issue while installing arduino-connector on upsquare
While installing arduino-connector through https://create.arduino.cc/getting-started/intel-platforms. Getting:
We were not able to establish a connection between the Arduino Create and your Intel®-based Platform. Make sure your Platform is correctly connected to Internet and you have filled out the Proxy Settings if you are behind Proxy.
I have properly filled proxy and other detail but still getting the same problem.
Also tried to install directly on upsquared but getting below issue:
Generate private key Generate csr Request certificate 2018/04/24 05:09:13 requestCert - POST https://api2.arduino.cc/devices/v1/********:8bef555d-b36f-41a7-88f3-7a5774ef2531: expected 200 OK, got 401 Unauthorized
I am also getting similar error with upsquared
We were not able to establish a connection between the Arduino Create and your Intel®-based Platform. Execute commandline: Process exited with status 5
arduino-connector.log has below information -
[sudo] password for up2: Version: 1.0.115
current configuration: id=
url=
http_proxy=
https_proxy=
all_proxy=
authurl=https://hydra.arduino.cc
apiurl=https://api2.arduino.cc
cert_path=./
sketches_path=
check_ro_fs=false
env_vars_to_load=
Generate private key to dump in: certificate.key
Generate csr
Request certificate to dump in: certificate.pem
2020/01/01 14:00:43 requestCert - POST https://api2.arduino.cc/iot/v1/devices/: expected 200 OK, got 412 Precondition Failed
May I request help to resolve the issue.
