issue in programming
Dears,
I used in my project android and bluetooth to control RGB strip 5050 , the first question is 5050 strip has a moving light like addressable rgb , the second question my code of arduino is
#include <SoftwareSerial.h>
SoftwareSerial BT(10, 11);
String color;
BT.begin(9600);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
while (BT.available()){
delay(10);
char c = BT.read ();
color += c;
if (color.length() > 0) {
Serial.println(color);
if (color == "blue")
digitalWrite(2, HIGH);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
delay(20);
else if (color == "green")
digitalWrite(2, LOW);
digitalWrite(3, HIGH);
delay(20);
else if (color == "red")
digitalWrite(4, HIGH);
delay(20);
else if (color == "stop")
delay(20);
else if (color == "Flash")
my question in the last part ( when color is Flash ) , flash word comes from android through bluetooth to apply blue then off then green then off then red then off but and wants to stay flasher blue , green and red , blue , green and red etc... not just once but if i press for example stop button from my android and want it to stop not stay flashing , so how i can do this
thank you
You are always adding characters to the end of 'color'. If you send "blue" then "Flash" then "stop" your color will be "blueFlashstop" and that won't match any of the choices.
The following two articles can be worth reading.
Serial input basics
Demonstration code for several things at the same time
Also, please read articles #2 and #3 at the top of this Forum by Nick Gammon on the proper way to post code here. It will help us help you.
