Guys, does anyone have an example of how I configure the timer to generate an interrupt every 1 second.
Which processor? Which timer?
I have a program that reads the pulses received on a pin through an interrupt and counts them. This part works well.
I made a routine using millis() to display the count value every 1 second and reset it to zero. It works well too.
But unfortunately I had to add some delay() at some point in the program, which causes the routine using millis() to sometimes be executed well after 1s.
So I would like to learn how to use the timer, I don't know which one to generate an interrupt every 1s.
Arduino UNO 16MHz
I would like to do this if I use a library.
I don't know which timer the Arduino UNO uses for the delay() and millis() function and also which timer the PWM uses. So I'm afraid of changing some timer that I shouldn't
Timer0. PWM uses Timers 1 and 2.
- This is 99.9% never necessary.
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch.
Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
Code?
How close to a second is close enough?
Re:
Getting rid of the delay will likely pay off, and then you might not need an interrupt.
If you still want an interrupt, this trick takes advantage of the already-configured timer0 to give free 976.5625Hz interrupts:
Precision is not very important, as the number of pulses I will receive in one second will not be greater than 50, so if in one second I have 49, 50, 51 pulses counted in one second it will not be a problem.
Well, here's the Adafruit timer0 multitasking example modified to do the guts of BlinkWithoutDelay inside an ISR:
// using an interrupt to do a 1 second process
// https://wokwi.com/projects/396818172976688129
// Built from
// https://learn.adafruit.com/multi-tasking-the-arduino-part-2/timers
// modified to do the code work of Blink without delay inside an ISR
// https://docs.arduino.cc/built-in-examples/digital/BlinkWithoutDelay/
const int ledPin = LED_BUILTIN; // the number of the LED pin
const long interval = 1000; // interval at which to blink (milliseconds)
byte ledState = LOW; // ledState used to set the LED
volatile unsigned long previousMillis = 0; // will store last time LED was updated
pinMode(ledPin, OUTPUT);
// Timer0 is already used for millis() - we'll just interrupt somewhere
// in the middle and call the "Compare A" function below
OCR0A = 0xAF; // TIMER0_COMPA_ value
TIMSK0 |= _BV(OCIE0A); // enable TIMER0_COMPA_vect ISR
// Interrupt is called about once a millisecond,
ISR(TIMER0_COMPA_vect)
// This is the main part of BWOD,
// check to see if it's time to blink the LED; that is, if the difference
// between the current time and last time you blinked the LED is bigger than
// the interval at which you want to blink the LED.
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
previousMillis += interval; // update timestamp and account for slippage
// previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
Would this work? Doesn't use interrupts. But then, why? If you don't need 'em.
