Issue with Analog Input being constant
Hello,
I am trying to analyze (with the arduino uno analog inputs) Vout from my non-inverting op amp setup.
Basically, when a force is applied to the FSR this will change Vout and I have some code to convert this into a force in my sketch.
See below for my schematic.
The Problem:
When reading the analog inputs, the values are not constant (when I view them on the serial monitor). When I apply a certain weight on to the FSR the analog read keeps jumping between 280 and about 310.
However, when I check Vout using my multi-meter it is constant at about 1.4 V.
Is there a reason why the analogRead is jumping around so much? Would any hardware changes help this?
Thanks!
There is a mistake in that circuit, my mistake.
R9 and FSR should be switched.
You need to low-pass filter your signal. You should add 100nF between the non-inverting input and ground (to decouple your virtual ground) and a capacitor across R9 (ie between inverting input and opamp output if I understand right), whose value C will set the bandwidth in conjunction with R9 (the product of C and R9 is the time constant).
