Issue with code, don't know why my code activates motors but not simultaneously
This code is suppoued to receive two values and activate de motors with them when I send the values one activates but not the other, for example: I travel through the x axis of my joystinck in an app and it activates motor x and does the same with motor y when I do it on y axis but when walk through anything in the middle of both jus one turns on.
Could you check if anything is bad in my code while I check my app?
const int pin_x =10;
  const int pin_y = 11;
  int in[2]{0};
  int index;
  int speedx=0; int speedy=0;
  const int SW_pin = 2; // digital pin connected to switch output
const int X_pin = 0; // analog pin connected to X output
const int Y_pin = 1;
class Car{
  private:
 int m_speedx = 0;
 int m_speedy = 0;
 public:
void getintoSpeed(int pinx ,int piny ,int x,int y){m_speedx =x; m_speedy =y;turnOnMotors(pinx,piny);}
void turnOnMotors(int pin_x, int pin_y){analogWrite(pin_x,m_speedx);analogWrite(pin_y,m_speedy);}
Car car;
  pinMode(pin_x, OUTPUT);
  pinMode(pin_y,OUTPUT);
  Serial.begin (38400); //for SC with bluetooth
void turn(int &speedOne, int &speedTwo){
    speedOne =255;
    speedTwo = 0;
  //speedx = ((analogRead(X_pin)-507)/507)*255;
  //speedy = ((analogRead(Y_pin)-518)/-518)*255;
  if(speedx < 0){speedx*=(-1);}
    while(Serial.available()>2){
      speedx=Serial.read();
      delay(10);
    speedy= Serial.read();
    delay(10);
    //automaticPilot
/*    if(Automatic()== 0){ // Turn Right
      turn(speedx,speedy)
     else{turn(speedy,speedx)}// Turn left*/
    car.getintoSpeed(pin_x, pin_y,speedx,speedy); //this potentially returnable
Don't write code like this - it is almost impossible to read
Put each part on its own line like this
    m_speedx =x;
    m_speedy =y;
    turnOnMotors(pinx, piny);
I don't see the point of the two lines
    m_speedx =x;
    m_speedy =y;
they don't seem to do anything.
...R
Robin2:
    m_speedx =x;
m_speedy =y;
...R
They set the private class variables associated with 'car'
Admittedly, that class is horrible.
I'm guessing the read problem is reading the x and y speeds from Serial as Serail.read() only returns the char read, not some sort of integer typed into the Serial monitor.
I was hoping your Reply #2 would have included a new version of your program with the code laid out so it is easy to read.
...R
Serial Input Basics - simple reliable non-blocking ways to receive data.
What model Arduino are you using?
How are you powering the motors?
How are you driving the motors?
are you sure your your motors are connected and controllable by pins 10 & 11?
