Hi, im trying to use the library BluetoothSerial, i had used with a ESP32CAM and works pretty fine, but now im trying to do the same with a NodeMCU32-S, and i have this errors:
abort() was called at PC 0x40195fd0 on core 1
Backtrace:0x40083679:0x3ffcccb00x40092d59:0x3ffcccd0 0x40098099:0x3ffcccf0 0x40195fd0:0x3ffccd70 0x40195dfb:0x3ffccd90 0x400fe803:0x3ffccdb0 0x400d679e:0x3ffccdd0 0x400d5db7:0x3ffcce20 0x400d30fd:0x3ffcce60 0x400d79f2:0x3ffccec0
ELF file SHA256: 0000000000000000
Using a decoder i get this:
*Decoding stack results* 0x40083679: **panic_abort** at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/**panic.c** line **402** 0x40092d59: **esp_system_abort** at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/**esp_system.c** line **128** 0x40098099: **abort** at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib/**abort.c** line **46** 0x400fe803: **esp_bt_controller_enable** at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/bt/controller/esp32/**bt.c** line **1848** 0x400d679e: **btStart** at C:\Users\angel\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32\**esp32-hal-bt.c** line **45** 0x400d5db7: **BluetoothSerial::begin(String, bool)** at C:\Users\angel\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src\**BluetoothSerial.cpp** line **644** 0x400d30fd: **setup()** at C:\Users\angel\Desktop\Documentos EDUTECNO\Proyecto OVO\Codigo Arduino\Intento ESPNOW\intento3\ESP32/**ESP32.ino** line **56** 0x400d79f2: **loopTask(void*)** at C:\Users\angel\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\cores\esp32\**main.cpp** line **42**
It says it abort when call Serial_BT.begin("BT_name"), what can be the problem?
