Issue with Interfacing Multiple MQ7 Modules to ESP32
Hi everyone,
I've been tackling a project involving interfacing two MQ7 modules with an ESP32. I followed a modification detailed on this site to enable the digital output pin to act as a heater enable pin. Below is the circuit diagram I've been using:
Circuit Diagram: MQ7 Circuit Diagram - Album on Imgur
The problem I'm encountering is that the second MQ7 sensor (MQ7 - 2) consistently returns an analog value of 0 when connected this way. Previously, I had these sensors connected to an ESP8266 board. Since the ESP8266 only has one analog pin, I could only connect one sensor at a time. In that setup, both sensors returned analog values: the first one gave around 50 in clean air, while the second one gave around 14.
However, when attempting to connect both sensors to the ESP32 as illustrated in the circuit diagram, only the first sensor reads an analog value of about 300, while the second sensor returns zero.
Here's the twist: when I connect the supposedly "faulty" second sensor to the Vin and Gnd of the ESP32, it returns an analog value of about 25.
I'm aware that I could work around this issue by connecting only the first sensor to the external supply and the second sensor to the ESP32. However, I'm curious as to why this discrepancy is occurring. Additionally, I've heard that the MQ7 draws relatively high currents, so directly connecting it to the ESP32 might pose some risks.
Could someone please shed some light on why this is happening? Any help would be greatly appreciated.
PS: Apologies for the messy circuit diagram; I'm not familiar with drawing circuit diagrams, so I resorted to using PowerPoint. :smile:
Here is the code I'm using:
//* ------------------------------ Header Files ------------------------------ *//
#include <Arduino.h>
#include<TFT_eSPI.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include<DHT.h>
#include <driver/adc.h>
//* --------------------------- ST7735 TFT Display --------------------------- *//
TFT_eSPI tft = TFT_eSPI();
//* ---------------------------------- MQ-7 ---------------------------------- *//
#define mq7_heater_pin_1 32
#define mq7_analog_pin_1 35
#define mq7_heater_pin_2 25
#define mq7_analog_pin_2 34
unsigned long startTime;
unsigned long elapsedTime;
unsigned long heater_duratio_1n = 55000;
unsigned long read_duratio_1n = 90000;
enum State
  HEATING,
  MEASURING,
  DONE
State currentState = HEATING;
bool heatingMessagePrinted = false;
bool measuringMessagePrinted = false;
#define default_temperature_1 34.0 // Default temperature_1 in Celsius
#define default_humidity_1 69.0    // Default relative humidity_1 in percentage
#define mq7_low_side_resistor 1000
#define mq7_high_side_resistor 470
#define mq7_supply_voltage 5.14
#define mq7_clean_air_compensated_resistance_1_1 39239.95  //7224.43
#define mq7_clean_air_compensated_resistance_1_2 35792.9325
//* ---------------------------------- DHT11 --------------------------------- *//
#define dht1_pin 33
#define dht_type DHT11
DHT dht1(dht1_pin, dht_type);
#define dht2_pin 13
DHT dht2(dht2_pin, dht_type);
//* -------------------------- Function Prototyping -------------------------- *//
void printEverySecond();
void updateRawData_1();
float calculateresistance_1(float raw_value_1);
float calculateCompensatedresistance_1(float resistance_1, float temperature_1, float humidity_1);
float calculateratio_1(float compensated_resistance_1);
float calculateCOppm_1(float ratio_1);
void updateRawData_2();
float calculateresistance_2(float raw_value_1);
float calculateCompensatedresistance_2(float resistance_2, float temperature_2, float humidity_2);
float calculateratio_2(float compensated_resistance_2);
float calculateCOppm_2(float ratio_2);
void tft_level_print(float co_ppm);
//*                               Setup Function                               *//
void setup(){
  dht1.begin();
  dht2.begin();
  //* ---------------------------- Initializing MQ7 ---------------------------- *//
  pinMode(mq7_heater_pin_1, OUTPUT);
  pinMode(mq7_heater_pin_2, OUTPUT);
  startTime = millis();
  //* ----------------------- TFT initialization & layout ---------------------- *//
  tft.init();
  tft.fillScreen(TFT_BLACK);
  tft.setTextColor(TFT_WHITE);
  tft.drawString("CO Level", 14, 0, 4);
  tft.drawString("ppm", 55, 100, 2);
//*                                Loop Function                               *//
void loop(){
   elapsedTime = millis() - startTime;
  switch (currentState) {
    case HEATING:
      digitalWrite(mq7_heater_pin_1, HIGH);
      digitalWrite(mq7_heater_pin_2, HIGH);
      if (!heatingMessagePrinted) {
        Serial.println("The sensors are heating!");
        heatingMessagePrinted = true;
      if (elapsedTime >= heater_duratio_1n) {
        currentState = MEASURING;
    case MEASURING:
      digitalWrite(mq7_heater_pin_1, LOW);
      digitalWrite(mq7_heater_pin_2, LOW);
      if (!measuringMessagePrinted) {
        Serial.println("The sensors are measuring!");
        measuringMessagePrinted = true;
      if (elapsedTime >= read_duratio_1n) {
        currentState = DONE;
    case DONE:
      if (digitalRead(mq7_heater_pin_1) == LOW && digitalRead(mq7_heater_pin_2) == LOW) {
        updateRawData_1();
        updateRawData_2();
        Serial.println("Done\n");
    default:
//*                      Function that shows time elapsed                      *//
unsigned long previousMillis_sec_check = 0; // Variable to store the last time the function was called
unsigned long currentSecond_sec_check = 0; // Variable to store the current second
String last_updated_sec; //String to print in display
void printEverySecond() {
  unsigned long currentMillis_sec_check = millis(); // Get the current time
  // Check if a second has passed since the last call
  if (currentMillis_sec_check - previousMillis_sec_check >= 1000) {
    // Save the last time the function was called
    previousMillis_sec_check = currentMillis_sec_check;
    // Increment the current second
    currentSecond_sec_check++;
    if(currentSecond_sec_check < 60){
      tft.drawString("Last updated ", 0, 128, 1);
      tft.setTextColor(TFT_MAGENTA);
      tft.print(currentSecond_sec_check);
//*              Function that updates MQ-7 data to Serial Monitor             *//
void updateRawData_1() {
  float temperature_1 = dht1.readTemperature();
  float humidity_1 = dht1.readHumidity();
  analogReadResolution(12);
  analogSetPinAttenuation(mq7_analog_pin_1, ADC_0db);  //SHUNT = IO35
  float raw_value_1 = analogRead(mq7_analog_pin_1);
  float resistance_1 = calculateresistance_1(raw_value_1);
  float compensated_resistance_1 = calculateCompensatedresistance_1(resistance_1, temperature_1, humidity_1);
  float ratio_1 = calculateratio_1(compensated_resistance_1);
  float co_ppm_1 = calculateCOppm_1(ratio_1);
  Serial.println("---------------------------------- MQ7 1 ---------------------------------");
  Serial.print("temperature_1: ");
  Serial.print(temperature_1);
  Serial.println(" °C");
  Serial.print("humidity_1: ");
  Serial.print(humidity_1);
  Serial.println(" %");
  Serial.print("MQ7_1 Raw Value: ");
  Serial.println(raw_value_1);
  Serial.print("MQ7_1 resistance_1: ");
  Serial.println(resistance_1);
  Serial.print("MQ7_1 Compensated resistance_1: ");
  Serial.println(compensated_resistance_1);
  Serial.print("MQ7_1 ratio_1: ");
  Serial.println(ratio_1);
  Serial.print("MQ7_1 Carbon Monoxide: ");
  Serial.println(co_ppm_1);
  tft_level_print(co_ppm_1);
  //sendSOS(String(co_ppm_1));
  //Serial.println(gmapLink);
float calculateresistance_1(float raw_value_1) {
  return (raw_value_1 /  mq7_supply_voltage)* (mq7_low_side_resistor - mq7_high_side_resistor);
float calculateCompensatedresistance_1(float resistance_1, float temperature_1, float humidity_1) {
  return resistance_1 / ( (-0.01223333 * temperature_1) - (0.00609615 * humidity_1) + 1.70860897);
float calculateratio_1(float compensated_resistance_1) {
  return 100.0 * 1/(compensated_resistance_1 / mq7_clean_air_compensated_resistance_1_1);
float calculateCOppm_1(float ratio_1) {
  float ratio_1_ln = log(ratio_1 / 100.0);
  return exp(-0.685204 - (2.67936 * ratio_1_ln) - (0.488075 * ratio_1_ln * ratio_1_ln) - (0.07818 * ratio_1_ln * ratio_1_ln * ratio_1_ln));
void updateRawData_2() {
  float temperature_2 = dht2.readTemperature();
  float humidity_2 = dht2.readHumidity();
  analogSetPinAttenuation(mq7_analog_pin_2, ADC_0db);
  float raw_value_2 = analogRead(mq7_analog_pin_2);
  float resistance_2 = calculateresistance_1(raw_value_2);
  float compensated_resistance_2 = calculateCompensatedresistance_2(resistance_2, temperature_2, humidity_2);
  float ratio_2 = calculateratio_2(compensated_resistance_2);
  float co_ppm_2 = calculateCOppm_2(ratio_2);
  Serial.println("---------------------------------- MQ7 2 ---------------------------------");
  Serial.print("temperature_2: ");
  Serial.print(temperature_2);
  Serial.print("humidity_2: ");
  Serial.print(humidity_2);
  Serial.print("MQ7_2 Raw Value: ");
  Serial.println(raw_value_2);
  Serial.print("MQ7_2 resistance_2: ");
  Serial.println(resistance_2);
  Serial.print("MQ7_2 Compensated resistance_2: ");
  Serial.println(compensated_resistance_2);
  Serial.print("MQ7_2 ratio_2: ");
  Serial.println(ratio_2);
  Serial.print("MQ7_2 Carbon Monoxide: ");
  Serial.println(co_ppm_2);
  //tft_level_print(co_ppm_1);
float calculateresistance_2(float raw_value_2) {
  return (raw_value_2 /  mq7_supply_voltage)* (mq7_low_side_resistor - mq7_high_side_resistor);
float calculateCompensatedresistance_2(float resistance_2, float temperature_2, float humidity_2) {
  return resistance_2 / ( (-0.01223333 * temperature_2) - (0.00609615 * humidity_2) + 1.70860897);
float calculateratio_2(float compensated_resistance_2) {
  return 100.0 * 1/(compensated_resistance_2 / mq7_clean_air_compensated_resistance_1_2);
float calculateCOppm_2(float ratio_2) {
  float ratio_2_ln = log(ratio_2 / 100.0);
  return exp(-0.685204 - (2.67936 * ratio_2_ln) - (0.488075 * ratio_2_ln * ratio_2_ln) - (0.07818 * ratio_2_ln * ratio_2_ln * ratio_2_ln));
//*              Function that prints the CO Level on the Display              *//
void tft_level_print(float co_ppm){
  tft.setTextColor(TFT_CYAN);
  tft.setTextSize(0.2);
  tft.drawString(" ", 20, 60, 8);
  tft.drawString(String(co_ppm), 20, 60, 8);
TLDR: When interfacing two MQ7 sensors with an ESP32 using a modified circuit, the second sensor always returns an analog value of 0, while the first sensor works fine. Connecting the "faulty" second sensor directly to the ESP32's Vin and Gnd yields a nonzero analog value. Seeking insights into why this discrepancy occurs and potential safety concerns with directly connecting the MQ7 to the ESP32.
Hi, @adarshkannan887
Have you read the data on the MQ7?
MQ-7.pdf (52.2 KB)
Tom.. :smiley: :+1: :coffee: :australia:
