Issue with data receiving
I want to transfer data that appears in Arduino to my C# application and do not know what's wrong in my code. Here comes Arduino code:
int switchPin = 7;
int ledPin = 13;
boolean lastButton = LOW;
boolean currentButton = LOW;
boolean flashLight = LOW;
  pinMode(switchPin, INPUT);
  pinMode(ledPin, OUTPUT);
boolean debounce(boolean last)
  boolean current = digitalRead(switchPin);
  if (last != current)
    delay(5);
  return current;
  currentButton = debounce(lastButton);
  if (lastButton == LOW && currentButton == HIGH)
    Serial.println("UP");
    digitalWrite(ledPin, HIGH);
  if (lastButton == HIGH && currentButton == LOW)
    Serial.println("DOWN");
    digitalWrite(ledPin, LOW);
  lastButton = currentButton;
As you can see, this simple sketch sends message to port while the button is pressed. I have created a console C# app to receive data:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Text;
using System.IO.Ports;
namespace ArduinoTestApplication
    class Program
        static void Main(string[] args)
            SerialPort port = new SerialPort("COM3", 9600);
            port.Open();
            string lane;
            while (true)
                lane = port.ReadLine();
                Console.WriteLine(lane);
But when I push the button console is still empty. Tell me what's wrong, please!
Do you see a "Serial.begin"?
Not sure I do.
Using the serial monitor can be a useful debugging tool.
Thanks a lot!
