Issue to upload bootloader file in atmega328p-au
Dear all, I have made one pcb for atmega328p-au where I have tried to upload bootloader file. I donw know where I have done mistake with pcb, coz when I'm trying to upload bootloader file its showing bellow error.
Arduino: 1.6.12 Hourly Build 2016/08/31 07:46 (Windows 10), Board: "Arduino Nano, ATmega328"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Error while burning bootloader.
option enabled in File -> Preferences.
Moved your topic to it's current location as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Check the checkbox next to "Show verbose output during: upload".
  • Click the "OK" button.
  • Attempt to "upload bootloader file"
  • After the process fails, you'll see a button on the right side of the orange bar: "Copy error messages". Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the Burn Bootloader output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
your1click:
Almost certainly unrelated to your problem, but I'm curious. Why are you using a 2.5 year old beta test version of the Arduino IDE?
You haven’t mentioned what programmer you are using to upload the boot loader or how it is wired ( ICSP ?).
Your board doesn’t show any serial connection or the reset line for any program upload either .
