[ISP board schematic] ATMEGA328P-AU TQFP-32
Does anyone have a ISP schematic (IC+ crystal+caps) for TQFP-32 so i could print that out and use it to program atmega328p-au via ISP?
If it also has FTDI it would be great but it's not a need : )
I could have created it but i don't know how to connect the components (yes i'm a noob)
Thanks
I have an Eagle schematic for a TDR including atmega328p-au, ISP header etc. at Dropbox - File Deleted. I haven't built this yet, so please check the connections against the datasheet before you rely on it.
Use the Nano schematic, has all you need.
Thanks mates, i'm going to take a look :slight_smile:
I've always heard it called an ICSP for In Circuit Serial Programmer.
Looks like a lot of people are calling it "ISP", now. Guess I'd better get with the times.
polymorph:
My understanding is that ISCP is a registered trademark and ISP is the "generic" term used by other companies.
(same as i2c vs. TWI or, if you're into ham radio, PL Tones vs CTCSS)
Regards,
Brad.
