Issue with formatting
Hello,
i have a problem with the formatting in the setup function.
I am not able to figure it out.
Can someone have a look whats going on and where the error is?
I have tried hours to find i but i think i am blind for my own code at this point..
Error from console says:
WaterFlowSensor_funktioniert_v2_wlan_json:155:1: error: expected unqualified-id before 'else'
155 | else {
The error refers to this line in the setup funktion:
else {
  Serial.println("failed to mount FS");
Here is the complete code:
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#ifdef ESP32
#include <SPIFFS.h>
#endif
//needed for library
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
#include <DNSServer.h>
#include <PubSubClient.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
char configFileName[] = "/config.json";
#define MQTTSERVER      "192.168.1.101"                     // Home Server
#define MQTTSERVERPORT  "1883"
#define MQTTTOPIC    "Test"
#define MQTTID    "1"                                  // Leave blank to auto generate one
#define MQTTUSER        "username"
#define MQTTPASSWORD    "password"
char mqtt_server[20] = MQTTSERVER;                 // Placeholders for MQTT server settings
char mqtt_port[6] = MQTTSERVERPORT;
char mqtt_user[20] = MQTTUSER;
char mqtt_pass[20] = MQTTPASSWORD;
char mqtt_ID[20] = MQTTID;
char mqtt_topic[20] = MQTTTOPIC;
WiFiClient espClient;
PubSubClient client(espClient);
WiFiManager wifiManager;
unsigned long lastMsg = 0;
#define MSG_BUFFER_SIZE  (50)
char msg[MSG_BUFFER_SIZE];
int value = 0;
#define SENSOR  14
#define RelaisPin  5
#define resteButton 1 //D6
long currentMillis = 0;
long previousMillis = 0;
int interval = 1000;
boolean ledState = LOW;
float calibrationFactor = 4.5;
volatile byte pulseCount;
byte pulse1Sec = 0;
float flowRate;
unsigned long flowMilliLitres;
unsigned int totalMilliLitres;
float flowLitres;
float totalLitres;
int percentageHumididy;
char relais;
int restebuttonstat = 0;
uint8_t wlan_status;
int count_mqtt_fail = 0;
String topic_string;
String flowRate_out_s;
String FlowLiters_out_s;
String FlowMiliLiters_out_s;
String m_perc_in_s;
String Ralais1_in_S;
const char *flowRate_out;
const char *FlowLiters_out;
const char *FlowMiliLiters_out;
const char *m_perc_in;
const char *Ralais1_in;
//flag for saving data
bool shouldSaveConfig = false;
void IRAM_ATTR pulseCounter()
  pulseCount++;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void reset_setting() {
  // Reset Wifi settings for testing
  wifiManager.resetSettings();
  //clean FS for testing
  SPIFFS.format();
  //ESP.reset();
  //reset_setting();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists(configFileName)) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open(configFileName, "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
#ifdef ARDUINOJSON_VERSION_MAJOR >= 6
        DynamicJsonDocument json(1024);
        auto deserializeError = deserializeJson(json, buf.get());
        serializeJson(json, Serial);
        if ( ! deserializeError ) {
#else
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
#endif
          Serial.println("\nparsed json");
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(mqtt_topic, json["mqtt_topic"]);
          strcpy(mqtt_ID, json["mqtt_ID"]);
          strcpy(mqtt_user, json["mqtt_user"]);
          strcpy(mqtt_pass, json["mqtt_pass"]);
        else {
          Serial.println("failed to load json config");
        configFile.close();
else {
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
WiFiManagerParameter custom_mqtt_topic("topic", "mqtt topic", mqtt_topic, 20);
WiFiManagerParameter custom_mqtt_ID("ID", "mqtt ID", mqtt_ID, 8);
WiFiManagerParameter custom_mqtt_user("user", "mqtt user", mqtt_user, 20);
WiFiManagerParameter custom_mqtt_pass("pass", "mqtt pass", mqtt_pass, 20);
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
//set static ip
//  wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//add all your parameters here
wifiManager.addParameter(&custom_mqtt_server);
wifiManager.addParameter(&custom_mqtt_port);
wifiManager.addParameter(&custom_mqtt_topic);
wifiManager.addParameter(&custom_mqtt_ID);
wifiManager.addParameter(&custom_mqtt_user);
wifiManager.addParameter(&custom_mqtt_pass);
//set minimum quality of signal so it ignores AP's under that quality
//defaults to 8%
//wifiManager.setMinimumSignalQuality();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
//wifiManager.setTimeout(120);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//here  "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("AutoConnectFlowESP8266", "password")) {
  Serial.println("failed to connect and hit timeout");
  delay(3000);
  //reset and try again, or maybe put it to deep sleep
  ESP.reset();
  delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected to: )");
String ssid = WiFi.SSID();
String password = WiFi.psk();
Serial.print(ssid);
Serial.println(" ; ");
Serial.println(password);
//read updated parameters
strcpy(mqtt_server, custom_mqtt_server.getValue());
strcpy(mqtt_port, custom_mqtt_port.getValue());
strcpy(mqtt_topic, custom_mqtt_topic.getValue());
strcpy(mqtt_ID, custom_mqtt_ID.getValue());
strcpy(mqtt_user, custom_mqtt_user.getValue());
strcpy(mqtt_pass, custom_mqtt_pass.getValue());
// strcpy(blynk_token, custom_blynk_token.getValue());
//save the custom parameters to FS
if (shouldSaveConfig) {
  Serial.println("saving config");
#else
  JsonObject& json = jsonBuffer.createObject();
#endif
  json["mqtt_server"] = mqtt_server;
  json["mqtt_port"] = mqtt_port;
  json["mqtt_topic"] = mqtt_topic;
  json["mqtt_ID"] = mqtt_ID;
  json["mqtt_user"] = mqtt_user;
  json["mqtt_pass"] = mqtt_pass;
  File configFile = SPIFFS.open(configFileName, "w");
  if (!configFile) {
    Serial.println("failed to open config file for writing");
  serializeJson(json, configFile);
#else
  json.printTo(configFile);
#endif
  configFile.close();
  //end save
wifiManager.getWLStatusString(wlan_status);
Serial.print("WLan Status: ");
Serial.println(wlan_status);
if (wlan_status == 0) {
  wifiManager.stopWebPortal();
  wifiManager.stopConfigPortal();
Serial.println("local ip");
String topic_string(mqtt_topic);
String flowRate_out_s = topic_string + "/flowRate_out";
String FlowLiters_out_s = topic_string + "/FlowLiters_out";
String FlowMiliLiters_out_s = topic_string + "/FlowMiliLiters_out";
String m_perc_in_s = topic_string + "/m_perc_in";
String Ralais1_in_S = topic_string + "/Ralais1_in";
const char *flowRate_out = flowRate_out_s.c_str();
const char *FlowLiters_out = FlowLiters_out_s.c_str();
const char *FlowMiliLiters_out = FlowMiliLiters_out_s.c_str();
const char *m_perc_in = m_perc_in_s.c_str();
const char *Ralais1_in = Ralais1_in_S.c_str();
//  client.setServer(mqtt_server, 12025);
String mqtt_prt_x_s(mqtt_port);
const uint16_t mqtt_port_x = strtol(mqtt_prt_x_s.c_str(), NULL, 10);
const char* mqtt_server_conn = mqtt_server;
client.setServer(mqtt_server_conn, mqtt_port_x);
Serial.println("MQTT Server startet with: ");
Serial.print(mqtt_server_conn);
Serial.print(" ; ");
Serial.println(mqtt_port_x);
client.setCallback(callback);
WiFi.setAutoReconnect(true);
WiFi.persistent(true);
pinMode(RelaisPin, OUTPUT);
pinMode(SENSOR, INPUT_PULLUP);
pinMode(resteButton, INPUT);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
previousMillis = 0;
attachInterrupt(digitalPinToInterrupt(SENSOR), pulseCounter, FALLING);
void callback(char* topic, byte * payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    String message = message + (char) payload[i];  // convert *byte to string
    Serial.print(message);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String mqttID(mqtt_ID);
    String clientId = "ESP8266ClientFlow" + mqttID;
    //clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str())) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      //client.publish("test1", "hello world");
      // ... and resubscribe
      percentageHumididy = client.subscribe(m_perc_in);
      relais = client.subscribe(Ralais1_in);
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  restebuttonstat = digitalRead(resteButton);
  if (restebuttonstat == HIGH) {
    reset_setting();
    delay(5000);
    wifiManager.reboot();
  if (!client.connected()) {
    reconnect();
  client.loop();
  currentMillis = millis();
  if (currentMillis - previousMillis > interval)
    pulse1Sec = pulseCount;
    pulseCount = 0;
    // Because this loop may not complete in exactly 1 second intervals we calculate
    // the number of milliseconds that have passed since the last execution and use
    // that to scale the output. We also apply the calibrationFactor to scale the output
    // based on the number of pulses per second per units of measure (litres/minute in
    // this case) coming from the sensor.
    flowRate = ((1000.0 / (millis() - previousMillis)) * pulse1Sec) / calibrationFactor;
    previousMillis = millis();
    // Divide the flow rate in litres/minute by 60 to determine how many litres have
    // passed through the sensor in this 1 second interval, then multiply by 1000 to
    // convert to millilitres.
    flowMilliLitres = (flowRate / 60) * 1000;
    flowLitres = (flowRate / 60);
    // Add the millilitres passed in this second to the cumulative total
    totalMilliLitres += flowMilliLitres;
    totalLitres += flowLitres;
    // Print the flow rate for this second in litres / minute
    Serial.print("Flow rate: ");
    Serial.print(float(flowRate));  // Print the integer part of the variable
    Serial.print("L/min");
    Serial.print("\t");       // Print tab space
    char FlowRate[10];
    dtostrf(flowRate, 9, 2, FlowRate);
    client.publish(flowRate_out, FlowRate);
    // Print the cumulative total of litres flowed since starting
    Serial.print("Output Liquid Quantity: ");
    Serial.print(totalMilliLitres);
    Serial.print("mL / ");
    Serial.print(totalLitres);
    Serial.println("L");
    char FlowtotalLitres[10];
    dtostrf(totalLitres, 9, 2, FlowtotalLitres);
    client.publish(FlowLiters_out, FlowtotalLitres);
    char FlowtotalMilliLitres[10];
    dtostrf(totalMilliLitres, 9, 2, FlowtotalMilliLitres);
    client.publish(FlowMiliLiters_out, FlowtotalMilliLitres);
  Serial.print("Percentage humidity in: ");
  Serial.println(percentageHumididy);
  if (percentageHumididy < 50) {
    digitalWrite(RelaisPin, HIGH);
    Serial.println("Relais ON");
    percentageHumididy = 60;
    delay(5000);
  else if (percentageHumididy > 50) {
    digitalWrite(RelaisPin, LOW);
    Serial.println("Relais OFF");
Edit: I know there are some other error but i think they are related to the formatting of the setup..
And i counted the brackets but did not find anything.
The auto formating is leading to the codestructure above..
thanks and nice day
The IDE can help you match your { with your }
Thanks for the answer but how can the IDE help me?
Did you try the right click thing and then select "auto format"?
You can use the IDE's auto-format tool, or just put the cursor on a { or } and the IDE will highlight its matching brace
Yes for shure i tried it, was my first step trying to solve the problem
Ok i know the auto formatting and the highliting of the braces.
Thats what i have done at the beginning to solve the problem.
And i counted every brace on my own and found nothing.
thats why i ask here, because i can not find the problem
Maybe someone is so nice and can take a look
thanks
Dang, I had hoped the auto-format would help. To be honest your code looks like a mishmash of people's code strung together in a hodge-podge fashion which makes it hard to follow. Actually, I quit trying to figure it out.
What you might do is to comment out everything. Then in blocks do some logical uncommenting till you find the error.
yes, the code is only a copy of two example codes which i copied together in an row.
Sorry that the examples which i took are that bad.
Funny thing is when i delete the last } which close the setuo the code is wotking :slight_smile: :sweat_smile:
Try:
This at least highlights the correct brace for the } before the else.
Looks like the #ifdef confused the auto-formatter and/or the brace matcher.
First thanks for the answere.
But no, the problem stays the same.
But i also think it has to do with the section you metioned.
But i dont know why.
The auto formatting is setting the code section to the beginning so it looks like it dont get that the setup function is there.
It should be one tab away from the edge..
Yes, because the else is in the wrong place.
Oh thanks for the hint, now it is working!
Like you said the #endif was the problem.
Thanks for your help!
Have a nice day
Also thanks to @Idahowalker for trying to help me!
Without persons like you are a beginner like me would not get further...
PS: Sorry for my bad englisch..
