ISP woes
I have successfully put together my ISP shield http://www.ladyada.net/library/arduino/arduinoisp.html. I mounted this on my Duemilanove and loaded my code onto my ATmega328p via the Arduino IDE 1.0.
Everything appears to work just fine, as I don't receive back any error codes. However, when I place the chip on my breadboard setup according to this instructable http://www.instructables.com/id/Standalone-Arduino-ATMega-chip-on-breadboard/, nothing happens.
I have simple code, that I've tried with my UNO, and it works as expected, but not the 328. I even tried another 328, but no change.
Any ideas as to what I'm missing??? It seems to be too simple, yet it doesn't work. :~
Just in case, here's my code:
int led = 9;
int myTimer;
void setup(){
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);
void loop(){
    for(int i=35; i > 0; i--){
      myTimer = i * 20;
        digitalWrite(led, HIGH);
      delay(myTimer);
      delay(myTimer);
I am willing to bet you may be putting the LED on the wrong chip pin.
I also wonder about your power supply? The Instructable suggests (under Option/Alternative #1) that any switching regulated supply from 5V to 16V is OK to use without a 5V regulator. Yikes!
It would be a good idea to put a resistor and LED on D13 (chip pin 19). The bootloader will flash this 3 times at startup whether or not a sketch is loaded. Provides a nice visual confirmation that the bootloader is present and working.
I'm also going to put in a plug for what I think is a particularly good ISP shield (I have no affiliation): http://evilmadscience.com/productsmenu/tinykitlist/253
The LED's can tell you a lot about what is, or isn't, happening.
Jim
smeezekitty:
I checked that about 27 times. And then another 2 more after reading your post.
I was hoping it was that simple, but not this time.
JimG: I also wonder about your power supply? The Instructable suggests (under Option/Alternative #1) that any switching regulated supply from 5V to 16V is OK to use without a 5V regulator. Yikes!
Jim
Okay, I do have the 5V regulator. I checked with my volt-meter, and I do have 4.98V feeding the circuit.
I used your idea with the LED on D13. It blinks, but doesn't stop after 3 blinks.
The ISP shield you mention looks really nice (and wish I'd seen that earlier), however, I would really like to get working what I've got. From everything I see on the web, there's no reason for it not to work.
Did you install a bootloader on the 328? How? Using the IDE?
Remember that digital pin 9 is probably not the same was physical pin 9.
