Issue with 433 MHz Transmitter/Receiver
Hoping someone can help. I'm trying to build a gesture controlled robot and I'm having issues with the transmitting and receiving.
I'm using the FS1000A 433MHz transmitter/receiver with the ADXL345 accelerometer and my code is;
TRANSMITTER CODE
//Connect the Transmitter data pin to Arduino pin 12
//If you don't want to use pin 12 use vw_set_tx_pin(transmit_pin), with transmit_pin being desired pin ,in void setup
//Refer to the documentation in link for more details
#include<Wire.h>
 // ADXL345 I2C address is 0x53(83)
 #define Addr 0x53
#include <VirtualWire.h>
int xPin=0;
int yPin=1;
int zPin=2;
int ledPin=13;//led on pin 13 is ON except when transmitter is parallel to the ground
  vw_setup(2000);//Bits per second
  pinMode(ledPin,OUTPUT);
  //Serial.begin(9600);//Initialise the serial connection debugging
   // Initialise I2C communication as MASTER
 Wire.begin();
 // Initialise serial communication, set baud rate = 9600
 // Start I2C Transmission
 Wire.beginTransmission(Addr);
 // Select bandwidth rate register
 Wire.write(0x2C);
 // Normal mode, Output data rate = 100 Hz
 Wire.write(0x0A);
 // Stop I2C transmission
 Wire.endTransmission();
 // Select power control register
 Wire.write(0x2D);
 // Auto-sleep disable
 Wire.write(0x08);
 // Select data format register
 Wire.write(0x31);
 // Self test disabled, 4-wire interface, Full resolution, Range = +/-2g
 Wire.write(0x08);
 delay(300);
 unsigned int data[6];
  for(int i = 0; i < 6; i++)
     // Select data register
     Wire.write((50 + i));
     // Request 1 byte of data
     Wire.requestFrom(Addr, 1);
     // Read 6 bytes of data
     // xAccl lsb, xAccl msb, yAccl lsb, yAccl msb, zAccl lsb, zAccl msb
     if(Wire.available() == 1)
        data[i] = Wire.read();
 // Convert the data to 10-bits
 int xval = (((data[1] & 0x03) * 256) + data[0]);
 if(xval > 511)
    xval -= 1024;
 int yval = (((data[3] & 0x03) * 256) + data[2]);
 if(yval > 511)
    yval -= 1024;
 int zval = (((data[5] & 0x03) * 256) + data[4]);
 if(zval > 511)
    zval -= 1024;
 // Output data to serial monitor
 Serial.print("Acceleration in X-Axis is : ");
 Serial.println(xval);
 Serial.print("Acceleration in Y-Axis is : ");
 Serial.println(yval);
 Serial.print("Acceleration in Z-Axis is : ");
 Serial.println(zval);
 delay(300);
  //Serial.print("xval=");
  //Serial.println(xval);
  //Serial.print("yval=");
  //Serial.println(yval);
  //Serial.print("zval=");
  //Serial.println(zval);
  //delay(1000); //used to display values after 1s delay
  //Serial.print("\n");
  if ((0<xval<10) && (zval>100)) //stationary or stop(transmitter parallel to ground)
    digitalWrite(ledPin,LOW);
    send("s");
    Serial.println("s");
  else if ((xval<0) && (zval>50)) //forward(transmitter tilted forward)
      digitalWrite(ledPin,HIGH);
      send("f");
    else if ((xval>100) && (zval>0)) //backward(transmitter tilted backward)
      send("b");
   else if ((yval<0) && (zval>0)) //left(transmitter tilted to left)
      send("l");
   else if ((yval>200) && (zval>10))//right(transmitter tilted to right)
      send("r");
  //delay(1000);
void send(char *message)//send function definition
  vw_send((uint8_t *)message, strlen(message));
  vw_wait_tx(); // Wait until the whole message is gone
RECEIVER CODE
//Connect the Receiver data pin to Arduino pin 11
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
//L293D
//Motor A
const int motorPin1  = 5;  // Pin 14 of L293
const int motorPin2  = 6;  // Pin 10 of L293
//Motor B
const int motorPin3  = 10; // Pin  7 of L293
const int motorPin4  = 9;  // Pin  2 of L293
const int ledPin=13;//led on pin 13 is ON except when bot is stationary
const int transmit_pin=12;
const int receive_pin=11;
    pinMode(motorPin1, OUTPUT);
    pinMode(motorPin2, OUTPUT);
    pinMode(motorPin3, OUTPUT);
    pinMode(motorPin4, OUTPUT);
 vw_setup(2000); // Bits per sec
 vw_rx_start(); // Start the receiver
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
  int i;
char c = char(i);
  Serial.print("Got: ");//debugging
  for (i = 0; i < buflen; i++)
     Serial.print(buf[i],HEX);//You may also use integer values debugging
      Serial.println(i + " : " + c);// debugging
          if (buf[i]==73)//Stationary
            digitalWrite(motorPin1,LOW);
            digitalWrite(motorPin2,LOW);
            digitalWrite(motorPin3,LOW);
            digitalWrite(motorPin4,LOW);
            Serial.println("Stationary");//debugging
          else  if(buf[i]==66)//Forward
                digitalWrite(motorPin1, LOW);
                digitalWrite(motorPin2, HIGH);
                digitalWrite(motorPin3, HIGH);
                digitalWrite(motorPin4, LOW);
               Serial.println("Forward");//debugging
          else if (buf[i]==0x62)//Backward
              digitalWrite(motorPin1, HIGH);
              digitalWrite(motorPin2, LOW);
              digitalWrite(motorPin3, LOW);
              digitalWrite(motorPin4, HIGH);
              Serial.println("Backward");//debugging
          else if (buf[i]==0x72)//Left
              Serial.println("Left");//debugging
            else      if (buf[i]==0x6C)//Right
    digitalWrite(motorPin4, LOW  );
              Serial.println("Right");//debugging
When the acceleromter is held flat the serial monitor on the receiver circuit is repeatedly showing 73 and the wheels on the robot remain stationary, however when tilted backwards the serial monitor then displays 62 and prints "backwards", the wheels on the robot go backwards but the serial monitor does not print any more lines. The circuit seems stop looping when a direction is detected.
Any ideas on where I'm going wrong ?
I'm using a 433MHz transmitter/receiver to send accelerometer data to control a robot.
When the accelerometer is held parallel to the ground the serial monitor shows the correct information looping, however when I tilt the accelerometer the new direction is shown once in the serial monitor then nothing after that. It appears to stop looping and the robot becomes stuck performing the same action.
I'm assuming the problem is in the receiver code as the transmitter serial monitor shows that it still continuously transmits data.
Both codes below. I have also attached a screenshot of what the receiver serial monitor looks like. As you can see when stationary the sketch loops but as soon as a direction is sent the loop stops. Hope someone can help !
RECEIVER CODE
//L293D
//Motor A
//Motor B
  int i;
char c = char(i);
  //Serial.print("Got: ");//debugging
     //Serial.print(buf[i],HEX);//You may also use integer values debugging
      //Serial.print(i + " : " + c);// debugging
          if (buf[i]==0x73)//Stationary
            //digitalWrite(ledPin,LOW);
        //else  if(buf[i]==66)
          else if (buf[i]==0x66)//Forward
               //digitalWrite(ledPin,HIGH);
           if (buf[i]==0x6C)//Left
             // digitalWrite(ledPin,HIGH);
             if (buf[i]==0x72)//Right
    //Serial.print("/n");// debugging
        //delay(1000);
TRANSMITTER CODE
#include<Wire.h>
 #define Addr 0x53
int xPin=0;
int yPin=1;
int zPin=2;
 Wire.begin();
 Wire.write(0x2C);
 Wire.write(0x0A);
 Wire.write(0x2D);
 Wire.write(0x08);
 Wire.write(0x31);
 Wire.write(0x08);
 delay(300);
 if(xval > 511)
    xval -= 1024;
 if(yval > 511)
    yval -= 1024;
 if(zval > 511)
    zval -= 1024;
 delay(300);
    send("s");
      send("f");
      Serial.println("f");
      send("b");
      Serial.println("b");
   else if ((yval<0) && (xval>0)) //left(transmitter tilted to left)
      send("l");
      Serial.println("l");
      send("r");
      Serial.println("r");
  //delay(1000);
As I cannot find an apparent mistake in the (horribly formatted) code I guess you have a problem in the hardware. As motors are part of that hardware my first guess would be a missing fly-back diode but as you didn't provide a wiring diagram or schematics I might be miserably wrong.
Apologies for the state of the code it's my first project, still a lot to learn !
As for the hardware, I tested it with 2 new motors and the same problem occurs. When I run some test code the motors run fine, it's just with this code that when one action is executed the serial monitor stops printing. It's as if the loop just stops.
That comment looks kind of silly, doesn't it?
Why do you need an array to store one byte?
Why do you assume that the other element(s) in the array contain anything other than garbage?
That is NOT how to test that a value is in a range. There are NO shortcuts. The value must be compared to the low end and then compared to the upper end.
    send("s");
      send("f");
      send("b");
      send("l");
      send("r");
You are reading WAY to much into the one byte of good data and 5 bytes of garbage.
Explain why you need a global array and global variable that you don't use.
  int i;
char c = char(i);
So, i contains some random garbage, and you cast it to a char. Why do you think you can do that? Why do you think you need to do that?
Printing c seems completely pointless, since I know, and you do, too, that it is garbage.
Why should I have to go look up what a 73 means?
          if (buf[i] == 'I') //Stationary
Now, I don't need to go look up what an 'I' means. Except that I have to wonder why 'I' means stationary. Must be a language thing...
There is NO good excuse for this.
Why did you still not post a wiring diagram of your setup?
I never wrote that I think the motors are broken. Motors contain coils and these tend to have spikes of return current if they are turned on and off. Without fly-back diodes or other means to solve this problem your power supply might show a voltage curve that is not appropriate for the circuit.
The IDE has an "Auto Format" option in the "Tools" menu.
