ +---data
¦ +---ArduinoOscilloscope
¦ +---arduino_6502
¦ +---Bad_Mini_Test
¦ +---Binary_RW_to_SD
¦ +---Blank_Sketch
¦ +---BlinkNcount-Printf
¦ +---BluePill
¦ ¦ +---BlinkNcount3
¦ ¦ +---Test_Blink
¦ +---BMP180_Datalogger
¦ +---C64_6502
¦ +---CardInfo
¦ +---DS18B20_1
¦ +---ESP8266
¦ ¦ +---Basic_WebTest
¦ ¦ +---STM32_Time
¦ ¦ +---Weather
¦ ¦ +---WebServer
¦ +---FastBlinkNcount
¦ +---Forum
¦ ¦ +---BNewbold
¦ ¦ ¦ +---AudioShield
¦ ¦ ¦ +---MapleTest
¦ ¦ ¦ +---OverClock
¦ ¦ ¦ +---PinClass
¦ ¦ ¦ +---PressureLab
¦ ¦ +---dhry21a
¦ ¦ +---FFT_1024
¦ ¦ +---FreeRTOS_Cube-Rotate
¦ ¦ +---HWserial_Test
¦ ¦ +---Multi-AD_DMA
¦ ¦ +---MultiInstance-SoftwareSerial
¦ ¦ +---MultiInstance_SoftwareSerial
¦ ¦ +---Percussion
¦ ¦ +---Pulse_timing
¦ ¦ +---RGB2_TSC3200
¦ ¦ +---RGB_TSC3200
¦ ¦ +---SM32F103_Internal_Temp_Sensor
¦ ¦ +---SoftSerialIntCC
¦ ¦ +---Examples
¦ ¦ +---SoftSerialIntCCExample
¦ ¦ +---SoftSerialIntCCTest
¦ ¦ +---TwoPortRXExample
¦ +---ForumTest
¦ +---GitHub_Examples
¦ ¦ +---Blink
¦ ¦ +---BlinkNcount
¦ ¦ +---BlinkNcount_BlueBD
¦ ¦ +---Blink_BlueBD
¦ ¦ +---FadingOnboard
¦ ¦ +---IntegerInput
¦ ¦ +---IntegerInput_FloatOutput
¦ ¦ +---InternalTempSensor
¦ ¦ +---PrimeNos
¦ ¦ +---PrimeNos2
¦ ¦ +---PrimeNos3
¦ ¦ +---Print_Binary
¦ ¦ +---Print_Float
¦ ¦ +---Print_HEX
¦ ¦ +---radioModem
¦ ¦ +---SerialReadUntil
¦ ¦ +---SerialReadUntil2
¦ ¦ +---STM32-Sunrise
¦ ¦ +---StringEx_Parsing
¦ ¦ +---strtol_DecEquivalents
¦ ¦ +---USB_ASCII
¦ +---Graphic_Displays
¦ ¦ +---GLCD5110_BMP085
¦ ¦ +---ILI9341
¦ ¦ ¦ +---BP180_GLCD
¦ ¦ ¦ +---BP180_GLCD_24
¦ ¦ ¦ +---BP180_GLCD_24_MOD1
¦ ¦ ¦ +---BP180_GLCD_48
¦ ¦ ¦ +---BP180_GLCD_A
¦ ¦ ¦ +---BP180_ILI9341_48_WIP
¦ ¦ ¦ +---GPS_Time_Baro
¦ ¦ ¦ +---ILI9341_fastgraphics
¦ ¦ ¦ +---ILI9341_fastgraphics2
¦ ¦ ¦ +---ILI9341_Harichord
¦ ¦ ¦ +---ILI9341_hwScroll
¦ ¦ ¦ +---Oscope
¦ ¦ ¦ +---Serial_Terminal
¦ ¦ ¦ +---STM32-Sunrise
¦ ¦ +---Nokia5100_PCD8544
¦ ¦ ¦ +---GLCD5110_BMP085
¦ ¦ ¦ +---Hwd_SPI
¦ ¦ ¦ +---I2C_SPI_SDcard_GLCD
¦ ¦ ¦ +---I2C_SPI_SD_GLCD_DHT11
¦ ¦ ¦ +---Nokia5110_SPI_SDCard
¦ ¦ ¦ +---NokiaTest1
¦ ¦ ¦ +---NokiaTest2
¦ ¦ ¦ +---RPI_MPC_Control
¦ ¦ ¦ +---RPI_MPC_Control_1
¦ ¦ ¦ +---RPI_MPC_Control_2
¦ ¦ ¦ +---RPI_MPC_Control_3
¦ ¦ ¦ +---RPI_MPC_Control_JOYST
¦ ¦ ¦ ¦ +---archive
¦ ¦ ¦ +---RPI_MPC_Control_JOYST_1
¦ ¦ ¦ +---RPI_MPC_Control_JOYST_2
¦ ¦ ¦ +---Test_Template
¦ ¦ +---SSD1306
¦ ¦ +---HariChord_swSPI
¦ ¦ +---OLED_Altimeter
¦ ¦ +---SPI_OLED_BPM180
¦ +---I2C_1_2
¦ +---I2C_Scanner
¦ +---maple_mini_bootloader
¦ +---maple_mini_bootloaer_updater
¦ +---NRF24_multipipe
¦ ¦ +---fontconvert
¦ ¦ +---Fonts
¦ +---Oscope
¦ +---Overclock
¦ +---RealTimeClock
¦ +---RealTimeClock_BlueBD
¦ +---SerialUSB
¦ +---Serial_Calc
¦ +---Simple_Array_Parser
¦ +---SPI
¦ ¦ +---SPI2_Example
¦ +---SplitStringToken_Example
¦ +---STM32-O-Scope
¦ +---STM32-Sunrise
¦ +---STM32C64TFT
¦ +---STM32CORES
¦ +---STM32GENERTIC_DOC
¦ +---StreamOutput_Decimal_Equivalents
¦ +---Test_RTClock
¦ +---Test_RTClock_BlueBD
¦ +---TinyGPS
¦ +---VarScopeIssue
+---Mega
¦ +---DHT11
¦ ¦ +---DHT11_NoLib
¦ +---DS1307_I2C
¦ +---Europa
¦ ¦ +---Datalogger3
¦ ¦ ¦ +---Datalogger3
¦ ¦ +---Engine_Monitor_1
¦ ¦ +---Europa10_Mega2560
¦ ¦ +---GrayCode_2
¦ ¦ +---IR_Code_Rec
¦ ¦ ¦ +---IR_Code_Rec
¦ ¦ ¦ +---IR_DS1307_Test
¦ ¦ +---PropBalancer
¦ ¦ ¦ +---ARDUINO_DS1307
¦ ¦ ¦ ¦ +---arduino code
¦ ¦ ¦ ¦ ¦ +---Arduino libraries
¦ ¦ ¦ ¦ ¦ ¦ +---DS1307
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---examples
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---DS1307
¦ ¦ ¦ ¦ ¦ ¦ ¦ +---I2C_Test
¦ ¦ ¦ ¦ ¦ ¦ +---OneWire
¦ ¦ ¦ ¦ ¦ ¦ +---sample
¦ ¦ ¦ ¦ ¦ +---demo2
¦ ¦ ¦ ¦ ¦ +---demo2uart
¦ ¦ ¦ ¦ +---sch
¦ ¦ ¦ +---dpbv1_3_3
¦ ¦ ¦ ¦ +---AP_Common
¦ ¦ ¦ ¦ ¦ +---tools
¦ ¦ ¦ ¦ ¦ +---FastSerial
¦ ¦ ¦ ¦ ¦ +---MultiFastSerial
¦ ¦ ¦ ¦ ¦ +---tools
¦ ¦ ¦ +---libraries
¦ ¦ ¦ +---AP_Common
¦ ¦ ¦ ¦ +---tools
¦ ¦ ¦ +---examples
¦ ¦ +---Steve_Engine_Monitor_1a
¦ ¦ +---Steve_Engine_Monitor_1b
¦ ¦ +---Test_adxl345
¦ ¦ +---Time_Array_adxl345
¦ ¦ +---Time_Array_adxl345_2
¦ +---GLCD
¦ ¦ +---ITDB02_Graph16_BitmapOK
¦ ¦ +---ITDB02_Graph16_DemoOK
¦ ¦ +---ITDB02_Graph16_LandscapeDemoOK
¦ ¦ +---ITDB02_Graph16_Rotate_BitmapOK
¦ ¦ +---ITDB02_Graph16_Textrotation_DemoOK
¦ ¦ +---ITDB02_Graph16_ViewFontLS_OK
¦ ¦ +---ITDB02_QVGA_240x320_PortOK
¦ ¦ +---ITDB02_Touch_CalibrationOK
¦ ¦ +---MenuPlay
¦ +---Interrupt_Test_Mega
¦ +---libraries
¦ +---SD_Card
¦ ¦ +---Datalogger
¦ ¦ +---Datalogger1
¦ ¦ +---Datalogger2
¦ ¦ +---Datalogger3
¦ +---Test_Interrupt
¦ +---WavePlay
¦ ¦ +---Copy what inside the folder in SD
¦ ¦ +---MegaCode
¦ ¦ +---ArduinoMega
¦ +---Z80_Interface
+---MiniPro
¦ +---BillH_ADXL345_SPI
¦ +---BMP180_5110_AltGph
¦ +---CanonFlash2
¦ +---esp8266_weather
¦ +---ILI9340
¦ ¦ +---Serial_Test10
¦ +---LCD
¦ ¦ +---Hello_World_4bit
¦ ¦ +---NokiaTest1
¦ ¦ +---OLED_1306_HelloWorld
¦ +---MagicMorse
¦ ¦ +---Magic_Morse_Nokia
¦ ¦ +---Magic_Morse_Nokia2
¦ ¦ +---Magic_Morse_Nokia3
¦ ¦ +---Magic_Morse_Nokia4
¦ ¦ +---Magic_Morse_Nokia5
¦ ¦ +---Magic_Morse_Nokia6
¦ ¦ +---Magic_Morse_Nokia7
¦ ¦ +---Magic_Morse_Nokia8
¦ ¦ +---Magic_Morse_Nokia8a
¦ ¦ +---Magic_Morse_V1
¦ ¦ +---Magic_Morse_V2
¦ +---Nokia_Test
¦ ¦ +---Adafruit_SSD1306
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---ssd1306_128x32_i2c
¦ ¦ ¦ +---ssd1306_128x32_spi
¦ ¦ ¦ +---ssd1306_128x64_i2c
¦ ¦ ¦ +---ssd1306_128x64_spi
¦ ¦ +---BMP180
¦ ¦ ¦ +---examples
¦ ¦ +---Button
¦ ¦ ¦ +---Examples
¦ ¦ ¦ +---Button
¦ ¦ ¦ +---EventButton
¦ ¦ ¦ +---PollingComplexButton
¦ ¦ +---EEPROM
¦ ¦ +---examples
¦ ¦ +---eeprom_read
¦ +---RF12B_GPS
¦ +---Receive
¦ +---Send
+---Nano
¦ +---12Keypad
¦ +---BlinknCount
¦ +---Calculator
¦ ¦ +---calculator1
¦ ¦ +---calculator2
¦ ¦ +---calculator3
¦ ¦ +---calculator4
¦ +---Double_Array_Parser
¦ +---Examples
¦ ¦ +---Double_Array_Parser
¦ ¦ +---examples
¦ ¦ ¦ +---Double_Array_Parser
¦ ¦ ¦ +---Float_IntegerStream
¦ ¦ ¦ +---FP_Exponents
¦ ¦ ¦ +---Integer_Stream
¦ ¦ ¦ +---Long_IntegerStream
¦ ¦ ¦ +---Simple_Array_Parser
¦ ¦ ¦ +---StreamOutput_Decimal_Equivalents
¦ ¦ +---float_from_serial
¦ ¦ +---_1K_eeprom_WR
¦ +---FindInArray
¦ +---GLCD_OLED
¦ ¦ +---GLCD128x128_ILI9163
¦ ¦ ¦ +---FTM144D01N_test
¦ ¦ ¦ ¦ +---Debug
¦ ¦ ¦ +---Img2Code
¦ ¦ ¦ +---Sumotoy
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---bigtest
¦ ¦ ¦ +---cube
¦ ¦ ¦ +---Mesmerizer
¦ ¦ ¦ +---minimal
¦ ¦ ¦ +---test
¦ ¦ +---OLED128x64_SSD1306
¦ ¦ ¦ +---SPI_Test
¦ ¦ +---QVGA240x320_ILI94341
¦ ¦ +---graphicstest2
¦ ¦ +---graphicstest3
¦ ¦ +---Test1
¦ +---GPS_NoLib
¦ +---LCD_I2C
¦ +---LCD_I2C_2x16-OLED
¦ +---LCD_I2C_2x16-OLED_GPS
¦ +---MemoryLeakage
¦ ¦ +---MemoryLeakage
¦ +---MLX90614
¦ +---Parsing
¦ ¦ +---StringEx
¦ +---PICAXECalc
¦ +---ReadPinState
¦ +---Right_Triangle
¦ ¦ +---examples
¦ ¦ +---Right_Triangle
¦ ¦ +---Right_Triangle1
¦ ¦ +---Right_Triangle2
¦ +---WavePlay
¦ +---NanoCode
¦ +---WAV files
¦ +---WAV_files
+---ProMicro
¦ +---ArraySwapIssue
¦ ¦ +---sketch_mar02a
¦ +---Blink
¦ +---BlinkCount
¦ +---CC_Flash
¦ +---CurveTracer
¦ +---GLCD_OLED
¦ ¦ +---ILI9163
¦ ¦ ¦ +---TFT_ILI9163C-master
¦ ¦ ¦ ¦ +---bigtest
¦ ¦ ¦ ¦ +---cube
¦ ¦ ¦ ¦ ¦ +---New Folder
¦ ¦ ¦ ¦ +---minimal
¦ ¦ ¦ ¦ +---test
¦ ¦ ¦ ¦ +---_Utility
¦ ¦ ¦ +---Version 3_5 (current)
¦ ¦ ¦ +---examples
¦ ¦ ¦ +---BasicFunctions
¦ ¦ ¦ +---ImageRotation
¦ ¦ ¦ +---TestPattern
¦ ¦ +---ILI9340
¦ ¦ +---GPS_GLCD_uBlox_BIG
¦ ¦ +---QBFgenerator
¦ ¦ ¦ +---Serial_Test9
¦ ¦ +---Serial_Test
¦ ¦ +---Serial_Test2
¦ ¦ +---Serial_Test3
¦ ¦ +---Serial_Test4
¦ ¦ +---Serial_Test6
¦ ¦ +---Serial_Test7
¦ ¦ +---Serial_Test8
¦ ¦ +---TextOnly
¦ +---JoyStick
¦ ¦ +---TFT_Pong
¦ ¦ +---TFT_Pong1
¦ ¦ +---TFT_Pong2
¦ ¦ +---TFT_Pong3
¦ ¦ +---TFT_Pong4
¦ ¦ +---TFT_Pong5
¦ +---OctalControl
¦ +---Oscope
¦ +---ShiftingBitsDancing
¦ +---SimpleArray
¦ +---stlport
¦ +---SyncSyncReboot
¦ +---SyncSyncShutdown
+---RP2040_Pico
¦ +---dhry21a
¦ +---Examples
¦ ¦ +---.github
¦ ¦ ¦ +---workflows
¦ ¦ +---adc
¦ ¦ ¦ +---adc_console
¦ ¦ ¦ +---dma_capture
¦ ¦ ¦ +---hello_adc
¦ ¦ ¦ +---joystick_display
¦ ¦ +---blink
¦ ¦ +---clocks
¦ ¦ ¦ +---detached_clk_peri
¦ ¦ ¦ +---hello_48MHz
¦ ¦ ¦ +---hello_gpout
¦ ¦ ¦ +---hello_resus
¦ ¦ +---cmake
¦ ¦ ¦ +---build_variants
¦ ¦ +---divider
¦ ¦ +---dma
¦ ¦ ¦ +---channel_irq
¦ ¦ ¦ +---control_blocks
¦ ¦ ¦ +---hello_dma
¦ ¦ +---flash
¦ ¦ ¦ +---cache_perfctr
¦ ¦ ¦ +---nuke
¦ ¦ ¦ +---program
¦ ¦ ¦ +---ssi_dma
¦ ¦ ¦ +---xip_stream
¦ ¦ +---gpio
¦ ¦ ¦ +---dht_sensor
¦ ¦ ¦ +---hello_7segment
¦ ¦ ¦ +---hello_gpio_irq
¦ ¦ +---hello_world
¦ ¦ ¦ +---serial
¦ ¦ ¦ +---usb
¦ ¦ +---i2c
¦ ¦ ¦ +---bus_scan
¦ ¦ ¦ +---lcd_1602_i2c
¦ ¦ ¦ +---mpu6050_i2c
¦ ¦ +---ide
¦ ¦ ¦ +---vscode
¦ ¦ +---interp
¦ ¦ ¦ +---hello_interp
¦ ¦ +---multicore
¦ ¦ ¦ +---hello_multicore
¦ ¦ ¦ +---multicore_fifo_irqs
¦ ¦ ¦ +---multicore_runner
¦ ¦ ¦ +---multicore_runner_queue
¦ ¦ +---picoboard
¦ ¦ ¦ +---blinky
¦ ¦ ¦ +---button
¦ ¦ +---pio
¦ ¦ ¦ +---addition
¦ ¦ ¦ +---apa102
¦ ¦ ¦ +---clocked_input
¦ ¦ ¦ +---differential_manchester
¦ ¦ ¦ +---hello_pio
¦ ¦ ¦ +---hub75
¦ ¦ ¦ +---i2c
¦ ¦ ¦ +---logic_analyser
¦ ¦ ¦ +---manchester_encoding
¦ ¦ ¦ +---pio_blink
¦ ¦ ¦ +---pwm
¦ ¦ ¦ +---spi
¦ ¦ ¦ +---squarewave
¦ ¦ ¦ ¦ +---generated
¦ ¦ ¦ +---st7789_lcd
¦ ¦ ¦ +---uart_rx
¦ ¦ ¦ +---uart_tx
¦ ¦ ¦ +---ws2812
¦ ¦ ¦ +---generated
¦ ¦ +---pwm
¦ ¦ ¦ +---hello_pwm
¦ ¦ ¦ +---led_fade
¦ ¦ ¦ +---measure_duty_cycle
¦ ¦ +---reset
¦ ¦ ¦ +---hello_reset
¦ ¦ +---rtc
¦ ¦ ¦ +---hello_rtc
¦ ¦ ¦ +---rtc_alarm
¦ ¦ ¦ +---rtc_alarm_repeat
¦ ¦ +---spi
¦ ¦ ¦ +---bme280_spi
¦ ¦ ¦ +---mpu9250_spi
¦ ¦ ¦ +---spi_dma
¦ ¦ ¦ +---spi_flash
¦ ¦ +---system
¦ ¦ ¦ +---hello_double_tap
¦ ¦ ¦ +---narrow_io_write
¦ ¦ ¦ +---unique_board_id
¦ ¦ +---timer
¦ ¦ ¦ +---hello_timer
¦ ¦ ¦ +---periodic_sampler
¦ ¦ ¦ +---timer_lowlevel
¦ ¦ +---uart
¦ ¦ ¦ +---hello_uart
¦ ¦ ¦ +---uart_advanced
¦ ¦ +---usb
¦ ¦ ¦ +---device
¦ ¦ ¦ ¦ +---dev_audio_headset
¦ ¦ ¦ ¦ +---dev_hid_composite
¦ ¦ ¦ ¦ +---dev_hid_generic_inout
¦ ¦ ¦ ¦ +---dev_lowlevel
¦ ¦ ¦ +---host
¦ ¦ ¦ +---host_hid
¦ ¦ +---watchdog
¦ ¦ +---hello_watchdog
¦ +---I2C_Mas-Sla
¦ +---ILI9341
¦ +---multicore_test
¦ +---multicore_test_2
¦ +---NeoPixel
¦ +---PrimeNos
¦ +---PrimeNos2
¦ +---ReadTemp_OLED
¦ +---SSD1306_OLED
+---sketch_sep11a
+---Teensy
¦ +---Adafruit_ST7735
¦ ¦ +---examples
¦ ¦ +---graphicstest_highspeed
¦ ¦ +---rotationtest
¦ ¦ +---rotationtest_highspeed
¦ ¦ +---shieldtest
¦ ¦ +---soft_spitftbitmap
¦ ¦ +---SpeedTest
¦ ¦ +---spitftbitmap_rotate
¦ +---ESP8266
¦ ¦ +---Teensy_Time
¦ +---eth_websrv_SD_Ajax_in_out
¦ +---ILI9340
¦ +---RGB_1dot8_LCD
¦ ¦ +---graphicstest_t31
¦ +---STM32-Sunrise-master
¦ +---t31_AMI_server4
¦ +---t31_BaroWebServer
¦ +---t31_graphicstest
¦ +---t31_Nokia5100-test
¦ +---t31_test_2
¦ +---t31_test_3
¦ +---WebServer
+---Tiny85
¦ +---32K_Play
¦ ¦ +---.dep
¦ +---AnalogReadSerial
¦ +---AnalogReadSerial_PC
¦ +---BareMinimum
¦ +---ColdHeartedOrb
¦ +---NTC_Resistor_Temp
¦ ¦ +---NTC_Resistor_Temp
¦ +---PWM3_TriColorLED
¦ +---PWM3_TriColorLED_Temp
¦ +---PWM3_TriColorLED_Temp_WDT
¦ +---Tiny85_Blink
¦ +---Tiny85_COM1_Print
¦ +---Tiny85_COM1_Print2
¦ +---Tiny85_Count
¦ +---Tiny85_Count_Print
¦ +---Tiny85_FP_Count_Print__Fails_
¦ +---Tiny85_InternalTemperatureSensor
¦ +---Tiny85_IR_Code_Rec
¦ +---Tiny85_IR_with_Xtal
¦ +---Tiny85_MagicMorse
¦ +---Tiny85_MagicMorse_Debug
¦ +---Tiny85_SerialPrint
¦ +---Tiny85_SoftwareSerial
¦ +---Tiny85_SparkFun_LCD
+---Trinket
¦ +---Blink
¦ +---Blinkie
¦ +---Blink_16
¦ +---DigiSpark
¦ ¦ +---PWM_3pins
¦ ¦ +---Serial_USB_Diags
¦ ¦ +---t85_InternalTemp
¦ +---Fade
¦ +---HID_IR_Sony
¦ +---HID_KBD
¦ +---HID_KBD_BlinkNCount
¦ +---HID_NTC_Temp
¦ +---NTC_Temp
¦ +---PWM_3pins
¦ +---Raw_IR
¦ +---RAW_IR_decode
¦ +---RAW_IR_Viewer
¦ +---Sony_IR
¦ +---SWSerialSendandCount
¦ +---TrinketKeyboardExample
¦ ¦ +---TrinketKeyboardExample.ino
¦ +---Trinket_F5
¦ +---Trinket_MagicMorse
¦ +---USBkeyboard_Prank
¦ +---USBkeyboard_Trinket
¦ +---USB_Mouse
¦ ¦ +---USB_Mouse
¦ +---_99_Minute_Timer
+---TrinketPro
¦ +---AnalogPrintOverHID
¦ ¦ +---HIDSerial
¦ ¦ +---examples
¦ ¦ +---analog_print
¦ ¦ +---button
¦ ¦ +---echo
¦ ¦ +---hello_world
¦ +---Calculator
¦ +---EchoSerialHID
¦ +---FakeSerialTest_1
¦ +---HIDprintAnalog_Blink
+---UNO
+---Accelerometer_835B
¦ +---Calibrate
¦ +---Calibrate2
¦ +---Controller
¦ +---DegreesDemo
¦ +---Processing
¦ ¦ +---Accel3D
¦ ¦ +---Game
¦ +---Touchscreen
¦ ¦ +---AccelGraph_MCP3008
¦ ¦ +---Schematic And Design
¦ +---XYZ_average
¦ +---XYZ_max_min
¦ +---XYZ_play
+---Arduino_Musical_NR
+---Arduino_Tester
¦ +---Ardutester
¦ +---ardutester_0
¦ ¦ +---arduino_07f
¦ ¦ ¦ +---arduino_07f_ino
¦ ¦ +---arduino_07fa
¦ ¦ +---ardutester_0
¦ +---ardutester_1
¦ +---ardutester_2
¦ +---ardutester_3
¦ +---ardutester_4
+---Calculator
¦ +---calculator4
+---CapMeter
¦ +---CapMeterV0
+---Count_transistins_Timer1
+---eINK_2_multiline-multifont
+---esp8266
¦ +---json_OpenWeatherMap1
+---FFT
¦ +---FFT_test
¦ +---FFT_test2
¦ +---FFT_test3
¦ +---FFT_test4
¦ +---FFT_TV
+---Firmata
¦ +---arduino-adc-io-expander
+---GLCD
¦ +---ILI9341
¦ ¦ +---Hello
¦ +---Nokia_5110
¦ ¦ +---Arduino_NOKIA_5110
¦ ¦ +---Hello_World_4bit_LCD
¦ ¦ +---Hello_World_4bit_LCD_freeRam
¦ ¦ +---Hello_World_4bit_LCD_newwire
¦ ¦ +---Nokia5110_Graphic
¦ ¦ +---Nokia_5110_Count
¦ ¦ +---Nokia_5110_Hello
¦ +---RGB_1dot8_LCD
¦ +---RGB_LCD_128x128x65K
¦ +---Direct_AVR_IO
¦ +---RGB_Demo
+---GPS
¦ +---GPS_clock_ArduinoUNO
¦ +---GPS_GLCD_uBlox_Temp
¦ +---GPS_LCD_uBlox
¦ +---GPS_LCD_uBlox_Temp
¦ +---GPS_OLED_uBlox
¦ +---GPS_Parsing_Small
¦ +---GPS_Parsing_Test
¦ +---GPS_TimeDateOLED
+---HIDserialUSnoobie
¦ +---analog_print
¦ +---analog_print_echo
¦ +---analog_Streaming_echo
¦ +---analog_Streaming_echo_led
¦ +---analog_Streaming_echo_led_Calc
¦ +---USB_HID_AnalogX6_D8
+---I2C
¦ +---I2C_bus_scanner
¦ +---I2C_eePROM
¦ +---MCP342x_AD_I2C
¦ +---MCP342x_AD_I2C_Explore
¦ +---Read_From_EEPROM_display
¦ +---_24C32_eePROM_WriteReadBytes
+---iArduino
¦ +---examples
¦ +---ArduinoMonitor
¦ ¦ +---BareMinimum
¦ ¦ +---Blink
¦ ¦ +---BlinkWithoutDelay
¦ ¦ +---cInterpreter
¦ ¦ +---Servo
¦ ¦ +---Knob
¦ ¦ +---Sweep
¦ +---iArduino
¦ +---ic_Arduino
+---Interrupt
¦ +---AVR_Interrupt
¦ +---OneSecBlink
+---IR_Analyzer
¦ +---necIR_Analyzer
+---Morse
¦ +---Magic_Morse
¦ ¦ +---OldBackup
¦ +---Magic_Morse_V3
¦ +---Magic_Morse_V4
¦ +---Magic_Morse_V5
¦ +---Magic_Morse_V6
¦ +---Magic_Morse_V8
¦ +---Magic_Morse_V8a
¦ +---Morse_Decoder
¦ ¦ +---Morse_Decoder_ino
¦ +---Morse_EnDecoder
¦ +---examples
¦ +---Morse_Encoder_tone
¦ +---Morse_EnDecoder_barebones
¦ +---Morse_EnDecoder_demo
+---Print_Formats
¦ +---Print_binary
¦ +---Print_float
¦ +---Print_hex
+---RTC
¦ +---DS1307_I2C
¦ +---DS1307_UNO
¦ +---Tiny_RTC_ADAfruit
+---Sensors
¦ +---328_Internal_Temp
¦ ¦ +---_328P_Internal_Temp2
¦ ¦ +---_328P_Internal_Temperature
¦ +---DHT11
¦ ¦ +---DHT11
¦ ¦ +---DHT11_NoLib
¦ ¦ +---DHT11_NoLib2
¦ +---DHT11_LM335_Ultrasonic
¦ +---DHT11_Ultrasonic
¦ +---DS18B20
¦ +---GPS_Arduino_10
¦ ¦ +---GPS_Test_Main_Library
¦ +---MAX31855_Temp
¦ +---TCS230_Module
¦ ¦ +---examples
¦ ¦ ¦ +---CRS_Code
¦ ¦ +---Test_Code
¦ ¦ +---C51
¦ +---Temperature
¦ +---Thermistor
¦ +---Thermistor_Stream
¦ +---Thermocouple
+---SerialRealUnitl
¦ +---SerialReadUnitl
+---Sin_LU
+---SPI_SDCard
¦ +---CardInfo1
¦ +---Datalogger3
+---SprintF
+---StarWarsTheme
+---Tests
¦ +---AD_256_Array_Lookup
¦ +---BareMinimum
¦ +---Blink_Count
¦ +---Blink_Serial
¦ +---Build_InputString
¦ +---Int_EEPROM
¦ ¦ +---Loop_EEPROM
¦ +---PrintFloats
¦ +---pString_Test
¦ +---SerialPort_Echo
¦ +---Serial_SD_Buffered_Logger
¦ +---_1K_eeprom_WR
+---TinyBASIC
¦ +---TinyBasic
¦ +---TinyBasicPlus
+---VUSB
¦ +---Bare_Minimum
¦ +---USB_HID_AlphaNum
¦ +---USB_HID_Analog2Serial
¦ +---USB_HID_InternalTemp
¦ +---USB_HID_KBD_Hello
¦ ¦ +---examples
¦ ¦ +---USB_HID_KBD_Hello
¦ +---USB_HID_MICKEYB
¦ +---USB_HID_StringAutoCount
¦ +---USB_HID_StringCount
¦ +---USB_Keyboard_Simple
+---zorkduino
+---docs
+---microsdfiles
+---zorkduino
Please tell me you didn't type that all out by hand.
C:\Users\burne\Documents\Arduino>tree Ray_Sketches > tree.txt
C:\Users\burne\Documents\Arduino>notepad tree.txt
Of course, a single "everything Arduino" makes searches a no-brainer!
ILI9341 across the folder is one command:
Thank you to all who provided direction.
It appears the root cause of my issues is the need for a better understanding of the environment.
Wrestling with libraries is and has always been an issue in the development world.
Now that I have learned a few things, I really have two chief take-aways.
Linux is a better development environment in that everything is contained under the Arduino directory structure.
Windows uses a much more esoteric structure.
C:\Users\dickinse\AppData\Local\Arduino15
C:\Users\dickinse\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32\Arduino.h
That is not affected by removing/downgrading/upgrading/installing boards and/or libraries.
I use this as an example since the offending "undeclared set::round" survived a wipe and reinstall.
Cut me some slack for I am a grey haired C nerd.
The final point is, is it easier and/or faster to wipe/reinstall than chase down a library or board version? Practice will tell.
Again thank you all for your input.
At least for the official version of Arduino IDE (it's possible some modified 3rd party versions from the Linux package repositories have a different behavior), this is incorrect. The IDE uses the same system of storing the installed boards platforms under a separate folder on Linux as on Windows. The location on Linux is ~/.arduino15
instead of C:\Users\dickinse\AppData\Local\Arduino15
The .arduino15
folder may be hidden by default in your file manager and terminal.
system
Closed
October 1, 2023, 1:38pm
15
