ISR on NANO is not started
I’m trying to get the demo ISR program to work on a NANO board. The code compiles and downloads OK. I have verified that the code runs by turning on the LED. However, it appears that the interrupt service routine is not activated.
bool ledOn = false;
const unsigned long TIME_TICKS = 2000; // for 100 ms interrupts at 48 MHz
const bool PRESCALER = B00000011; // Prescaler of 64
const bool ENABLE_ISR = B00000010; // Enable the ISR to generate an interrupt
ISR (TIMER1_COMPA_vect)
    ledOn = !ledOn;   // toggle led
    if (ledOn) {
      digitalWrite(LED_BUILTIN, HIGH);
      digitalWrite(LED_BUILTIN, LOW);
} // End of ISR
//  flash the LED at the interrupt rate
  pinMode(LED_BUILTIN, OUTPUT);
  ledOn = false;
  TCCR1A = 0;           // Init Timer1A
  TCCR1B = 0;           // Init Timer1B
  TCCR1B |= PRESCALER;  // Set Prescaler
  OCR1A = TIME_TICKS;   // Timer Compare1A Register
  TIMSK1 |= ENABLE_ISR; // Enable Timer COMPA Interrupt
  // set up main function here
Change
bool ledOn = false;
to
volatile bool ledOn = false;
Change
to
const uint8_t PRESCALER = B00000011; // Prescaler of 64
const uint8_t ENABLE_ISR = B00000010; // Enable the ISR to generate an interrupt
Thanks for your help! That fixed the problem. I'll pay more attention to the constants and their types in the future.
Probably not necessary, since there isn't a ISR vs main path conflict.
This however is quite important. Assigning any non-zero value to a "bool" will result in a value of 1 (true), so you'll have the wrong bit pattern.
Also not that you probably don't want "normal" mode (TCCR1A = 1B = 0), since that won't reset the count when you hit the match; the counter will keep going until it overflows. (OTOH, a count of 2000 won't be visible to the human eye.)
Thanks for the clarification. My actual interrupt will be set for 10ms.
