I want to try boot loading Atmega 8a (on the breadboard) with Adruino Mega 2560, I already check ports 20 50,51,53,52 as well. But I got this error yet.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
Actually, It i try same issue. not in sync: resp=0x00
Error while burning bootloader.
I think it's arisen from this part:
select "Arduino Duemilanove or Nano w/ ATmega328" from the Tools > Board menu. I 'm using Atmega8A-pu * atmega 32A-pu , might this micro not include in "Arduino Duemilanove or Nano w/ ATmega328" ?!
Thanks
That is correct. The only Arduino board definition that uses the ATmega8 is the "Arduino NG or older" and you must also make sure to select Tools > Processor > ATmega8 after selecting that board from the Tools > Board menu.
However, I would recommend installing the excellent MiniCore instead. This adds better support to the Arduino IDE for the ATmega8A, including the far superior Optiboot bootloader, which will free up 0.5 kB of the precious flash memory on the ATmega8A.
You can easily install MiniCore in the Arduino IDE using Boards Manager. See the readme for instructions and more information:
I tried but I got the following error.
avrdude: Version 6.3-20201216
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/f_sur/Library/Arduino15/packages/MiniCore/hardware/avr/2.1.3/avrdude.conf"
User configuration file is "/Users/f_sur/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14101
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
Yes, at first, I did,
1- I choose atmega 2560 board, 2- example File > Examples > 11.ArduinoISP > Arduino ISP 3- upload,
after successful uploading,
1- tolls board, mini core, atmega 8 2- Boatloading.
But I got error.
