Team, I really need help as this is driving me nuts and do not know where is the issue.
I'm building an application with Arduino, I have 2 files
The first one is the configuration file I should read and update when config changes
The second one is a swap file to handle text I receive from a modem.
The program does this:
- open config file and read
- wait for modem to start
- gather the list of messages and save them in the swap file
Both files are opened and closed every time.
The swap file is deleted if exists before being opened
Now: 1) always work, file is read correctly
3) always fails!
I tried to change SD card, to change library from SD to SDFat, to change code and order, to use 2 different file handles to avoid conflicts...
but no way!
Once every 100000000 times 3 works
and saves the file (thus it makes me think is not an issue on the code)
Can you help me?
Note to leave more power to Arduino Serial is at 4800 and AltSerial is at 2400 (so they should not impact all the rest)
Connection between SD shield and Arduino Pro Mini is on 10-11-12-13 as per design
Even with a super simple sketch that opens the first file and read and then opens the second one and writes I get a lot of errors:
Initializing SD card...initialization done.
loop numMsg : 354
loop msgAtt : 0
loop numCell : 01234556789012
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop finished writing - Process File
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files DOES NOT exists
loop aFileT 0
loop ERROR open file
loop File Error
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop aFileT 0
loop File Error
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
here the sketch:
SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 10
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#define SD_CS_PIN SS
#include <SPI.h>
#include <SdFat.h>
SdFat SD;
File aFileS; // global File handle. Only one file at time can be opened on arduino
File aFileT; // global File handle. Only one file at time can be opened on arduino
#define c_FileName "d.bin" // filename of the data file
#define c_TempName "t.bin" // filename of the data file
#define c_NumMsg 0
#define c_MsgAtt 3
#define c_NumCell 6
#define c_NUMCELL_SIZE 14 // Phone number size
int numMsg; // total number of messages
int msgAtt; // last read message - starting from 1. First 160 byte of file reserved for other variables
char numCell[c_NUMCELL_SIZE]; // send to cell number
Serial.begin(4800);
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(SD_CS_PIN)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
aFileS = SD.open(c_FileName);
// if the file is available, write to it:
if (aFileS) {
aFileS.seek(c_NumMsg);
numMsg = word(aFileS.read(), aFileS.read());
Serial.print(F("loop\tnumMsg : ")); Serial.println(numMsg);
aFileS.seek(c_MsgAtt);
msgAtt = word(aFileS.read(), aFileS.read()); // default, init value is 0.
Serial.print(F("loop\tmsgAtt : ")); Serial.println(msgAtt);
aFileS.seek(c_NumCell);
memset(numCell, 0, c_NUMCELL_SIZE);
for (int ai = 0; ai < c_NUMCELL_SIZE; ai++)
numCell[ai] = aFileS.read();
numCell[c_NUMCELL_SIZE] = 0;
Serial.print(F("loop\tnumCell : ")); Serial.println(numCell);
else {
Serial.println(F("loop File Error"));
aFileS.close();
if (SD.exists(c_TempName)) {
Serial.println(F("loop\tfiles exists"));
if (SD.remove(c_TempName)){
Serial.println(F("loop\tfiles removed"));
else {
Serial.println(F("loop\tERR files not removed"));
else{
Serial.println(F("loop\tfiles DOES NOT exists"));
delay(10);
aFileT = SD.open(c_TempName, FILE_WRITE);
Serial.print(F("loop\taFileT\t")); Serial.println(aFileT);
if (aFileT) { //if data file exists
Serial.println(F("loop\tready to write"));
for (int ai = 0; ai < 50; ai++)
aFileT.println(ai);
aFileT.close();
delay(10);
Serial.println(F("loop\tfinished writing - Process File"));
else {
Serial.println(F("loop\tERROR open file"));
What are you using for an SD shield/module?
I created a dummy d.bin file and your program seems to run fine forever without error.
Here is the content of t.bin as text
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
I have a Catalex MicroSD Card Manager v1.0 11/01/2013
with a microSD:
init time: 690 ms
Card type: SD1
Manufacturer ID: 0X1A
OEM ID: PQ
Product: MS
Version: 1.0
Serial number: 0X9B046118
Manufacturing date: 10/2007
cardSize: 513.28 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
OCR: 0X80FF8000
SD Partition Table
part,boot,type,start,length
1,0X0,0X6,233,1001719
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
Volume is FAT16
blocksPerCluster: 32
clusterCount: 31295
freeClusters: 31290
freeSpace: 512.66 MB (MB = 1,000,000 bytes)
fatStartBlock: 234
fatCount: 2
blocksPerFat: 123
rootDirStart: 480
dataStartBlock: 512
still no luck
Now is even worst.
The file is CANCELLED but this is the log:
loop numMsg : 354
loop msgAtt : 0
loop numCell : 00393346932755
loop files exists
and the code is the same: loop
It deadlocks on the remove file!
Changed the SD card... even worst:
loop numMsg : 354
loop msgAtt : 0
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop files exists
loop files removed
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 1
loop ready to write
loop numMsg : 354
loop msgAtt : 0
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
loop aFileT 0
loop File Error
