int C = 10;
int o = 11;
const int numeral[12] = {
//ABCDEFG /dp
B11111100, // 0
B01100000, // 1
B11011010, // 2
B11110010, // 3
B01100110, // 4
B10110110, // 5
B00111110, // 6
B11100000, // 7
B11111110, // 8
B11100110, // 9
B10011100, // C
B11000110, // o
const int inPin = 0; // analog pin
// pins for decimal point and each segment
// dp,G, F, E, D, C, B, A
const int segmentPins[] = { 9,8,7,6,5,4,3,2};
const int nbrDigits= 4;
//dig 1 2 3 4
const int digitPins[nbrDigits] = { 13,12,11,10};
void setup(){
Serial.begin (9600);
for(int i=0; i < 8; i++)
pinMode(segmentPins[i], OUTPUT); // set segment and DP pins to output
for(int i=0; i < nbrDigits; i++){
pinMode(digitPins[i], OUTPUT); //HIGH disables digit, LOW enables digit
digitalWrite (digitPins[i], HIGH); //Digit disabled by default
int value = analogRead (inPin);
int millivolts = (value / 1023.0) * 5000;
float celsius = millivolts * 0.1 - 50; // sensor output is 10mV per degree Celsius
Serial.println (millivolts);
Serial.println (celsius);
delay (2000);
showNumber(celsius);
void showNumber( int number)
showDigit (C, nbrDigits - 1);
showDigit (o, nbrDigits - 2);
// showDigit (C, nbrDigits - 1);
if(number == 0)
showDigit( 0, nbrDigits-1) ;
for( int digit = nbrDigits-3; digit >= 0; digit--)
if(number > 0)
showDigit( number % 10, digit) ;
number = number / 10;
void showDigit( int number, int digit)
// Displays given number on a 7-segment display at the given digit position
digitalWrite( digitPins[digit], LOW );
for(int segment = 1; segment < 8; segment++)
boolean isBitSet = bitRead(numeral[number], segment);
//isBitSet = ! isBitSet;
digitalWrite( segmentPins[segment], isBitSet);
delay(300);
digitalWrite( digitPins[digit],HIGH);
//delay(1000);
A delay you say? Well, you told it to wait 300ms with each digit it puts there.
Please open your code back up in the IDE and do an auto-format. It's so much easier to read and debug code when the blocks line up nice and neat and you can see what's nested where without having to count braces.
See if this code helps your project.
As I don't know which sensor you used I used a potentiometer to simulate a temperature sensor.
Then modify the temperature calculation in the "loop()" to suit your sensor.
Simulated in: " SevenSeg - Wokwi ESP32, STM32, Arduino Simulator "
int C = 10;
int o = 11;
//ABCDEFG /dp
//2345678 9
B11111100, // 0
B01100000, // 1
B11011010, // 2
B11110010, // 3
B01100110, // 4
B10110110, // 5
B00111110, // 6
B11100000, // 7
B11111110, // 8
B11100110, // 9
B10011100, // C
B11000110, // o
const int segmentPins[] = { 9, 8, 7, 6, 5, 4, 3, 2};
const int nbrDigits = 4;
//dig 1 2 3 4
const int digitPins[nbrDigits] = { 13, 12, 11, 10};
for (int i = 0; i < 8; i++) {
for (int i = 0; i < nbrDigits; i++) {
//int millivolts = (value / 1023.0) * 5000;
//float celsius = millivolts * 0.1 - 50; // sensor output is 10mV per degree Celsius
float celsius = map(value, 0, 1023, 0, 60);
//Serial.println(number);
if (number == 0)
showDigit( 0, nbrDigits - 3) ;
for ( int digit = nbrDigits - 3; digit >= 0; digit--)
if (number > 0)
for(int i = 0; i < 4; i++)
digitalWrite( digitPins[i], LOW );
for (int segment = 0; segment < 8; segment++)
digitalWrite( digitPins[digit], HIGH);
