Issue to adapt a function regarding my code
Dear All,
I am sorry to bore you but I would really appreciate if you can help me do adapt that function. After this, I hope :), I will be able to continue.
It would be very nice from you.
I have to adapt a sendATcommand() function to get the answer.
First let me show you again how I started my library.
Sim908.h
  Sim908.h - Library
#ifndef Sim908_h
#define Sim908_h
#include <SoftwareSerial.h>
#include "Arduino.h"
class Sim908{
	private:
		int _pinToPowerOnModule;
		//Stream* _cell;
		SoftwareSerial* _cell;
		int _debug;
	public:
		Sim908(SoftwareSerial* serial, int baud_rate, int pinToPowerOnModule, int debug);
		void powerOnSim908();
		int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout);
		void blinkLed(int lPin, int nBlink, int msec);
#endif
For Sim908.cpp, I do not copy all code because it work. I just copy the two concerned function and the constructor. The first is just because it contain the call to sendATcommand(“AT”, “OK”, 2000);
The problem is int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout);
// Contructor
Sim908::Sim908(SoftwareSerial* serial, int baud_rate, int pinToPowerOnModule, int debug)
	pinMode(pinToPowerOnModule, OUTPUT);
	_pinToPowerOnModule = pinToPowerOnModule;
	_cell = serial;
	_debug = debug;
	serial->begin(baud_rate);
[... code...]
// Look at sendATcommand("AT", "OK", 2000);
void Sim908::powerOnSim908(){
   uint8_t answer=0;
    digitalWrite(_pinToPowerOnModule,HIGH);
    delay(3000);
    digitalWrite(_pinToPowerOnModule,LOW);
	if(_debug){
		Serial.print(F("Powering up SIM908.\n"));
    while(answer == 0){     // Send AT every two seconds and wait for the answer
    	answer = sendATcommand("AT", "OK", 2000);
    if(_debug){
	    Serial.print(F("SIM908 is powered on!\n"));
int8_t Sim908::sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    // For debug. It display well "OK" and "2000"
    Serial.println(expected_answer);
    Serial.println(timeout);
    memset(response, '\0', 100);    // Initialice the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    if (ATcommand[0] != '\0')
       // It display "AT"
        Serial.println(ATcommand);    // Send the AT command
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(Serial.available() != 0){    // if there are data in the UART input buffer, reads it and checks for the asnwer
            response[x] = Serial.read();
            Serial.print(response[x]);
            x++;
            if (strstr(response, expected_answer) != NULL)    // check if the desired answer (OK) is in the response of the module
                answer = 1;
        }else{
        if(_debug){
         Serial.println(F("No data in UART"));
    }while((answer == 0) && ((millis() - previous) < timeout));    // Waits for the asnwer with time out
if(_debug){
Serial.println("");
Serial.println(answer);
Serial.println("");
    return answer;
When I upload the code, my terminal is always retuning me
No data in UART
and
if(_debug){
Serial.println("");
Serial.println("");
is displaying
0
So, I supposed that
Serial.available()and
Serial.read()
is not reading my Serial port. I think, it’s because I use _cell (see in my constructor)
In my .ino file, I do have:
Sim908 sim908(new SoftwareSerial(2, 3), baud_rate, pinToPowerOnModule, debug);
Then I try to replace
Serial.read()
by
_cell.available()and
_cell.read()
but it generate an error:
/Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.cpp: In member function ‘int8_t Sim908::sendATcommand(char*, char*, unsigned int)’:
/Users/pierrot/Documents/Arduino/libraries/Sim908/Sim908.cpp:86: error: request for member ‘available’ in ‘((Sim908*)this)->Sim908::_cell’, which is of non-class type ‘SoftwareSerial*’
So, now I wunder if I well declared
in my Sim908.h file???
I am a bit lost…
Here is my sendATcommand() from my Sim908.cpp file
    char response[100];
    delay(100);
    x = 0;
    do{
            x++;
                answer = 1;
        }else{
        if(_debug){
if(_debug){
Serial.println("");
Serial.println("");
    return answer;
My god, I hope I was clear and fell you free to ask me more.
Thank a lot, to help my adapt sendATcommand() function or to higlight my errors
Cheers
Does this work?
_cell->available()
_cell->read()
Hello, I already tried this. The compilation do no display errors, but the terminl display the same result
... No data in UART No data in UART
Answer : 0
Expected answer: OK Timeout: 2000 Command: AT No data in UART ...
Answer shoud not return 0 :cold_sweat:
OK, so that fixed the syntax errors but there are other problems.
First, in sendATcommand(), presumably this is meant to be _cell and not Serial, and you have changed them.
Second, the following statements should be removed from the constructor and put into a begin() method called in setup() (or maybe you could put them in powerOnSim908())
EDIT added a reference for this last comment
http://forum.arduino.cc/index.php?topic=111463.msg837662#msg837662
See last three messages in that thread.
I am wondering if the is another IDE that arduino (I have a Macbook) What do you with? Is there a comment to print the content of
_cell->begin
or
_cell.begin
and what the difference between -> and the dot
I ma very anoyed to be block with the atCommeand()
Thang for all can help me with this (I hope my description is clear enough)
Cheers
If the left-hand argument is a pointer to an object, -> is used.
