I'm having a problem connecting / uploading new code to my arduino. I had it all working, and then all of the sudden I would get something like serial port not found. I checked everything out, made sure everything was still plugged in properly and such, and it seems to be. Now, I don't even get that though, I get "error opening serial port /dev/ttyUSB0". I checked to make sure that was the right one by disconnecting it and reconnecting it, and then it gets moved to USB1, so that seems right (and there's no other ttyUSB in /dev/). I've also tried rebooting, and didn't have any luck there either (both the PC and resetting the 'duino).
Here's the stack trace from the console:
Couldn't determine program size:
processing.app.SerialException: Error opening serial port '/dev/ttyUSB0'.
at processing.app.Serial.<init>(Serial.java:142)
at processing.app.Serial.<init>(Serial.java:72)
at processing.app.Uploader.flushSerialBuffer(Uploader.java:66)
at processing.app.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:73)
at processing.app.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:48)
at processing.app.Sketch.upload(Sketch.java:1632)
at processing.app.Sketch.exportApplet(Sketch.java:1701)
at processing.app.Editor$41.run(Editor.java:2004)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: gnu.io.UnsupportedCommOperationException: Invalid Parameter
at gnu.io.RXTXPort.setSerialPortParams(RXTXPort.java:171)
at processing.app.Serial.<init>(Serial.java:132)
... 15 more
If it matters, I'm running Ubuntu 8.10 x64 w/ the newer version of gcc-avr (4.3.2), and I followed all the other ubuntu specific instructions, like making it so that the ide was using the x64 jars..
