Hello, I am trying to convert a variable string of data into an hexstring to send it over LoRa. When I make my array too long it gets filled with 0's and weird characters. How can I make my conversion variable or cut off my conversion when my data ends? My code is
#include <TheThingsNetwork.h>
#include <SoftwareSerial.h>
SoftwareSerial BTserial(8, 9); // RX | TX
char c = ' ';
void delayAndRead()
delay(220);
while (BTserial.available())
c = BTserial.read();
delay(800);
void initHC05ToInq()
BTserial.println("AT+INIT");// Init.
delayAndRead();
Serial.println("test0");
BTserial.println("AT+CMODE=1");// Enable connect to any device
delayAndRead();
Serial.println("test1");
BTserial.println("AT+ROLE=1");// Set to master in order to enable scanning
delayAndRead();
Serial.println("test2");
BTserial.println("AT+INQM=1,7,5");//RSSI, Max 10 devices, ~30s
delayAndRead();
Serial.println("test3");
BTserial.println("AT+CLASS=0");// Disable COD filter
delayAndRead();
Serial.println("test4");
// Set your DevAddr, NwkSKey, AppSKey and the frequency plan
const char *devAddr = "nonono";
const char *nwkSKey = "no private keys";
const char *appSKey = "for you :)";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
loraSerial.begin(57600);
debugSerial.begin(9600);
BTserial.begin(38400);
// Wait a maximum of 10s for Serial Monitor
while (!debugSerial && millis() < 10000)
debugSerial.println("-- PERSONALIZE");
ttn.personalize(devAddr, nwkSKey, appSKey);
debugSerial.println("-- STATUS");
ttn.showStatus();
BTserial.println("AR+ORGL");
BTserial.println("AT+RESET");
initHC05ToInq();
initMessage();
BTserial.println("AT+INQ");
char lineBuffer[100];
char subBuffer[220];
int index = 0;
int index2 = 0;
int total = 0;
bool capture = false;
String send = "";
void initMessage()
send = "B1:";
void string2ByteArray(char* input, byte* output)
int loop;
int i;
loop = 0;
i = 0;
while (input[loop] != '\0')
output[i++] = input[loop++];
// Keep reading from HC-05 and send to Arduino Serial Monitor
if (BTserial.available())
// Read character and append into buffer
lineBuffer[index] = c;
index++;
// When line ends
if (c == '\n')
// Remove line end characters from buffer
lineBuffer[index - 1] = 0; // \r\n
// Reset buffer index for next line
index = 0;
if (lineBuffer[0] == 'O' && lineBuffer[1] == 'K')
// Finish message
send += "]}}}";
// B1;["FCDE:90:5E7952,5A020C,FFD4"]} = 34 (ex. haakjes is het 31)
send.toCharArray(subBuffer, sizeof(subBuffer));
ttn.sendBytes(subBuffer, sizeof(subBuffer));
// DEBUG / TODO actually send this message
if (total > 0)
Serial.println(send);
// Restart INQ
delay(2000);
total = 0;
initMessage();
capture = false;
index2 = 0;
for (index = 0; index < 220; index++)
if (!capture)
if (lineBuffer[index] == ':')
capture = true;
subBuffer[index2] = lineBuffer[index];
if (lineBuffer[index] == '\n')
subBuffer[index2] = 0;
index2++;
index = 0;
// Add this line buffer
String str((char*)subBuffer);
if (send.indexOf(str) <= 0)
// If not first then add comma
if (total > 0)
send += ",";
send += "\"";
send += str;
send += "\"";
// Keep count
total++;
around this part:
if (total > 0)
is where my problems begin. For example I get returned this :
42313A22423441393A46433A3131363334442C3241303130432C464642300D222C22423441393A46433A3131363334442C3241303130432C464641380D222C22423441393A46433A3131363334442C3241303130432C464641450D222C22423441393A46433A3131363334442C3241303130432C464641460D225D7D7D7D00000000000000FFFF0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001D01000010270000E9060000CD00CC00C800C9
this translates into:
B1:"B4A9:FC:11634D,2A010C,FFB0
","B4A9:FC:11634D,2A010C,FFA8
","B4A9:FC:11634D,2A010C,FFAE
","B4A9:FC:11634D,2A010C,FFAF
"]}}}ÿÿ'éÍÌÈÉ
but I want it to translate it into this:
So how can I edit my program to cut off or to remove the unnecessary piece of the string. This whole piece is not needed:
I cannot make my array smaller because my data is variable between 1 and 9 devices.
Thank you in advance!
