Issue with access point esp8266 nodemcu
Hi everyone, for days I've been trying to create an access point with an ESP8266 board, but I'm having upload problems with this code. When I upload 'simpler' codes to the board, everything works fine: it creates the access point, I connect via WiFi with my smartphone, and I can load the web page. However, when I upload 'more complex' codes like the one in question, it doesn't show me anything when I search for it with WiFi.
Initially, I thought it was a memory problem, so I inserted ESP.getFreeHeap to check if it was full, even though it's almost empty. I also tried flashing the board, but to no avail. Thanks to anyone who can help me.
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
#define LED_PIN D3
#define RELAY_PIN D5
#define SENSOR_PIN A0
ESP8266WebServer server(80);
int t1 = 85;
int t2 = 20;
int v1 = 400;
  EEPROM.begin(12);
  t1 = EEPROM.read(0) << 8 | EEPROM.read(1);
  t2 = EEPROM.read(2) << 8 | EEPROM.read(3);
  v1 = EEPROM.read(4) << 8 | EEPROM.read(5);
  pinMode(LED_PIN, OUTPUT);
  pinMode(RELAY_PIN, OUTPUT);
  pinMode(SENSOR_PIN, INPUT);
  WiFi.softAP("ESP8266 AP", "12345678");
  server.on("/", handleRoot);
  server.begin();
  Serial.print("Memoria heap libera: ");
  Serial.println(ESP.getFreeHeap());
  server.handleClient();
  int sensorValue = analogRead(SENSOR_PIN);
  if (sensorValue >= v1) {
    delay(t2);
    digitalWrite(LED_PIN, HIGH);
    digitalWrite(RELAY_PIN, HIGH);
    delay(t1);
    digitalWrite(LED_PIN, LOW);
    digitalWrite(RELAY_PIN, LOW);
void handleRoot() {
  String s = "<html><body>";
  s += "<form method='get' action='set'>";
  s += "Tempo di taglio: <input name='t1' length=12 value='" + String(t1) + "'><br>";
  s += "Ritardo cutoff: <input name='t2' length=12 value='" + String(t2) + "'><br>";
  s += "Media sensore: <input name='v1' length=12 value='" + String(v1) + "'><br>";
  s += "<input type='submit'></form></body></html>";
  server.send(200, "text/html", s);
  if (server.hasArg("t1") && server.hasArg("t2") && server.hasArg("v1")) {
    t1 = server.arg("t1").toInt();
    t2 = server.arg("t2").toInt();
    v1 = server.arg("v1").toInt();
    EEPROM.write(0, t1 >> 8);
    EEPROM.write(1, t1 & 0xFF);
    EEPROM.write(2, t2 >> 8);
    EEPROM.write(3, t2 & 0xFF);
    EEPROM.write(4, v1 >> 8);
    EEPROM.write(5, v1 & 0xFF);
    EEPROM.commit();
