ISR problem... On MEGA using timer5 COMPA actives but not B or C
I am using these ISRs in a different program I am writing. TIMER5_COMPA is firing correctly and entering the ISR. However, B and C will not. BTW this is not actually being used to toggle pins. That is just what I am using to debug the ISRs. COMPA is running some code that I need to run at 400Hz and is working great. I am already using timer 1,3, and 4 for PWM generation.
#define D22Output() DDRA |= 1<<0
#define D22High() PORTA |= 1<<0
#define D22Low() PORTA &= ~(1<<0)
#define D22Toggle() PORTA ^= (1<<0);
#define D23Output() DDRA |= 1<<1
#define D23High() PORTA |= 1<<1
#define D23Low() PORTA &= ~(1<<1)
#define D23Toggle() PORTA ^= (1<<1);
#define D24Output() DDRA |= 1<<2
#define D24High() PORTA |= 1<<2
#define D24Low() PORTA &= ~(1<<2)
#define D24Toggle() PORTA ^= (1<<2);
void setup(){
  D22Output();
  D23Output();
  D24Output();
  Timer5Setup();
void loop(){
ISR(TIMER5_COMPA_vect){
  D22Toggle();
ISR(TIMER5_COMPB_vect){
  D23Toggle();
ISR(TIMER5_COMPC_vect){
  D24Toggle();
void Timer5Setup(){
  TCCR5A = (1<<COM5A1);
  TCCR5B = (1<<CS51)|(1<<WGM52);
  TIMSK5 = (1<<OCIE5A)|(1<<OCIE5B)|(1<<OCIE5C);
  OCR5A = 5000;
  OCR5B = 50000;
  OCR5C = 50000;
I have tried doing this to see if I can at least get TIMER5_COMPB to fire and it does not work:
void setup(){
  D23Output();
  Timer5Setup();
void loop(){
  D23Toggle();
void Timer5Setup(){
  TIMSK5 = (1<<OCIE5B);
  OCR5B = 50000;
Hopefully someone can shed some light on why my ISRs are working correctly. Thanks in advance.
You have set the timer mode to CTC with TOP = OCR5A.
In this mode, when the timer reaches the OCR5A value, it resets to 0.
OCR5B and OCR5C in your example are a higher number than OCR5A, so they will never be fired.
In your second example, you don't set OCR5A, so it will have a default value of 0, meaning OCR5B is still larger than OCR5A.
Thank you that makes sense.
