ISR: expected constructor, destructor, or type conversion before '(' token
Hi all.
how to fix this error please?
Thanks
Adam
 //code copied from arduino.cc
int pulsePin = 43;                 // Pulse Sensor purple wire connected to analog pin A0
int blinkPin = 44;                // pin to blink led at each beat
// Volatile Variables, used in the interrupt service routine!
volatile int BPM;                   // int that holds raw Analog in 0. updated every 2mS
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false;     // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
static boolean serialVisual = true;   // Set to 'false' by Default.  Re-set to 'true' to see Arduino Serial Monitor ASCII Visual Pulse
volatile int rate[10];                      // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0;          // used to determine pulse timing
volatile unsigned long lastBeatTime = 0;           // used to find IBI
volatile int P = 512;                      // used to find peak in pulse wave, seeded
volatile int T = 512;                     // used to find trough in pulse wave, seeded
volatile int thresh = 525;                // used to find instant moment of heart beat, seeded
volatile int amp = 100;                   // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false;      // used to seed rate array so we startup with reasonable BPM
  pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
  Serial.begin(115200);             // we agree to talk fast!
  interruptSetup();                 // sets up to read Pulse Sensor signal every 2mS
                                    // IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
                                    // UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
                                    //   analogReference(EXTERNAL);
//  Where the Magic Happens
   serialOutput();
  if (QS == true) // A Heartbeat Was Found
      // BPM and IBI have been Determined
      // Quantified Self "QS" true when arduino finds a heartbeat
      serialOutputWhenBeatHappens(); // A Beat Happened, Output that to serial.
      QS = false; // reset the Quantified Self flag for next time
  delay(20); //  take a break
void interruptSetup()
  // Initializes Timer2 to throw an interrupt every 2mS.
  TCCR2A = 0x02;     // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
  TCCR2B = 0x06;     // DON'T FORCE COMPARE, 256 PRESCALER
  OCR2A = 0X7C;      // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
  TIMSK2 = 0x02;     // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
  sei();             // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
void serialOutput()
{   // Decide How To Output Serial.
 if (serialVisual == true)
     arduinoSerialMonitorVisual('-', Signal);   // goes to function that makes Serial Monitor Visualizer
      sendDataToSerial('S', Signal);     // goes to sendDataToSerial function
void serialOutputWhenBeatHappens()
 if (serialVisual == true) //  Code to Make the Serial Monitor Visualizer Work
     Serial.print(" Heart-Beat Found ");  //ASCII Art Madness
     Serial.print("BPM: ");
     Serial.println(BPM);
     sendDataToSerial('B',BPM);   // send heart rate with a 'B' prefix
     sendDataToSerial('Q',IBI);   // send time between beats with a 'Q' prefix
void arduinoSerialMonitorVisual(char symbol, int data )
  const int sensorMin = 0;      // sensor minimum, discovered through experiment
  const int sensorMax = 1024;    // sensor maximum, discovered through experiment
  int sensorReading = data; // map the sensor range to a range of 12 options:
  int range = map(sensorReading, sensorMin, sensorMax, 0, 11);
  // do something different depending on the
  // range value:
void sendDataToSerial(char symbol, int data )
   Serial.print(symbol);
   Serial.println(data);
ISR(TIMER2_COMPA_vect) //triggered when Timer2 counts to 124
  cli();                                      // disable interrupts while we do this
  Signal = analogRead(pulsePin);              // read the Pulse Sensor
  sampleCounter += 2;                         // keep track of the time in mS with this variable
  int N = sampleCounter - lastBeatTime;       // monitor the time since the last beat to avoid noise
                                              //  find the peak and trough of the pulse wave
  if(Signal < thresh && N > (IBI/5)*3) // avoid dichrotic noise by waiting 3/5 of last IBI
      if (Signal < T) // T is the trough
        T = Signal; // keep track of lowest point in pulse wave
  if(Signal > thresh && Signal > P)
    {          // thresh condition helps avoid noise
      P = Signal;                             // P is the peak
    }                                        // keep track of highest point in pulse wave
  //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
  // signal surges up in value every time there is a pulse
  if (N > 250)
  {                                   // avoid high frequency noise
    if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) )
        Pulse = true;                               // set the Pulse flag when we think there is a pulse
        digitalWrite(blinkPin,HIGH);                // turn on pin 13 LED
        IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
        lastBeatTime = sampleCounter;               // keep track of time for next pulse
        if(secondBeat)
        {                        // if this is the second beat, if secondBeat == TRUE
          secondBeat = false;                  // clear secondBeat flag
          for(int i=0; i<=9; i++) // seed the running total to get a realisitic BPM at startup
            rate[i] = IBI;
        if(firstBeat) // if it's the first time we found a beat, if firstBeat == TRUE
          firstBeat = false;                   // clear firstBeat flag
          secondBeat = true;                   // set the second beat flag
          sei();                               // enable interrupts again
          return;                              // IBI value is unreliable so discard it
      // keep a running total of the last 10 IBI values
      word runningTotal = 0;                  // clear the runningTotal variable
      for(int i=0; i<=8; i++)
        {                // shift data in the rate array
          rate[i] = rate[i+1];                  // and drop the oldest IBI value
          runningTotal += rate[i];              // add up the 9 oldest IBI values
      rate[9] = IBI;                          // add the latest IBI to the rate array
      runningTotal += rate[9];                // add the latest IBI to runningTotal
      runningTotal /= 10;                     // average the last 10 IBI values
      BPM = 60000/runningTotal;               // how many beats can fit into a minute? that's BPM!
      QS = true;                              // set Quantified Self flag
      // QS FLAG IS NOT CLEARED INSIDE THIS ISR
  if (Signal < thresh && Pulse == true)
    {   // when the values are going down, the beat is over
      digitalWrite(blinkPin,LOW);            // turn off pin 13 LED
      Pulse = false;                         // reset the Pulse flag so we can do it again
      amp = P - T;                           // get amplitude of the pulse wave
      thresh = amp/2 + T;                    // set thresh at 50% of the amplitude
      P = thresh;                            // reset these for next time
      T = thresh;
  if (N > 2500)
    {                           // if 2.5 seconds go by without a beat
      thresh = 512;                          // set thresh default
      P = 512;                               // set P default
      T = 512;                               // set T default
      lastBeatTime = sampleCounter;          // bring the lastBeatTime up to date
      firstBeat = true;                      // set these to avoid noise
      secondBeat = false;                    // when we get the heartbeat back
  sei();                                   // enable interrupts when youre done!
}// end isr
ERROR:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Arduino_HRS_a:113:5: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Xinzhou\Documents\Arduino\Arduino_HRS_a\Arduino_HRS_a.ino: In function 'void interruptSetup()':
Arduino_HRS_a:62:3: error: 'TCCR2A' was not declared in this scope
Arduino_HRS_a:63:3: error: 'TCCR2B' was not declared in this scope
Arduino_HRS_a:64:3: error: 'OCR2A' was not declared in this scope
Arduino_HRS_a:65:3: error: 'TIMSK2' was not declared in this scope
C:\Users\Xinzhou\Documents\Arduino\Arduino_HRS_a\Arduino_HRS_a.ino: At global scope:
Arduino_HRS_a:113:4: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
Invalid library found in C:\Users\Xinzhou\Documents\Arduino\libraries\esp-idf-2.0-master: no headers files (.h) found in C:\Users\Xinzhou\Documents\Arduino\libraries\esp-idf-2.0-master
Invalid library found in C:\Users\Xinzhou\Documents\Arduino\libraries\esp8266-oled-ssd1306-master: no headers files (.h) found in C:\Users\Xinzhou\Documents\Arduino\libraries\esp8266-oled-ssd1306-master
Invalid library found in C:\Users\Xinzhou\Documents\Arduino\libraries\T-Display-S3-main: no headers files (.h) found in C:\Users\Xinzhou\Documents\Arduino\libraries\T-Display-S3-main
Invalid library found in C:\Users\Xinzhou\Documents\Arduino\libraries\TTGO-T-Display-master: no headers files (.h) found in C:\Users\Xinzhou\Documents\Arduino\libraries\TTGO-T-Display-master
option enabled in File -> Preferences.
Odd, I do not get any errors compiling your code for an Arduino UNO.
Are you having problems compiling any other sketches?
Have you tried closing the Arduino IDE and restarting, possibly something has gotten corrupted.
Odd for me, and that compiling passed on another PC.
Thanks.
