Issue getting data into database from DS1820 temperture sensors
I am try to get my DS1820 temperature sensor addresses in to a mysql database.
I can get all the required field entries I require, temperature, but for the address I can only get the last 2 digits of the address into the database. :frowning:
This is the function I have created. I am only using 2 temperature sensors.
addresses are 28DCBD4903000093 and 28B59A490300006F
I am wondering if this has to do with the webClient.print() and something else needs to be added like a char array??
the column in the database is set to Name: TempTag, Type: varchar(16), not null.
In the database column I get 93 or 6F
which is making me very confused…
/* Function */
void writeAddress( DeviceAddress deviceAddress )
if( deviceAddress == insideThermometer )
Serial.println( “inside” );
for( uint8_t i = 0; i < 8; i++ )
if( deviceAddress[ i ] < 16 )
Serial.println( “0” );
webClient.print( “0” );
webClient.print( “&TempAddress0=” );
webClient.print( deviceAddress[ i ], HEX );
else if( deviceAddress == outsideThermometer )
Serial.println( “outside” );
for(uint8_t j = 0; j < 8; j ++ )
if( deviceAddress[ j ] < 16 )
webClient.print( “&TempAddress1=” );
webClient.print( deviceAddress[ j ], HEX );
I rather suspect that this:
webClient.print( "&TempAddress0=" );
should be before the for loop, not inside it.
Well spotted bill!
also true for - webClient.print( "&TempAddress1=" ); -
Thanks you so much I just tried it out now and I can see the entries in my database tables .... it works!!!!! :) I9 really appreciate the help thanks
maybe you can post the whole code (arduino & mysql side) so people in the future can find it.
