Issue Using Arduino Leonardo with Processing
I am attempting to implement this project with an Arduino Leonardo and strand of Adafruit Neopixel LEDs. I’ve been able to implement several projects using the Leonardo to control the LEDs successfully but I’m completely lost when it comes to using Processing to send messages to the Leonardo.
I’ve read several things online about Leonardo communication via USB but I’m completely stumped. From what I have gathered this line of code is necessary for the Leonardo
while (!Serial){
However, adding this has not helped. Additionally I’ve read several things about DTREnable needing to be set but I am lost as to what this is and how to set it.
Could anybody shed some light on what I could be missing? When I open up the Serial Monitor in the IDE while this program is running, the only thing that shows up is
“yyyyyyyyyy…” forever.
Thank you very much in advance for your help.
Here is the exact code that I am using
Arduino
#define PIN 6
#define NUM_LED 25
#define NUM_DATA 77 // NUM_LED * 3 + 2
#define RECON_TIME 2000 // after x seconds idle time, send afk again.
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LED, PIN, NEO_GRB + NEO_KHZ800);
uint8_t led_color[NUM_DATA];
int index = 0;
unsigned long last_afk = 0;
unsigned long cur_time = 0;
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  while (!Serial){
  Serial.print("ozy"); // Send ACK string to host
    for(;;){
    if (Serial.available() > 0) {
      led_color[index++] = (uint8_t)Serial.read();
      if (index >= NUM_DATA){
        Serial.write('y');
        last_afk =  millis();
        index = 0;
        if ((led_color[0] == 'o') && (led_color[1] == 'z')){
          // update LEDs
          for(int i=0; i<NUM_LED; i++){
            int led_index = i*3 + 2;
            strip.setPixelColor(i, strip.Color(led_color[led_index], led_color[led_index+1], led_color[led_index+2]));
          strip.show();
    else{
      cur_time = millis();
      if (cur_time - last_afk > RECON_TIME){
        Serial.write('y');
        last_afk =  cur_time;
        index = 0;
Processing
import java.awt.*;
import java.awt.image.*;
import processing.serial.*;
// using 12 RGB LEDs
static final int led_num_x = 4;
static final int led_num_y = 4;
static final int leds[][] = new int[][] {
  {1,3}, {0,3}, // Bottom edge, left half
  {0,2}, {0,1}, // Left edge
  {0,0}, {1,0}, {2,0}, {3,0}, // Top edge
  {3,1}, {3,2}, // Right edge
  {3,3}, {2,3}, // Bottom edge, right half
// using 25 RGB LEDs
static final int led_num_x = 10;
static final int led_num_y = 6;
  {2,5}, {1,5}, {0,5}, // Bottom edge, left half
  {0,4}, {0,3}, {0,2}, {0,1}, // Left edge
  {0,0}, {1,0}, {2,0}, {3,0}, {4,0}, {5,0}, {6,0}, {7,0}, {8,0}, {9,0}, // Top edge
  {9,1}, {9,2}, {9,3}, {9,4}, // Right edge
  {9,5}, {8,5}, {7,5}, {6,5}  // Bottom edge, right half
static final short fade = 70;
static final int minBrightness = 120;
// Preview windows
int window_width;
int window_height;
int preview_pixel_width;
int preview_pixel_height;
int[][] pixelOffset = new int[leds.length][256];
// RGB values for each LED
short[][]  ledColor    = new short[leds.length][3],
      prevColor   = new short[leds.length][3];
byte[][]  gamma       = new byte[256][3];
byte[]    serialData  = new byte[ leds.length * 3 + 2];
int data_index = 0;
//creates object from java library that lets us take screenshots
Robot bot;
// bounds area for screen capture
Rectangle dispBounds;
// Monitor Screen information
GraphicsEnvironment     ge;
GraphicsConfiguration[] gc;
GraphicsDevice[]        gd;
Serial          port;
void setup(){
  int[] x = new int[16];
  int[] y = new int[16];
  // ge - Grasphics Environment
  ge = GraphicsEnvironment.getLocalGraphicsEnvironment();
  // gd - Grasphics Device
  gd = ge.getScreenDevices();
  DisplayMode mode = gd[0].getDisplayMode();
  dispBounds = new Rectangle(0, 0, mode.getWidth(), mode.getHeight());
  // Preview windows
  window_width      = mode.getWidth()/5;
  window_height      = mode.getHeight()/5;
  preview_pixel_width     = window_width/led_num_x;
  preview_pixel_height   = window_height/led_num_y;
  // Preview window size
  size(window_width, window_height);
  //standard Robot class error check
  try   {
    bot = new Robot(gd[0]);
  catch (AWTException e)  {
    println("Robot class not supported by your system!");
    exit();
  float range, step, start;
  for(int i=0; i<leds.length; i++) { // For each LED...
    // Precompute columns, rows of each sampled point for this LED
    // --- for columns -----
    range = (float)dispBounds.width / led_num_x;
    // we only want 256 samples, and 16*16 = 256
    step  = range / 16.0;
    start = range * (float)leds[i][0] + step * 0.5;
    for(int col=0; col<16; col++) {
      x[col] = (int)(start + step * (float)col);
    // ----- for rows -----
    range = (float)dispBounds.height / led_num_y;
    start = range * (float)leds[i][1] + step * 0.5;
    for(int row=0; row<16; row++) {
      y[row] = (int)(start + step * (float)row);
    // ---- Store sample locations -----
    // Get offset to each pixel within full screen capture
        pixelOffset[i][row * 16 + col] = y[row] * dispBounds.width + x[col];
  // Open serial port. this assumes the Arduino is the
  // first/only serial device on the system.  If that's not the case,
  // change "Serial.list()[0]" to the name of the port to be used:
  // you can comment it out if you only want to test it without the Arduino
 //port = new Serial(this, "/dev/tty.usbmodem1412", 115200);
  // A special header expected by the Arduino, to identify the beginning of a new bunch data.
  serialData[0] = 'o';
  serialData[1] = 'z';
void draw(){
  //get screenshot into object "screenshot" of class BufferedImage
  BufferedImage screenshot = bot.createScreenCapture(dispBounds);
  // Pass all the ARGB values of every pixel into an array
  int[] screenData = ((DataBufferInt)screenshot.getRaster().getDataBuffer()).getData();
  data_index = 2; // 0, 1 are predefined header
    int r = 0;
    int g = 0;
    int b = 0;
    for(int o=0; o<256; o++)
    {       //ARGB variable with 32 int bytes where
        int pixel = screenData[ pixelOffset[i][o] ];
        r += pixel & 0x00ff0000;
        g += pixel & 0x0000ff00;
        b += pixel & 0x000000ff;
    // Blend new pixel value with the value from the prior frame
    ledColor[i][0]  = (short)(((( r >> 24) & 0xff) * (255 - fade) + prevColor[i][0] * fade) >> 8);
    ledColor[i][1]  = (short)(((( g >> 16) & 0xff) * (255 - fade) + prevColor[i][1] * fade) >> 8);
    ledColor[i][2]  = (short)(((( b >>  8) & 0xff) * (255 - fade) + prevColor[i][2] * fade) >> 8);
    serialData[data_index++] = (byte)ledColor[i][0];
    serialData[data_index++] = (byte)ledColor[i][1];
    serialData[data_index++] = (byte)ledColor[i][2];
    float preview_pixel_left  = (float)dispBounds.width  /5 / led_num_x * leds[i][0] ;
    float preview_pixel_top    = (float)dispBounds.height /5 / led_num_y * leds[i][1] ;
    color rgb = color(ledColor[i][0], ledColor[i][1], ledColor[i][2]);
    fill(rgb);
    rect(preview_pixel_left, preview_pixel_top, preview_pixel_width, preview_pixel_height);
  if(port != null) {
    // wait for Arduino to send data
    for(;;){
      if(port.available() > 0){
        int inByte = port.read();
        if (inByte == 'y')
    port.write(serialData); // Issue data to Arduino
  // Benchmark, how are we doing?
  println(frameRate);
  arraycopy(ledColor, 0, prevColor, 0, ledColor.length);
Looks like it sends an initial "ozy" followed by a "y" every two seconds. What else did you expect to see in Serial Monitor?
You can't have Processing and Serial Monitor connected to the same serial port at the same time.
