Issue getting two numbers to display on LCD to then recall on
Hi fellow arduino lovers.
Im using an Arduino Mega for a project where I need to display a welcome message on an LCD, then when a number (1-32) gets entered it is displayed upon the lcd with a new message (you have selected machine number '0' press s to continue).
my initial code was the following:
//libraries//
#include <Wire.h>
#include <Keypad.h>
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 16 chars and 2 line display
//ints that will remain constant//
const int delayTime= 4000; //sets delay time for 4 seconds
const int delayTime2 = 30000; //sets delay time for 30 seconds
const int delayTime3 = 80; //sets delay time for 80 milli seconds
const int buzzer = 50;
int red = 52;
int yellow = 53;
int green = 51;
//Pull up code to check on previous transactions//
char lasttrans = "60"; //code to initiate last transactions
int currentPosition = 0;
char previous = "S";  //goes to previous transaction
char next = "C";     // goes to next transaction
byte value=0;
//Timer to check on inactivity and perform reset//
unsigned long previousMillis = 0;        // will store last time lcd
const long interval = 60000;           // interval at which to blink (milliseconds)
const long timer = 4000;
//Strings for all lcd text//
String welcome="Welcome to";
String shop="Shop Name";
String please="Please Select";
String machine="Machine Number";
String select="You have selected";
String option="Press S to continue";
//keypad set up for a 4x3 keypad
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'S','0','C'}
byte rowPins[ROWS] = {8,7,2,3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6,5,4}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
//start up of running code//
  lcd.init(); // initialize the LCD
  lcd.backlight(); // turns on LCD backlight
  Serial.begin(9600); //initialize the serial monitor
  pinMode (green, OUTPUT);
  pinMode (yellow, OUTPUT);
  pinMode (red, OUTPUT);
  pinMode(buzzer, OUTPUT);
  displayWelcomeScreen();
   char key = keypad.getKey(); //gets key press from keypad
   int value = 0;
    if (key != NO_KEY && key != 'S') //if key pressed then
     if (key >= '0' && key <= '9') //if key pressed is between 0 and 9 then maths equation to determin value,
       value = value *10;
       value = value + key - '0';
     Serial.println(value);
     lcd.clear();
     digitalWrite (red, LOW);
     lcd.setCursor(1,0);   //prints out the machine selected for confirmation (allows for changes)
     lcd.print(select);
     lcd.setCursor(3,1);
     lcd.print(machine);
     lcd.setCursor(9,2);
     lcd.print (value);
     lcd.setCursor(0,3);
     lcd.print (option);
     digitalWrite (yellow, HIGH);
  if(key == 'S')// if S (yes) it will confirm selection and ask for money at vend price
     lcd.clear();
     digitalWrite (yellow, LOW);
     digitalWrite (green, HIGH);
     lcd.setCursor(0,0);
     lcd.print ("********************");
     lcd.setCursor(0,1);
     lcd.print ("***  Please pay  ***");
     lcd.setCursor(0,2);
     lcd.print ("***  Vend price  ***");
     lcd.setCursor(0,3);
    if (key == 'C')//if C (no) it will cancel and go back to beginning.
      lcd.clear();
      tone(buzzer, 1000); // Send 1KHz sound signal...
      delay(1000);        // ...for 1 sec
      noTone(buzzer);     // Stop sound...
      digitalWrite (green, LOW);
      digitalWrite (red, HIGH);
      unsigned long currentMillis = millis();  // if no action after 60 seconds it will reset to beginning
   if (currentMillis - previousMillis >= interval)
    if (int(key)==NO_KEY)
      lcd.clear();
  void displayWelcomeScreen ()
    lcd.clear();
    lcd.setCursor(4,0);
    lcd.print(welcome);
    lcd.setCursor(4,1);
    lcd.print(shop);
    lcd.setCursor(3,2);
    lcd.print(please);
    lcd.setCursor(3,3);
    lcd.print(machine);
Currently Whenever I press a number, it will display on the screen correctly, however it will only display 0-9.
I can't seem to get it to display double digits such as 10-32 etc.
if i type 1 (1 appears) followed by a 0 (the 1 gets replaced by 0)
my purpose for this is I want to assign a monetary value in GBP to each number and am unable to do so unless I can get two digits working.
The other issue i have is that I want to store the selected number(s) when i press 'S' on the keypad to confirm the selection. This would then allow me to jump to the code where I can assign the monetary value for that machine, however I am having difficulty coding that to work.
I have tried an alternate code using while/switch statements which also runs into the exact same issues as the previous code :
    v1 = GetNumber();
    v1.toInt();
    Serial.println(v1);
    v2 = GetNumber();
    v2.toInt();
    Serial.println(v2);
    int  GetNumber()
      int num = 0;
      while(key != 'S')
         switch (key)
            case NO_KEY:
            case '0': case '1': case '2': case '3': case '4':
            case '5': case '6': case '7': case '8': case '9':
            lcd.clear();
            lcd.print(select);
            lcd.setCursor(3,1);
            lcd.print(machine);
            lcd.setCursor(9,2);
            lcd.print (key);
            num = num * 10 + (key - '0');
            lcd.setCursor(0,3);
            lcd.print (option);
            case 'C':
            num = "";
            lcd.clear();
            displayWelcomeScreen ();
   return num;
    lcd.clear();
    lcd.setCursor(4,0);
    lcd.print(welcome);
    lcd.setCursor(4,1);
    lcd.print(shop);
    lcd.setCursor(3,2);
    lcd.print(please);
    lcd.setCursor(3,3);
    lcd.print(machine);
i have searched multiple forum posts, and tried everything i can think of, but I am rather new with this type of stuff. Anyone who could point me in the right direction or knows what i am missing would be helping me out loads.
I appreciate you taking the time to read this.
Thankyou
char lasttrans = "60"; You can't put a string into a single char.
Didn't the compiler complain?
It didn't complain, but then again I haven't tried to use that in any part of the code, it would have been for future use, but I appreciate the advice on that.
squaidskun:
   v1 = GetNumber();
   v1.toInt();
   Serial.println(v1);
   v2 = GetNumber();
   v2.toInt();
   Serial.println(v2);
That code is converting your Strings to integers and then discarding the result.
String s = "111";
int v = s.toInt();
Correct me if im wrong, im just trying to understand this code you posted and what it would be used for?
String s = "111";
int v = s.toInt();
if im understanding correctly i need a separate string, this will read multiple keypad inputs? then it will take that number, covert it into an int, which then i can use to print to lcd? So i would do something like.
String s = String ('0');
int v = s.toInt();
serial.println (int v);
Your GetNumber()
   int  GetNumber()
is returning an int so no need to convert it to an int as it is already one.
squaidskun:
String s = "111";
int v = s.toInt();
I was just showing you how to properly use the toInt() method in the String class. Your code didn't assign the return value is it was pointless.
