Issue with alarm
I am a noob that is trying to setup a notification engine for my home alarm system. I am monitoring the alarm out on the alarm with an analogRead function. If the pin goes high enough, it will visit a web page on my home server that will trigger an email alert to my cell. That function is working okay, but I tried adding a relay into the mix to reboot the alarm box after the alarm has sounded and then stopped. The reason I want this is due to I will be going on a trip and I want the ability to re-arm the alarm in case the motion detector gives a false positive and triggers the alarm. The issue that I am having, is it seems that the “rebooting alarm” loop is the only thing running, but it is not triggering the relay. All I see in the serial monitor is: “rebooting alarm”. I have tested the relay, and it does work; so I think that it is an issue with my code. I would appreciate any advice or suggestions.
Thank you
My Code:
Door Alarm (notifier)
Uses the Ethernet shield to notify us when there is an alarm sounding
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x07, 0x9E };
IPAddress server(10,0,0,21);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
//int emailState = 0;
int analogPin = 0;
int val = 0;
int alarmState = 0;
long previousMillis = 0;        // will store last time email was sent
long interval = 10000;           // interval at which to send emails
  pinMode(7, OUTPUT);
  // start the serial library:
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // give the Ethernet shield a second to initialize:
void loop(){
digitalWrite(7, HIGH);
  val = analogRead(analogPin);    // read the input pin
if (val >= 600) {
 if(currentMillis - previousMillis > interval) //added this in to provide a delay function so I do not get as many email alerts.
if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /email.php HTTP/1.0");
    client.println();
    Serial.println("disconnecting.");
    client.flush();
    client.stop();
   alarmState = 1;
   Serial.println("alarmState = 1");
if (val < 600) {
  if (alarmState = 1) {
Serial.println("rebooting alarm");
digitalWrite(7,LOW);
delay(2000);
alarmState = 0;
If you're seeing the "rebooting alarm" message, I can't see any reason in the code why your digitalwrites wouldn't be executed. Looks more like a hardware problem. There is an issue with the code here:
  if (alarmState = 1)
Where == should have been used, but it didn't cause your issue.
wildbill:
If you’re seeing the “rebooting alarm” message, I can’t see any reason in the code why your digitalwrites wouldn’t be executed. Looks more like a hardware problem. There is an issue with the code here:
  if (alarmState = 1)
Where == should have been used, but it didn’t cause your issue.
I created another sketch that just toggles the relays on and off repeatedly, they are hooked up the exact same way and they work fine. Also, just to verify, my if statement should have been like this:
if (alarmState == 1)
Correct?
Code: if (alarmState == 1)
Correct?
Yes
