isPlaying() and disable option DF player as well as other discussions
Well . . Getting back after a long time in between an urgent project
In SD Card module we have audio.disable and audio.isPlaying() options
but in case of DF Player I am not able to find things like that
how we can go through such similar operations ??
Please guide !!
Sorry but what are You talking about? Read and mind this link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
please check this one
We'd love to help but are not sure what you are asking. Can you re-state your question so we will know what you're having trouble with?
Ya ok
Axtually I want the working of exactly the functions
Aidio.isplaying
Aidio.Disable
does
Incase of sd card module
But this time I want to apply the same function for a DF player unit
Major issue is ,on applying disable or isplaying it says that no such thing is present in DF player library
So I want to know that what is the actual thing I need to write in code to produce same fucntion
Here an exanple :-
For sd card module the play function is like
audio.play("001);
But the same play function for DFPlayer is
Player.play(1);
IN SAME WAY
Stop function for
sd module
Audio.stopPlayback();
For DF player
Its player.stop();
So now for audio.disable I want to know the same for DF player
Hope i explained to get understand easily
The following link shows how to control and how to query the DF player, there are a couple of products calling themselves DF player but have slight differences so this link may not be exactly for your player. DFPlayer_Mini_SKU_DFR0299-DFRobot
Yeah I am on it only in fact . . .
But there is nothing like that present here
As this disable stops internal clock in case of SD Card , it won't generate any small distortion type sound after we stop the player with command audio.disable();
In case of this DF Player a continue small level sound is present even after we simply stops the player
ans when connected to a PA system that small sound gets amplifies annoying people around
