Hi all, for my school I'm trying to make a project find on a forum but when I verify the code I receive an error. Follow the code (thanx to hans andersson):
#include <FastLED.h>
DS3231 rtc(SDA, SCL);
rtc.begin();
rtc.setTime(12,39,0); // hour, minute, second
Serial.println(rtc.getTimeStr());
delay (1000);
#define PHOTO_RESISTOR_PIN A3
#define LED_PIN 4
#define NUM_LEDS 60
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
#define FRAMES_PER_SECOND 50
#define MAX_TINT 80
#define MAX_HUE_OFFSET 25
#define MIN_BRIGHTNESS 7
#define MAX_BRIGHTNESS 255
#define MIN_LIGHT 5
#define MAX_LIGHT 300
#define LIGHT_SENSITIVITY 10 //minimum light for light sensor to work as a button
#define NUM_MODES 6
#define MODE_SIMPLE 0
#define MODE_MINIMALISTIC 1
#define MODE_PROGRESS 2
#define MODE_SWEEP 3
#define MODE_SPECTRUM 4
#define MODE_HYSTERICAL 5
CRGB leds[NUM_LEDS];
delay( 3000 ); // power-up safety delay
FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setMaxPowerInVoltsAndMilliamps( 5, 1500);
rtc.begin();
static int mode = MODE_SIMPLE;
static unsigned long old_s=0;
static int old_light = 0;
static unsigned long last_dimmed = 0;
static int tint_a = 0;
static int tint_b = 0;
static int tintSteps=3;
static int hueOffset = 0;
static int hueSteps=1;
Time t = rtc.getTime();
unsigned long h=t.hour;
unsigned long m=t.min;
unsigned long s=t.sec;
if(s!=old_s)
old_s=s;
int light=analogRead(PHOTO_RESISTOR_PIN);
if(light < 3 && old_light > LIGHT_SENSITIVITY)
last_dimmed = millis();
else if(light > LIGHT_SENSITIVITY && millis() - last_dimmed < 3000)
mode=(mode+1)%NUM_MODES;
last_dimmed=0;
old_light=light;
light = constrain(light,MIN_LIGHT,MAX_LIGHT);
int b1=map(light,MIN_LIGHT,MAX_LIGHT,MIN_BRIGHTNESS,MAX_BRIGHTNESS);
int b2=FastLED.getBrightness();
if(b1 != b2 && (b1==MIN_BRIGHTNESS || b1==MAX_BRIGHTNESS || abs(b1-b2)*100/b2 > 10))
FastLED.setBrightness(b1);
int h_led=h%12*5+m/12;
int m_led=m;
int s_led=s;
hueOffset+=hueSteps;
if(abs(hueOffset) == MAX_HUE_OFFSET)
hueSteps*=-1;
if(tint_a==0)
tint_b+=tintSteps;
tint_b=constrain(tint_b,0,MAX_TINT);
if(tint_b==0 || tint_b==MAX_TINT)
tintSteps*=-1;
if(tint_b==0)
tint_a=1;
tint_a+=tintSteps;
tint_a=constrain(tint_a,0,MAX_TINT);
if(tint_a==0 || tint_a==MAX_TINT)
tintSteps*=-1;
if (mode == MODE_SIMPLE)
modeSimple(h_led,m_led,s_led,tint_a,tint_b);
else if (mode == MODE_MINIMALISTIC)
modeMinimalistic(h_led,m_led,tint_a,tint_b);
else if (mode == MODE_PROGRESS)
modeProgress(h_led,m_led,s_led,tint_a,tint_b);
else if (mode == MODE_SWEEP)
modeSweep(h_led,m_led,s_led,hueOffset);
else if (mode == MODE_SPECTRUM)
modeSpectrum(h_led,m_led,s_led,tint_a,tint_b);
else if (mode == MODE_HYSTERICAL)
modeHysterical(h_led,m_led,s_led,hueOffset);
FastLED.delay(1000/FRAMES_PER_SECOND);
void modeSimple(int h, int m, int s, int tint_a, int tint_b)
FastLED.clear();
leds[h]+=CRGB(255,tint_a,tint_b);
leds[m]+=CRGB(tint_b,255,tint_a);
leds[s]+=CRGB(tint_a,tint_b,255);
FastLED.show();
void modeMinimalistic(int h, int m, int tint_a, int tint_b)
FastLED.clear();
FastLED.show();
void modeProgress(int h, int m, int s, int tint_a, int tint_b)
FastLED.clear();
for(int i=h;i>=0 && (i==h || (i!=m && i!=s));i--)
leds[i]=CRGB(255,tint_a,tint_b);
for(int i=m;i>=0 && (i==m || (i!=h && i!=s));i--)
leds[i]=CRGB(tint_b,255,tint_a);
for(int i=s;i>=0 && (i==s || (i!=h && i!=m));i--)
leds[i]=CRGB(tint_a,tint_b,255);
FastLED.show();
void modeSweep(int h, int m, int s, int hueOffset)
FastLED.clear();
for(int i=1;i<15 &&(h-i+60)%60!=m&&(h-i+60)%60!=s;i++)
leds[(h-i+60)%60]=CHSV((HUE_RED+hueOffset)%255,255,255-15*i);
for(int i=1;i<15&&(m-i+60)%60!=h&&(m-i+60)%60!=s;i++)
leds[(m-i+60)%60]=CHSV(HUE_GREEN+hueOffset,255,255-15*i);
for(int i=1;i<15 &&(s-i+60)%60!=h&&(s-i+60)%60!=m;i++)
leds[(s-i+60)%60]=CHSV(HUE_BLUE+hueOffset,255,255-15*i);
leds[h]=CHSV((HUE_RED+hueOffset)%255,255,255);
leds[m]=CHSV(HUE_GREEN+hueOffset,255,255);
leds[s]=CHSV(HUE_BLUE+hueOffset,255,255);
FastLED.show();
void modeSpectrum(int h, int m, int s, int tint_a, int tint_b)
FastLED.clear();
int count=(h-m+60)%60;
CRGB rgb_h=CRGB(255,tint_a,tint_b);
CRGB rgb_m=CRGB(tint_b,255,tint_a);
CRGB rgb_s=CRGB(tint_a,tint_b,255);
int s_count=(h-s+60)%60;
if(s_count < count)
for(int i=0;i<=s_count;i++)
leds[(h-i+60)%60]= blend(rgb_h,rgb_m, 255*i/count);
for(int i=s_count;i<=count;i++)
leds[(h-i+60)%60]= blend(rgb_s,rgb_m, 255*(i-s_count)/(count-s_count));
for(int i=0;i<=count;i++)
leds[s]=rgb_s;
FastLED.show();
void modeHysterical(int h, int m, int s, int hueOffset)
FastLED.clear();
for(int i=4;i<60;i++)
for(int j=i-4;j<=i;j++)
leds[(s+j)%60]= CHSV(HUE_BLUE+hueOffset,255,255);
for(int j=0;j<60;j++)
if(random(10)==1 && j!=h && j!=m )
leds[j]=leds[j].fadeToBlackBy(100);
FastLED.show();
delay(1);
for(int i=0;i<30;i++)
if(j!=h && j!=m && j!=s)
leds[j]=leds[j].fadeToBlackBy(40);
FastLED.show();
delay(3);
for(int i=0;i<60;i++)
if(i!=h && i!=m && i!=s)
leds[i]=0;
FastLED.show();
```#include <DS3231.h>
rtc.begin();
rtc.setTime(8,15,0); // hour, minute, second
delay (1000);
Could someone help me please?
thank you and sorry if I've make a mistake to post in this way
Mary
