Hello everyone,
I am using the new development board called ARIES IoT. This board is built upon a RISC-V ISA compliant VEGA Processor. I did the necessary changes in BLELocalDevice::begin() function to initialise all the pins. I am trying peripheral/LED example to control a built-in LED with nRF Connect app.
It is working when I put some print messages before HCITransport.write() function call in HCIClass::sendCommand() function. I tried to replace the print statements with delay but it is not working that way.
HCIClass::sendCommand() Function:
int HCIClass::sendCommand(uint16_t opcode, uint8_t plen, void* parameters)
struct __attribute__ ((packed)) {
uint8_t pktType;
uint16_t opcode;
uint8_t plen;
} pktHdr = {HCI_COMMAND_PKT, opcode, plen};
uint8_t txBuffer[sizeof(pktHdr) + plen];
memcpy(txBuffer, &pktHdr, sizeof(pktHdr));
memcpy(&txBuffer[sizeof(pktHdr)], parameters, plen);
if (_debug) {
dumpPkt("HCI COMMAND TX -> ", sizeof(pktHdr) + plen, txBuffer);
#ifdef _BLE_TRACE_
Serial.print("Command tx -> ");
for(int i=0; i< sizeof(pktHdr) + plen;i++){
Serial.print(" 0x");
Serial.print(txBuffer[i],HEX);
Serial.println("");
#endif
Serial.println(__LINE__);
// delayMicroseconds(1389);
// Serial.println();
delay(1);
HCITransport.write(txBuffer, sizeof(pktHdr) + plen);
_cmdCompleteOpcode = 0xffff;
_cmdCompleteStatus = -1;
for (unsigned long start = millis(); _cmdCompleteOpcode != opcode && millis() < (start + 1000);) {
poll();
return _cmdCompleteStatus;
I am using the latest ArduinoBLE library.
I added following lines in begin():
pinMode(SPIWIFI_SS, OUTPUT);
pinMode(NINA_RESETN, OUTPUT);
digitalWrite(SPIWIFI_SS, LOW);
digitalWrite(NINA_RESETN, LOW);
delay(100);
digitalWrite(NINA_RESETN, HIGH);
delay(750);
// set SS HIGH
digitalWrite(SPIWIFI_SS, HIGH);
// set RTS HIGH
pinMode(NINA_RTS, OUTPUT);
digitalWrite(NINA_RTS, HIGH);
// set CTS as input
pinMode(NINA_CTS, INPUT);
Baudrate is 115200
