ISR Setup causing reset in latest version of Arduino IDE ... help?
I'm trying to update the arduino software on this device we are using. Downloaded the latest development environment and built for my target. Compiles, no problem. But when I load code the device just continuously resets.
I managed to tear everything down and isolate the problem to the setup function. Looks like it is occurring somewhere between disable interrupt, setup interrupt registers and re-enabling interrupts.
NOW, the interesting thing is, this problem does not occur in the Arduino 1.0.x IDE, but it does occur with the latest official build as well as the nightly build. All of which are the 64bit linux version, if that makes any difference.
Best I can make out, updates to interrupt.h or another include have brought out an error in how things are setup. I could spend a good amount of time digging through this, but was hoping someone w/ a trained eye could spot any mistakes in the code below:
.... some other stuff here....
__ // *** INITIALIZE TIMER INTERRUPTS ******************************************__
** // Disable interrupts**
** cli();**
** // Clear timer1 control registers**
** TCCR1A = 0;**
** TCCR1B = 0;**
** // Initialize counter to 0 **
** TCNT1 = 0; **
** // Set compare match register to default sample rate**
__ OCR1A = 16000000 / (sampleRate * 1024) - 1;__
** // Turn on CTC Mode**
** TCCR1B |= (1 << WGM12);**
** // Set prescaler to 1024**
** TCCR1B |= (1 << CS12) | (1 << CS10);**
** // Enable timer compare interrupt**
** TIMSK1 |= (1 << OCIE1A);**
** // Clear timer2 control registers**
** TCCR2A = 0;**
** TCCR2B = 0;**
** // Initialize counter to 0**
** TCNT2 = 0;**
** // Set compare match register for sample rate of 1000Hz**
** OCR2A = 250;**
** OCR2B = 250;**
** TCCR2B |= (1 << WGM22);**
** // Set prescaler to 64**
** TCCR2B |= (1 << CS22) | (0 << CS21) | (0 << CS20);**
** TIMSK2 |= (1 << OCIE2A);**
** // Enable interrupts**
** sei();**
You do not have a handler for one or both of the interrupts you enable.
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the "Code" icon above the posting area. It is the first icon, with the symbol: </>
As Coding Badly points out, you don't have ISR handlers for those interrupts. And the default behaviour is to jump to the reset vector.
