issue with if statement
what i’m trying (and failing spectacularly) to achieve is for my relay (rele) to turn on during the 16 hour period defined between 5 am and 9 pm and off for the rest of the time. the issue is that it ignores the else if part of the code. thanks in advance for your help!!!
 RtcDateTime now = Rtc.GetDateTime();
  //encendido y apagado del led
  if (now.Hour() > 5 && now.Hour() < 21) {
      Serial.println("hola");
      digitalWrite(rele, HIGH);
 else if (now.Hour() < 21 && now.Hour() > 5) {
     Serial.println("chau");
     digitalWrite(rele, LOW);
here is my code
//librerias
#include <Arduino.h>
#define BLYNK_PRINT Serial
#include <SPI.h>
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h>
#include "DHT.h"
#include "timer.h"
#include "TimerOne.h"
#include <Wire.h>
#include <RtcDS3231.h>
//conecciones
#define DHTTYPE DHT22
#define W5100_CS  10
#define SDCARD_CS 4
#define DHTPIN 2
int rele = 5;
int t2000, ft2000;
int sensorPin = 0;
int sensorValue = 0;
int ht = 0;
int tref = 0;
boolean Encendido = false;
char auth[] = "";
DHT dht(DHTPIN, DHTTYPE);
RtcDS3231<TwoWire> Rtc(Wire);
  pinMode(rele, OUTPUT);
  //--------RTC SETUP ------------
  Rtc.Begin();
  RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
  if (now < compiled)
    Rtc.SetDateTime(compiled);
  Rtc.Enable32kHzPin(false);
  Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeNone);
  //--------BLYNK SETUP-----------
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
 // Blynk.begin(auth);
  //Blynk.run();
  timer_update(&ft2000, &t2000, timeout_t2000);
void timeout_t2000() {
  float t = dht.readTemperature();
  float h = dht.readHumidity();
  Blynk.virtualWrite(V1, t);
  Blynk.virtualWrite(V2, h);
  if (isnan(h) || isnan(t)) {
    return;
  sensorValue = analogRead(sensorPin);
  ht = 1023 - sensorValue;
  Blynk.virtualWrite(V3, ht );
  timer_reset(&ft2000, &t2000, 2000);
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
  char datestring[20];
  snprintf_P(datestring,
             countof(datestring),
             PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
             dt.Month(),
             dt.Day(),
             dt.Year(),
             dt.Hour(),
             dt.Minute(),
             dt.Second() );
  Serial.print(datestring);
Do you see some difference between those two sets of conditions? I sure don’t…
Regards,
Ray L.
If the hour value is not between 5 and 21, why do you need to perform another test?
Or more simply:
  digitalWrite (rele, (5 <= now.Hour() && now.Hour() < 21)) ;
(Simpler, and more correct as it will turn on at 5am, not 6am)
More correct, possibly, but not simpler. More compact != simpler. It does not do everything that the original code does, and requires more study (on my part, anyway). I like my comparisons to happen in an if statement.
Arguable - conditional execution is much harder to reason about than boolean valued expressions, in the general case. More clear would be to use a predicate function:
bool is_daytime_hour (int hour)
  return hour >= 5 && hour < 21 ;
void loop ()
  digitalWrite (rele, is_daytime_hour (now.Hour()) ;
