HI,
im trying to use a IR Led and receiver to count the rpms of a fan, i have it all wired up but im getting no information through to the infrared photo transistor, im using an elegoo uno R3
ill put my code below
[code]
int photo_i_p = 2;
int loop_no = 0;
int time_sec = 0;
int input_value = 0; // digital input signal either on / off 0 or 1
int currentState = 0;
int previousState = 0; // set up input and count variables, -32768 to 32767
float pot_i_p ;
float voltScaled ;
float period = 2000; // using millis() is mS
float physCount = 0;
float blades_sec ;
float set_rev_sec ;
float fb_rev_sec ; // feed back photo_i_p optic sense
float elapse ;
float start ;
pinMode(photo_i_p, INPUT) ; // declare i/p could avoid this set as default
pinMode(10, OUTPUT);
Serial.begin(9600) ;
delay(1000) ; // delay to start
Serial.println("");
Serial.println(" Oct 2019 ");
Serial.println(" ");
Serial.println(" set feed back");
Serial.println(" sec rev/s rev/s ");
start = millis(); // mS since program started
} // setup
// section 1/ potentiometer input leading to PWM output
pot_i_p = analogRead(A1); // read volts pin A1 = physical pin #15 (0-5.0 volts)
voltScaled = (pot_i_p / 665) * 250; // scaled for 0-1023 from 0-5.0 volt
set_rev_sec = voltScaled / 3.5 + 16.07;
analogWrite(10, voltScaled);
// section 2/ measure rotational speed
// a/ single pulse debounce & count, increments as a result of single cycle input
input_value = digitalRead(photo_i_p);
if (input_value == HIGH)
currentState = 1;
currentState = 0;
if (currentState != previousState)
if (currentState == 1)
physCount ++;
previousState = currentState;
// b/ n-second sampling period, rpm calculation
elapse = millis() - start ; // elapse = millis(current) – millis(start of programme) mS
if (elapse > period) // period set in declarations above
blades_sec = physCount * 1000 / period ; // use thousands as no decimal
fb_rev_sec = blades_sec / 7.0 ; // true feedback speed from 7 fan
// blades
loop_no ++ ; time_sec = loop_no * period / 1000;
// start = millis(); // reset timer
physCount = 0; //physical counter reset for new sample period
displayResult(); // call output routine
} // loop return
// section 3/ display on monitor
void displayResult()
Serial.print(" ");
Serial.print(time_sec);
Serial.print(" ");
Serial.print(set_rev_sec); // from potentiometer scaled
Serial.print(" ");
Serial.print(fb_rev_sec);// from photo-diode
} // display
thanking you
Also putting a schematic or at least a labeled block diagram would be of great help.
Have you verified the IR LED is working?
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please go back and fix your original post.
Photos that clearly show your wiring can also be very helpful.
