Hello I manage to get my code to compile without any errors but I get this error when I attempt to upload it.
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 2572 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 37 bytes (1%) of dynamic memory, leaving 2011 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\CAE~1.DE\AppData\Local\Temp\arduino_build_221574/sketch_feb08b_v.2.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd5
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
And this is my code
#include <NewPing.h>
#include <toneAC.h>
#define DEBUG false // Set to true to enable Serial debug
#define TONE_PIN 8
#define TONE_VOLUME 10 // 1-20
#define TRIGGER_PIN 12 // Board pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 11 // Board pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
if (DEBUG) {
Serial.println("Theremino starting");
delay(30); // Wait 30ms between pings (about 33 pings/sec). 29ms should be the shortest delay between pings.
unsigned long uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
if (DEBUG) Serial.println(uS);
if (uS > 2000) { // Range is about 0-30 cm from sensor
toneAC(0); // Turn sound off when not in range
if (DEBUG) Serial.println("No tone");
int freq = 2000 - uS / 1.5; // Get sound frequency
toneAC(freq, TONE_VOLUME); // Play it!
if (DEBUG) Serial.println(freq);
