Issue: Unable to Connect HC-05 Bluetooth Module to Windows 10 Computer
Hardware:
  • Arduino: Arduino Uno
  • Bluetooth Module: HC-05 (ZC-040)
Problem: I'm having trouble connecting my HC-05 Bluetooth module to my Windows 10 computer. The computer can find the device, but it fails to establish a connection. I've double-checked the wiring and the code, but I'm still facing issues.
Current Setup:
  • Connections:
    • HC-05 TX -> Arduino pin 2 (RX)
    • HC-05 RX -> Arduino pin 3 (TX)
    • HC-05 VCC -> 5V
    • HC-05 GND -> GND
#include <SoftwareSerial.h>
#define RX_PIN 2  // RX pin of BlueTooth Module connected to pin number 2 on the Arduino
#define TX_PIN 3  // TX pin of BlueTooth Module connected to pin number 3 on the Arduino
SoftwareSerial Slave(TX_PIN, RX_PIN);
char BluetoothData;  // Initialize BluetoothData variable
  Serial.begin(19200);  // Serial communication at 19200 baud
  Slave.begin(9600);    // SoftwareSerial communication at 9600 baud
  // Check if data is available from Bluetooth module
  if (Slave.available()) {
    BluetoothData = Slave.read();   // Read the incoming data
    Serial.println(BluetoothData);  // Print the incoming data to serial monitor
Try the BT sample first, what does it do.
You have the parameters the wrong way round. The first once should be the Rx pin and the second the Tx pin
