Issue compiling marlin firmware "expected primary expression ')' before token"
Arduino: 1.8.12 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch\Marlin_main.cpp:2108:36: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
LCD_MESSAGEPGM(MACHINE_NAME" "MSG_OFF".");
In file included from sketch\Marlin.h:21:0,
from sketch\Marlin_main.cpp:30:
sketch\Marlin_main.cpp: In function 'void setup_powerhold()':
fastio.h:32:37: error: expected primary-expression before ')' token
#define _WRITE_C(IO, v) do { if (v) { \
sketch\fastio.h:45:80: note: in expansion of macro '_WRITE_C'
#define _WRITE(IO, v) do { if (&(DIO ## IO ## _RPORT) >= (uint8_t *)0x100) {_WRITE_C(IO, v); } else {_WRITE_NC(IO, v); }; } while (0)
sketch\fastio.h:68:23: note: in expansion of macro '_WRITE'
#define WRITE(IO, v) _WRITE(IO, v)
sketch\Marlin_main.cpp:411:4: note: in expansion of macro 'WRITE'
WRITE(PS_ON_PIN, PS_ON_AWAKE);
fastio.h:30:37: error: expected primary-expression before ')' token
#define _WRITE_NC(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
sketch\fastio.h:45:105: note: in expansion of macro '_WRITE_NC'
sketch\Marlin_main.cpp: In function 'void set_bed_level_equation_lsq(double*)':
sketch\Marlin_main.cpp:873:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
planeNormal.debug("planeNormal");
sketch\Marlin_main.cpp: In function 'void process_commands()':
sketch\Marlin_main.cpp:2072:9: note: in expansion of macro 'WRITE'
Marlin_main.cpp:2104:26: error: 'PS_ON_ASLEEP' was not declared in this scope
WRITE(PS_ON_PIN, PS_ON_ASLEEP);
sketch\fastio.h:32:36: note: in definition of macro '_WRITE_C'
sketch\Marlin_main.cpp:2104:9: note: in expansion of macro 'WRITE'
sketch\fastio.h:30:36: note: in definition of macro '_WRITE_NC'
sketch\Marlin_main.cpp: In function 'void clamp_to_software_endstops(float*)':
Marlin_main.cpp:3326:7: error: 'min_software_endstops' was not declared in this scope
if (min_software_endstops) {
Marlin_main.cpp:3332:7: error: 'max_software_endstops' was not declared in this scope
if (max_software_endstops) {
exit status 1
option enabled in File -> Preferences.
Just clone the latest code from github (2.0.6) and it compiled fine (although tons of warnings which doesn't indicate a good code quality).
So I guess you either got an older code version or configured your IDE incorrectly.
