Team,
I’m getting creazy. I’ve opened the simple ReadWrite example and changed the Test 1, 2, 3 with a loop to write it 500 times.
The read part is exactly the same of the example.
here the issue:
testing 1, 2, 3.
testing ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ1, 2, 3.
testing 1, 2, 3.
testing 1, 2, 3.
The ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ chars ARE NOT in the file.
I’m using an arduino pro mini so there is a led on Pin 13 that is the SCLK when the ÿÿ appear the led “vibrates”…
the ÿÿ appear multiple times.
I’ve tried to change libraries SD and SdFat as well as change SD card and Arduino board always with the same result.
I’ve even tried to put some delay in the read cycle… issue still there.
Here the code
SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SdFat.h>
File myFile;
SdFat SD;
Serial.begin(4800L);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
SD.remove("test.txt");
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
for (int index = 0; index < 500; index++) {
myFile.println("testing 1, 2, 3.");
Serial.println(index);
delay(10);
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
delay(10);
// close the file:
myFile.close();
// nothing happens after setup
