I've using a ATmega328p SMD that is already soldered down and there wasn't any problem with it, I uploaded the bootloader, I set it up to 8mhz external oscillator because it was the one I'm using and I've been using an Arduino UNO with ArduinoISP to burn the bootloader and to upload the sketch via ISP, everything was going with out a problem. Everytime that I uploaded a sketch it showed this succesful compiler message
El Sketch usa 13608 bytes (42%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 643 bytes (31%) de la memoria dinámica, dejando 1405 bytes para las variables locales. El máximo es 2048 bytes.
C:\Users\leo_c\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\7.1-arduino.1/bin/avrdude -CC:\Users\leo_c\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.2.2/avrdude.conf -v -patmega328p -cstk500v1 -PCOM12 -b19200 -Uflash:w:C:\Users\leo_c\AppData\Local\Temp\arduino_build_233486/Matrix_display_master_test.ino.with_bootloader.hex:i
avrdude: Version 7.1-arduino.1
Copyright the AVRDUDE authors;
see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is C:\Users\leo_c\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.2.2\avrdude.conf
Using Port : COM12
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : possible i/o
RETRY pulse : SCK
Serial program mode : yes
Parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Alias Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
signature 0 0 0 0 no 3 1 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 1 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
avrdude: device signature = 0x1e950f (probably m328p)
avrdude: Note: flash memory has been specified, an erase cycle will be performed.
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file C:\Users\leo_c\AppData\Local\Temp\arduino_build_233486/Matrix_display_master_test.ino.with_bootloader.hex for flash
with 14092 bytes in 3 sections within [0, 0x7fff]
using 111 pages and 116 pad bytes
avrdude: writing 14092 bytes flash ...
Writing | ################################################## | 100% 15.18s
avrdude: 14092 bytes of flash written
avrdude: verifying flash memory against C:\Users\leo_c\AppData\Local\Temp\arduino_build_233486/Matrix_display_master_test.ino.with_bootloader.hex
Reading | ################################################## | 100% 8.20s
avrdude: 14092 bytes of flash verified
avrdude done. Thank you.
The issue began when I used another arduino board that I had as the arduino programmer to upload the sketch via ISP, when doing so the compiler sent this error message.
C:\Users\leo_c\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\7.1-arduino.1/bin/avrdude -CC:\Users\leo_c\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.2.2/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:0b11111101:m -Uhfuse:w:0b11010110:m -Ulfuse:w:0b11110111:m
Using Port : COM3
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: reading input file 0xff for lock
with 1 byte in 1 section within [0, 0]
avrdude: writing 1 byte lock ...
avrdude: 1 byte of lock written
avrdude: verifying lock memory against 0xff
avrdude avr_verify() warning: verification mismatch
device 0x00 != input 0xff at addr 0x0000 (error)
avrdude do_op() error: verification mismatch
Error quemando bootloader
And everytime that I try to use any Arduino as a programmer via ISP it sends the following error and I can't upload nor burn any bootloader
Using Port : COM12
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: device signature = 0xffffff (probably .xmega) (retrying)
avrdude main() error: Yikes! Invalid device signature.
avrdude main() error: expected signature for ATmega328P is 1E 95 0F
Double check connections and try again, or use -F to override
this check.
I don't know if there's been an error with the fuses that I need to reset, or the firmware or if my ATmega328p is dead, but I would like to know what advice you can give to me.
