ISP Header with NRF24 attatched.
Hi. Couple of quick questions...
Was unsure of which sub-forum this may be in but I guess it it "general" guidance.
I am going to be trying to make some standalone atmega328pu boards with an nrf24l modules attached.
  1. I am assuming that I can just have the MISO/MOSI/etc. SPI pins used for in system programming even with the nrf attatched to the same MOSI/MISO SPI pins?
  2. Does the reset pin basically place the MCU in to a sort of "programming" mode?
  3. I guess I need to use a 3.3V regulator for the nrf24 modules (3.3V power and 5V logic is fine apparently...why cant they just add a 3.3V reg themselves...)?
If you are making a standalone Atmega 328 with an nRF24 why not make life simple and power everything at 3.3volts.
I don't know the answer to your SPI programming question but I suspect you will need to be able to differentiate between the nRF24 and the Atmega 328.
I program my Atmega 328s with a USB-ttl cable.
...R
Read up on Select or Enable pins and take a look at your NFR2400....
Thank you both!
Yeah, I assumed that most sensors were 5V, but it seems a lot are happy at 3.3V
Saves me hassle.
Johnny010:
  1. Does the reset pin basically place the MCU in to a sort of "programming" mode?
If you mean loading a sketch, the boot loader will accept an attempt to load a sketch for a few seconds after a reset. You do not require a bootloader, incidentally, if you load sketches using ISP.
Here is an excellent explanation:
I happened to have tons of boards with isp and NRF24 header. if you want them, I can send you few for free.
