Issue with Data from Serial Monitor for Self Balancing Robot
Hello all,
I have just finished building the chassis for my self balancing robot and mounting all components. My issue is that when I plug in my Arduino to read the data from the MPU6050, I am receiving weird symbols and letters even though I am set to the correct baudrate (115200). I had this same issue of odd symbols previously while I was testing the response of circuit itself, but the issue was solved after refreshing the page and plugging/replugging. Now, this method is not working to solve the issue of odd symbols in the serial monitor. This issue happens with the code for calibrating the gyroscope offsets (1st picture) as well as the code for the self balancing robot itself (2nd picture). I could only assume this is due to a wiring issue, yet all my wires are connected properly. However they are cheap. I am not sure if this could be the problem itself or if there is a deeper cause to this issue. Does anyone have advice to solve this issue?
Please don't use screenshots, pictures! Use autoformatted IDE code and code tags for code and post the entire code.
Do you have any hardware connected to the Serial pins (Pin 0 or Pin 1)?
No I have nothing connected to pin 0 or pin 1
Well I really only wanted to show the symbols I was yielding in my serial monitor but if the code itself would be beneficial for either the Gyroscope calibration or the Self balancing robot, please let me know and I will post it.
Okey, but it forces helpers to help You write the question, using time and efforts to complete Your question. For You it might be nice social time but for helpers.... annoying.
Snippets are never wanted. Know that every helper is a newbie regarding Your project. Posting the entire code gives helpers the opportunity to "catch the idea". Mistakes like wrong baudrates needs the code. Baudrate settings in sender and receiver are the same? It looks like not.
Schematics are close to be wanted.
Code for self balancing robot:
/*Arduino Self Balancing Robot
 * Code by: B.Aswinth Raj
 * Build on top of Lib: https://github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050
 * Website: circuitdigest.com
#include "I2Cdev.h"
#include <PID_v1.h> //From https://github.com/br3ttb/Arduino-PID-Library/blob/master/PID_v1.h
#include "MPU6050_6Axis_MotionApps20.h" //https://github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
/*********Tune these 4 values for your BOT*********/
double setpoint= 176; // 176 set the value when the bot is perpendicular to ground using serial monitor.
//Read the project documentation on circuitdigest.com to learn how to set these values
double Kp = 21; // 21 Set this first
double Kd = 0.8; //Set this secound
double Ki = 140; //Finally set this
/******End of values setting*********/
// Initialize PID control algortihum w/ above variables
double input, output;
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
//Analyzes data from MPU to get reliable tilt value
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
    mpuInterrupt = true;
  //Initialise the Motor outpu pins
    pinMode (6, OUTPUT);
    pinMode (9, OUTPUT);
    pinMode (10, OUTPUT);
    pinMode (11, OUTPUT);
  // initialize device
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
     // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // load and configure the DMP
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(220);
    mpu.setYGyroOffset(76);
    mpu.setZGyroOffset(-85);
    mpu.setZAccelOffset(1688);
// Initializes DMP for MPU6050
      // make sure it worked (returns 0 if so)
    if (devStatus == 0)
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
        //setup PID
        pid.SetMode(AUTOMATIC);
        pid.SetSampleTime(10);
        pid.SetOutputLimits(-255, 255);
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
//Initialize Motor pins
//By default turn off both the motors
    analogWrite(6,LOW);
    analogWrite(9,LOW);
    analogWrite(10,LOW);
    analogWrite(11,LOW);
// Functions to move bot dependant upon tilt value. Restores to 180 degree, direction control
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize)
        //no mpu data - performing PID calculations and output to motors
        pid.Compute();
        //Print the value of Input and Output on serial monitor to check how it is working.
        Serial.print(input); Serial.print(" =>"); Serial.println(output);
        if (input>150 && input<200){//If the Bot is falling
        if (output>0) //Falling towards front
        Forward(); //Rotate the wheels forward
        else if (output<0) //Falling towards back
        Reverse(); //Rotate the wheels backward
        else //If Bot not falling
        Stop(); //Hold the wheels still
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024)
        // reset so we can continue cleanly
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    else if (mpuIntStatus & 0x02)
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        mpu.dmpGetQuaternion(&q, fifoBuffer); //get value for q
        mpu.dmpGetGravity(&gravity, &q); //get value for gravity
        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity); //get value for ypr
        input = ypr[1] * 180/M_PI + 180;
//Functions controlling motor speed dependant on value from PID control algorithum
void Forward() //Code to rotate the wheel forward
    analogWrite(6,output);
    analogWrite(9,0);
    analogWrite(10,output);
    analogWrite(11,0);
    Serial.print("F"); //Debugging information
void Reverse() //Code to rotate the wheel Backward
    analogWrite(6,0);
    analogWrite(9,output*-1);
    analogWrite(10,0);
    analogWrite(11,output*-1);
    Serial.print("R");
void Stop() //Code to stop both the wheels
    analogWrite(6,0);
    analogWrite(9,0);
    analogWrite(10,0);
    analogWrite(11,0);
    Serial.print("S");
It should be noted that I am using a 9V battery instead of the two 3.7V Lithium Ion batteries as used by the creator at circuit digest, DIY Self Balancing Robot using Arduino
My power source is not connected while I am trying to determine serial monitor data.
The circuit itself works as intended (dc motors responding to the input values from MPU6050), and after previously testing the circuit itself (before connecting to chassis) values were displayed in the serial monitor using this same code. If anymore information is needed, please let me know.
My notes say that you've already found the problem.
9 volt battery? A PP3?
Do things get better if you disconnect the power from the motor driver?
I was able to upload your sketch to my Arduino UNO (powered by USB). I don't have the other hardware but it got as far as displaying "Initializing I2C devices..." on Serial Monitor. That tends to show that the problem is in your hardware.
I believe the issue was within my code because I am now receiving the correct data from the MPU6050 by placing the motor initialization after the DMP initialization. My circuit also seems to be responding correctly, yet I am having trouble with balancing the bot itself . When using my own gyroscope offsets that I found from calibration, most of the time either one of the wheels will not spin, causing the bot to spin in circles, 360 degrees. However, when I first used the creator's offsets that he had found, I did not experience this issue. This issue is happening with both wheels, sporadically, which makes me assume it is due to my gyroscope values. I have posted the gyroscope calibration code that I used:
// Arduino sketch that returns calibration offsets for MPU6050 //   Version 1.1  (31th January 2014)
// Done by Luis Ródenas <luisrodenaslorda@gmail.com>
// Based on the I2Cdev library and previous work by Jeff Rowberg <jeff@rowberg.net>
// Updates (of the library) should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// These offsets were meant to calibrate MPU6050's internal DMP, but can be also useful for reading sensors.
// The effect of temperature has not been taken into account so I can't promise that it will work if you
// calibrate indoors and then use it outdoors. Best is to calibrate and use at the same room temperature.
/* ==========  LICENSE  ==================================
 I2Cdev device library code is placed under the MIT license
 Copyright (c) 2011 Jeff Rowberg
 Permission is hereby granted, free of charge, to any person obtaining a copy
 of this software and associated documentation files (the "Software"), to deal
 in the Software without restriction, including without limitation the rights
 to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 copies of the Software, and to permit persons to whom the Software is
 furnished to do so, subject to the following conditions:
 The above copyright notice and this permission notice shall be included in
 all copies or substantial portions of the Software.
 THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 THE SOFTWARE.
// I2Cdev and MPU6050 must be installed as libraries
#include "I2Cdev.h"
#include "MPU6050.h"
#include "Wire.h"
///////////////////////////////////   CONFIGURATION   /////////////////////////////
//Change this 3 variables if you want to fine tune the skecth to your needs.
int buffersize=1000;     //Amount of readings used to average, make it higher to get more precision but sketch will be slower  (default:1000)
int acel_deadzone=8;     //Acelerometer error allowed, make it lower to get more precision, but sketch may not converge  (default:8)
int giro_deadzone=1;     //Giro error allowed, make it lower to get more precision, but sketch may not converge  (default:1)
// default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
//MPU6050 accelgyro;
MPU6050 accelgyro(0x68); // <-- use for AD0 high
int16_t ax, ay, az,gx, gy, gz;
int mean_ax,mean_ay,mean_az,mean_gx,mean_gy,mean_gz,state=0;
int ax_offset,ay_offset,az_offset,gx_offset,gy_offset,gz_offset;
///////////////////////////////////   SETUP   ////////////////////////////////////
  // join I2C bus (I2Cdev library doesn't do this automatically)
  Wire.begin();
  // COMMENT NEXT LINE IF YOU ARE USING ARDUINO DUE
  TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz). Leonardo measured 250kHz.
  // initialize serial communication
  accelgyro.initialize();
  // wait for ready
  while (Serial.available() && Serial.read()); // empty buffer
  while (!Serial.available()){
    Serial.println(F("Send any character to start sketch.\n"));
    delay(1500);
  while (Serial.available() && Serial.read()); // empty buffer again
  // start message
  Serial.println("\nMPU6050 Calibration Sketch");
  delay(2000);
  Serial.println("\nYour MPU6050 should be placed in horizontal position, with package letters facing up. \nDon't touch it until you see a finish message.\n");
  delay(3000);
  Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
  // reset offsets
  accelgyro.setXAccelOffset(0);
  accelgyro.setYAccelOffset(0);
  accelgyro.setZAccelOffset(0);
  accelgyro.setXGyroOffset(0);
  accelgyro.setYGyroOffset(0);
  accelgyro.setZGyroOffset(0);
///////////////////////////////////   LOOP   ////////////////////////////////////
  if (state==0){
    Serial.println("\nReading sensors for first time...");
    meansensors();
    state++;
  if (state==1) {
    Serial.println("\nCalculating offsets...");
    calibration();
    state++;
  if (state==2) {
    meansensors();
    Serial.println("\nFINISHED!");
    Serial.print("\nSensor readings with offsets:\t");
    Serial.print(mean_ax);
    Serial.print("\t");
    Serial.print(mean_ay);
    Serial.print("\t");
    Serial.print(mean_az);
    Serial.print("\t");
    Serial.print(mean_gx);
    Serial.print("\t");
    Serial.print(mean_gy);
    Serial.print("\t");
    Serial.println(mean_gz);
    Serial.print("Your offsets:\t");
    Serial.print(ax_offset);
    Serial.print("\t");
    Serial.print(ay_offset);
    Serial.print("\t");
    Serial.print(az_offset);
    Serial.print("\t");
    Serial.print(gx_offset);
    Serial.print("\t");
    Serial.print(gy_offset);
    Serial.print("\t");
    Serial.println(gz_offset);
    Serial.println("\nData is printed as: acelX acelY acelZ giroX giroY giroZ");
    Serial.println("Check that your sensor readings are close to 0 0 16384 0 0 0");
    Serial.println("If calibration was succesful write down your offsets so you can set them in your projects using something similar to mpu.setXAccelOffset(youroffset)");
    while (1);
///////////////////////////////////   FUNCTIONS   ////////////////////////////////////
void meansensors(){
  long i=0,buff_ax=0,buff_ay=0,buff_az=0,buff_gx=0,buff_gy=0,buff_gz=0;
  while (i<(buffersize+101)){
    // read raw accel/gyro measurements from device
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    if (i>100 && i<=(buffersize+100)){ //First 100 measures are discarded
      buff_ax=buff_ax+ax;
      buff_ay=buff_ay+ay;
      buff_az=buff_az+az;
      buff_gx=buff_gx+gx;
      buff_gy=buff_gy+gy;
      buff_gz=buff_gz+gz;
    if (i==(buffersize+100)){
      mean_ax=buff_ax/buffersize;
      mean_ay=buff_ay/buffersize;
      mean_az=buff_az/buffersize;
      mean_gx=buff_gx/buffersize;
      mean_gy=buff_gy/buffersize;
      mean_gz=buff_gz/buffersize;
    i++;
    delay(2); //Needed so we don't get repeated measures
void calibration(){
  ax_offset=-mean_ax/8;
  ay_offset=-mean_ay/8;
  az_offset=(16384-mean_az)/8;
  gx_offset=-mean_gx/4;
  gy_offset=-mean_gy/4;
  gz_offset=-mean_gz/4;
  while (1){
    int ready=0;
    accelgyro.setXAccelOffset(ax_offset);
    accelgyro.setYAccelOffset(ay_offset);
    accelgyro.setZAccelOffset(az_offset);
    accelgyro.setXGyroOffset(gx_offset);
    accelgyro.setYGyroOffset(gy_offset);
    accelgyro.setZGyroOffset(gz_offset);
    meansensors();
    Serial.println("...");
    if (abs(mean_ax)<=acel_deadzone) ready++;
    else ax_offset=ax_offset-mean_ax/acel_deadzone;
    if (abs(mean_ay)<=acel_deadzone) ready++;
    else ay_offset=ay_offset-mean_ay/acel_deadzone;
    if (abs(16384-mean_az)<=acel_deadzone) ready++;
    else az_offset=az_offset+(16384-mean_az)/acel_deadzone;
    if (abs(mean_gx)<=giro_deadzone) ready++;
    else gx_offset=gx_offset-mean_gx/(giro_deadzone+1);
    if (abs(mean_gy)<=giro_deadzone) ready++;
    else gy_offset=gy_offset-mean_gy/(giro_deadzone+1);
    if (abs(mean_gz)<=giro_deadzone) ready++;
    else gz_offset=gz_offset-mean_gz/(giro_deadzone+1);
    if (ready==6) break;
Also, how should I be obtaining data for my PID values? I assume this could not be a "brute force" type of scenario but the process itself for finding these PID values was left ambiguous by the creator. Thanks for your help
That may be relevant to the circuit itself but the 9V battery is not connected while attempting to read data from the serial monitor. Also the input voltage for the Arduino is 5-12V and the L298N is 3.2-35V so within certain limits the battery really is insignificant.
May not get even 3.2V with the required motor current (whatever that is), but its probably more than the battery can output. Check the ¼ amp V/I curve for a 9V Coppertop battery ...
Wouldn't the 9V battery give me more current than the two 3.7V lithium ion batteries anyway? I have noticed when I use a brand new 9V battery (voltage is assumed to be slightly higher than this value) my dc motors turn in only one direction with no response from the MPU6050, which is an issue I solved previously by supplying power to circuit directly through 9V battery and the arduino serial monitor port itself. When I first tested the bot using the creator's gyroscope and PID values, it worked decently well, but seems to be getting worse and worse as I input my own setpoint and gyroscope offsets.
No, the 9V battery has higher internal series resistance, much lower peak current (mA) output, much lower capacity (mAh) and therefore worse regulation under the varying motor load which would exceed the battery's specifications .
