Issue with AT+CIPGSMLOC=1,1
Good day, all!
I actually experiment a issue because the command
AT+CIPGSMLOC=1,1
return me an error response, when I start my App but only the 3 first GSMLOC requests.
I wundering if I correctly open the GPRS, at the good time
Thank for reading my post and I will try to give you a good explication.
My GPRS/GSM module is a SIM808
I am using my module to
  • Send and receive SMS
  • Receive call to listen what happen around the module
  • Get GPS location
  • If no GPS, get GSM Location
  • Send coordinate to a remote server
  • Write / read in SD card the APN and the coordinate which have not been sent
  • SOS button (interrupt)
All works excepted AT+CIPGSMLOC=1,1 when I start my App and then it work.
Note, I open my GPRS in the setup() and I wundering if I should open the GPRS before I request a GSMLOC or when I send the data with HTTP to the remote server, and immediately close the GPRS connection.
here is my actiion
In setup()
Wait 3 sec.
Initializing FONA....
Attempting to open comm with ATs
 ---> AT
 <--- AT
 ---> ATE0
 <--- ATE0
 ---> ATE0
 <--- OK
 ---> AT+CVHU=0
 <--- OK
 ---> ATI
 <--- SIM808 R14.18
OK
+CPIN: READY
FONA 808 (v2) is OK
 ---> AT+CPIN?
 <--- +CPIN: READY
SIM card is ready
 ---> AT+CREG?
 <--- +CREG: 0,2
NS: Not registered (searching)
 ---> AT+CREG?
 <--- +CREG: 0,2
 ---> AT+CREG?
 <--- +CREG: 0,2
 ---> AT+CREG?
 <--- +CREG: 0,1
NS: Home
 ---> AT+COPS?
 <--- +COPS: 0,0,"Orange"
Turn on GPS
 ---> AT+CGNSPWR?
 <--- +CGNSPWR: 0
 ---> AT+CGNSPWR=1
 <--- OK
ENABLE GPRS AND CHECK enableGPRSAndCheck(2)
 ---> AT+CSQ
 <--- +CSQ: 14,0
Check SAPBR (Bearer):
 ---> AT+SAPBR=2,1
 <--- +SAPBR: 1,3,"0.0.0.0"
 Bearer status: 3, Closed
Enabling GPRS
 ---> AT+CIPSHUT
 <--- SHUT OK
 ---> AT+CGATT=1
 <--- OK
 ---> AT+SAPBR=3,1,"CONTYPE","GPRS"
 <--- OK
 ---> AT+SAPBR=3,1,"APN","click"
 <--- OK
 ---> AT+CSTT="click","",""
 <--- OK
 ---> AT+SAPBR=3,1,"USER",""
 <--- OK
 ---> AT+SAPBR=3,1,"PWD",""
 <--- OK
 ---> AT+SAPBR=1,1
 <--- OK
 ---> AT+CIICR
 <--- OK
Sync UTC time. 5 attends.
 ---> AT+CNTPCID=1
 <--- OK
 ---> AT+CNTP
 <--- OK
NTP Service response error
GPRS not enable. Check APN.
 ---> AT+CNTPCID=1
 <--- OK
 ---> AT+CNTP
 <--- OK
Sync NTP time OK
GPRS enabled
Running since: 43 sec.
 ---> AT+CPBS?
 <--- +CPBS: "SM",3,250
// Requesting the monnay ballance
 ---> AT+CUSD=1
 <--- OK
 ---> AT+CUSD=1,"#121#"
 <--- OK
 USSD Reply (36 bytes):Votre solde actuel est de CHF 16.62.
// Check battery level
 ---> AT+CBC
 <--- +CBC: 0,100,4222
// Request time
 ---> AT+CCLK?
 <--- +CCLK: "16/08/24,00:54:53+08"
Time: "16/08/24,00:54:53+08"
At the end of setup, all work fine. Now the loop() starts and observe the 4 AT+CIPGSMLOC=1,1 response:
If you observe well, the first and second time time, AT+CIPGSMLOC return that response:
<--- +CIPGSMLOC: 603
(DNS error)
The third time, the response is
<--- +CUSD: 4
here is the sequence in loop()
 ---> AT
 <--- OK
Running since: 0 sec.
// Check quality of signal
 ---> AT+CSQ
 <--- +CSQ: 13,0
// Check network
 ---> AT+CREG?
 <--- +CREG: 0,1
Network status: Home
Get timestamp (NTP)
 ---> AT+CCLK?
 <--- +CCLK: "16/08/24,00:54:55+08"
Check call status
 ---> AT+CPAS
 <--- +CPAS: 0
 > Line is READY
Checking unsent SOS in SD card
Nb of Files: 0
/SOS/ does not exist
Check call status
 ---> AT+CPAS
 <--- +CPAS: 0
 > Line is READY
REQUEST GPS AND SEND
Running since: 2 sec.
 ---> AT+CSQ
 <--- +CSQ: 13,0
Check GPRS
Is Attached: ---> AT+CGATT?
 <--- +CGATT: 1 // OK
 ---> AT+SAPBR=2,1
 <--- +SAPBR: 1,1,"10.176.175.151"
 Bearer status: 1, Connected (CHECK IF NEED NTPSYNC)
Running since: 4 sec.
Starting Geolocalisation
1/5 attend to get GPS
Get coordinate ---> AT+CGNSINF
 <--- +CGNSINF: 1,0,19800106000016.000,,,,0.00,0.0,0,,,,,,0,0,,,,,
// The GPS location is not valid, then it look for GSM location (triangulation)
 ---> AT+SAPBR=2,1
// Read DNS
 ---> AT+CDNSCFG?
 <--- PrimaryDns: 10.9.11.21
Getting GSMLOC
 ---> AT+CIPGSMLOC=1,1
GSMLOC Failed!
Could not get GSM or GPS coordinates
2/5 attend to get GPS
 <--- +CGNSINF: 1,0,19800106000032.000,,,,0.00,0.0,0,,,,,,0,0,,,,,
DEBUG: GPS Status: 1
// GPS not valide, then it ask for the second time GSM Loc
DEBUG: Check SAPBR (Bearer):
 ---> AT+SAPBR=2,1
// Read again the DNS
 ---> AT+CDNSCFG?
Getting GSMLOC
GSMLOC Failed!
3/5 attend to get GPS
 <--- +CGNSINF: 1,0,19800106000049.000,,,,0.00,0.0,0,,,,,,0,0,,,,,
// GPS not valid, then it ask GSMLOC for the third time
 ---> AT+SAPBR=2,1
// DNS
 ---> AT+CDNSCFG?
Getting GSMLOC
 <--- +CUSD: 4
GSMLOC Failed!
// THEN FROM NOW, ALL ANSWER ARE EMPTY UNTIL THE 4TH GSMLOC REQUEST
 ---> AT+SAPBR=2,1
 Bearer status: 0, Connecting
4/5 attend to get GPS
DEBUG: GPS Status: -1
 ---> AT
// IT RECEIVE THE GSMLOC RESPONSE NOW!!!! STRANGE
 ---> AT+SAPBR=2,1
 <--- +CIPGSMLOC: 0,6.141064,46.219772,2016/08/24,00:55:39
 ---> AT+CDNSCFG?
// NOW THE GSMLOC RESPONSE IS CORRECT
Getting GSMLOC
 <--- +CIPGSMLOC: 0,6.141064,46.219772,2016/08/24,00:55:40
If you observe, after the 3rd GSMLOC attend, all response are empty and the program look like a bit creasy :o).
At the 4th GSMLOC request, the response is correct and from that step, the program works well at each loop() interraction.
From that point all command return a correct andswer and AT+CIPGSMLOC=1,1 returns always a correct answer.
I do not understang why AT+CIPGSMLOC=1,1 need to be called 4 times to have the programm running correctely and why AT+CIPGSMLOC=1,1 make troubles to the following command.
I also open the GPRS connection at stup() and it remaind always open.
Enabling GPRS
 ---> AT+CIPSHUT
 <--- SHUT OK
 ---> AT+CGATT=1
 <--- OK
 <--- OK
 <--- OK
 <--- OK
 <--- OK
 <--- OK
 ---> AT+SAPBR=1,1
 <--- OK
 ---> AT+CIICR
 <--- OK
That is a good idea?
I wundering if I should open and close it only when I need it. For exemple with AT+CIPGSMLOC and HTTP rquest?
Your help and suggestion will help me a lot, and thank for reading my codes
I hope I provided good information
Cheers
Is there a way to remove / avoid / cancel all Unsolicited Result code?
Also note, each time a command is lunched, the buffer is cleanned
uint16_t timeoutloop = 0;
    while (timeoutloop++ < 40) {
        while(available()) {
            read();
            timeoutloop = 0;  // If char was received reset the timer
        delay(1);
I'm not sure but you probably just need a delay at the start before starting to get location because it takes time to initialize the gsm module
I had the same problem with sim808 gps/gsm/gprs module .
all I needed was a delay at the start until the module gets power then initialize .
