Hallo,
wollte mir mal so eben eine Wetterstation bauen, Ausgangspunkt war folgende Anleitung ESP8266 Weather Station - with Wind and Rain Sensors | Tysonpower.de
wie ihr seht, nutzt der Entwickler einen Wemos D1 mini. Ich hingegen nutze einen NodeMcu Lolin V3
So weit so gut.
Also da beide ESP8266 sind, dachte ich , dass der Code kompatibel sein sollte.
#include "DHT.h"
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
// Setup
#define WIFI_AP "XXX" // AP SSID
#define WIFI_PASSWORD "XXXXX" // AP Password
char thingsboardServer[] = "192.68.176.2"; // Thingsboard Server
#define TOKEN "THINGSBOARD TOKEN" // Thingsboard token
#define INTERVAL 30 // Intervall of sending in seconds
// DHT
#define DHTPIN 2 // DHT pin
#define DHTTYPE DHT22
//info config
const String device_model = "\"WEMOS D1 mini 2.3.0\"";
const String software_version = "\"ESP8266_Wetterstation_MQTT - 1.0\"";
//weather sensors
const byte windSpeedPin = 13;
const byte windDirPin = A0;
const byte rainPin = 12;
WiFiClient wifiClient;
// Initialize DHT sensor.
DHT dht(DHTPIN, DHTTYPE);
PubSubClient client(wifiClient);
int status = WL_IDLE_STATUS;
unsigned int windcnt = 0;
unsigned int raincnt = 0;
unsigned long lastSend;
//////////////// SETUP //////////////////////////////////////////////
// pin for Wind speed
pinMode(windSpeedPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(windSpeedPin), cntWindSpeed, RISING);
pinMode(rainPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(rainPin), cntRain, RISING);
pinMode(windDirPin, INPUT);
dht.begin();
delay(10);
InitWiFi();
client.setServer( thingsboardServer, 1883 );
// send device attributes
if ( !client.connected() ) {
reconnect();
// Prepare a JSON payload string
String payload = "{";
payload += "\"Device\":"; payload += device_model; payload += ",";
payload += "\"Firmware\":"; payload += software_version; payload += ",";
payload += "\"Sensors\":"; payload += "DHT22 - Wind Speed";
payload += "}";
// Send the payload
char attributes[100];
payload.toCharArray( attributes, 100 );
Serial.println(payload);
client.publish( "v1/devices/me/attributes", attributes );
Serial.println("Send device attributes.");
lastSend = millis() - INTERVAL*1000;
//////////////// LOOP //////////////////////////////////////////////
// check connection
reconnect();
if ( millis() - lastSend > INTERVAL*1000 ) { // Update and send only after delay
getAndSendTemperatureAndHumidityData();
client.loop(); //keep connected, look for messages from server
//////////////// Functions //////////////////////////////////////////
void getAndSendTemperatureAndHumidityData()
Serial.println("Collecting Weather data.");
// Reading temperature or humidity takes about 250 milliseconds!
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
//Calculate Wind Speed (klicks/interval * 2,4 kmh)
float ws = (windcnt/INTERVAL) * 2.4;
windcnt = 0;
//Calculate Rain
float r = (raincnt/2)*0.2794;
raincnt = 0;
// get wind direction
float dirpin = analogRead(windDirPin)*(3.3 / 1023.0);
String wd = "other";
if(dirpin > 2.60 && dirpin < 2.70 ){
wd = "N";
if(dirpin > 1.60 && dirpin < 1.70 ){
wd = "NE";
if(dirpin > 0.30 && dirpin < 0.40 ){
wd = "E";
if(dirpin > 0.60 && dirpin < 0.70 ){
wd = "SE";
if(dirpin > 0.96 && dirpin < 1.06 ){
wd = "S";
if(dirpin > 2.10 && dirpin < 2.20 ){
wd = "SW";
if(dirpin > 3.15 && dirpin < 3.25 ){
wd = "W";
if(dirpin > 2.95 && dirpin < 3.05 ){
wd = "NW";
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
Serial.print("Windspeed: ");
Serial.print(ws);
Serial.print(" km/h ");
Serial.print("Wind Direction: ");
Serial.print(wd);
Serial.print(" ");
Serial.print("Rain: ");
Serial.print(r);
Serial.print(" mm ");
String temperature = String(t);
String humidity = String(h);
String windspeed = String(ws);
String winddir = String(wd);
String rain = String(r);
// Just debug messages
Serial.print( "Sending Data : [" );
Serial.print( temperature ); Serial.print( "," );
Serial.print( humidity ); Serial.print( "," );
Serial.print( windspeed ); Serial.print( "," );
Serial.print( winddir ); Serial.print( "," );
Serial.print( rain );
Serial.print( "] -> " );
payload += "\"temperature\":"; payload += temperature; payload += ",";
payload += "\"humidity\":"; payload += humidity; payload += ",";
payload += "\"windspeed\":"; payload += windspeed; payload += ",";
payload += "\"winddirection\":"; payload += winddir; payload += ",";
payload += "\"rain\":"; payload += rain;
payload += "}";
// Send payload
client.publish( "v1/devices/me/telemetry", attributes );
Serial.println( attributes );
lastSend = millis();
void InitWiFi()
Serial.println("Connecting to AP ...");
// attempt to connect to WiFi network
WiFi.begin(WIFI_AP, WIFI_PASSWORD);
WiFi.mode(WIFI_STA);
Serial.print(".");
Serial.println("Connected to AP");
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
status = WiFi.status();
if ( status != WL_CONNECTED) {
Serial.print(".");
Serial.print("Connecting to ThingsBoard node ...");
// Attempt to connect (clientId, username, password)
if ( client.connect("ESP8266 Device", TOKEN, NULL) ) {
Serial.println( "[DONE]" );
Serial.print( "[FAILED] [ rc = " );
Serial.print( client.state() );
Serial.println( " : retrying in 5 seconds]" );
// Wait 5 seconds before retrying
delay( 5000 );
// Interupts
void cntWindSpeed() {
windcnt++;
void cntRain() {
raincnt++;
Allerdings hat mich nach den flashen im seriellen Monitor folgendes in dauerschleife erwartet:
0000 3ffee688 40204a5f
3fffffb0: feefeffe feefeffe 3ffe84f0 40100f6d
<<<stack<<<
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
ISR not in IRAM!
User exception (panic/abort/assert)
Abort called
>>>stack>>>
Nun weiß ich leider nicht mehr weiter und hoffe auf einen Hinweis.
Gruß
Thomas
